Old 03-29-2021, 06:17 PM #1
Swipter Swipter is offline
Swipter will become famous soon enough Swipter will become famous soon enough
Do I keep my original spare or take one of the current wheel and tires?
I am in the process of ordering my wheels and tires for my sr5. I don't want to do a five tire rotation since I will be sticking with 265 70 17.
Do I just keep the spare that's underneath or should I take one of the other wheels and tires?
I don't want to keep the original wheels and tires, 13k on a 2018 with no tire repairs.
Thanks
Swipter is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 07:51 PM #2
DAW89446's Avatar
DAW89446 DAW89446 is offline
Real Name: Dave
DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light
DAW89446's Avatar
Real Name: Dave
It has been my practice with all my 4x4 vehicles to keep the OEM spare. I have run BFG All Terrains on all of them since the 1990s and I stick with stock tire sizes.
That being said, if one is going significantly larger over stock tire size, than it can be beneficial to put the larger size tire on the spare wheel to avoid drivetrain damage or having to rotate the smaller tire to the non-powered axle and the larger tire to the driven one.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
DAW89446 is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 08:03 PM #3
5thToy 5thToy is offline
5thToy is just really nice 5thToy is just really nice 5thToy is just really nice 5thToy is just really nice
If I am in a situation where one of my KO2 C load (stock size) experiences a failure, I don't want to bet on an OEM Dunlop P getting me home through the same terrain. I bought a 5th KO2 and mounted it on the spare steelie. I guess it depends on what you will be doing with the vehicle.
5thToy is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 09:22 PM #4
Smitty19TRD Smitty19TRD is offline
Smitty19TRD will become famous soon enough
If sticking with the same size and only do light off-roading, especially with others, keep the OEM. If you like to get way out in the back country by yourself, such as overlanding, primitive remote camping or the like, you may want to consider slapping the same tire on the OEM steel wheel. Like stated above, the OEM spare may not de up to handling rough terrain.
Smitty19TRD is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 09:50 PM #5
DAW89446's Avatar
Real Name: Dave
DAW89446's Avatar
Real Name: Dave
I’ve been fortunate enough that I’ve never had to resort to the spare tire with BFGs. And I never was easy on the tires. My 2002 Tacoma TRD, which is still in the family after I replaced it with my ‘18 SR5, still has its OEM spare and I’ve only had to remove it to replace the shocks. Still holding street pressure air, though I’m sure the rubber is getting pretty dried out by now.
But yes, those OEM 5th gen tires I had on my rig were pretty feeble. I sliced one sidewall on my first off road ride. The BFG Rugged Trail T/A tires that came with the Tacoma I ran until they had 38k on them and they were pretty well sliced and diced but never failed me. And the OEM tires on my 1996 Chevrolet S-10 4x4 pickup, Goodyear Wrangler RTS stood for “Really Thin Spare.” Ten flats and one ripped sidewall in the first three months.
Dave
2018 4Runner SR5
Old 03-29-2021, 10:00 PM #6
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough
What I would do:
Option 1: Order 4 wheels and 5 tires. Slap one of the new tires on the OEM spare wheel underneath.
Option 2: Order 4 wheels and 4 tires. Shop around for a used all terrain tire in the same size and slap it on the OEM spare wheel underneath. You can possibly find a used tire on here or craigslist or FB marketplace.
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
Old 03-29-2021, 10:59 PM #7
All great suggestions. Does it matter if the spare is 10 pounds heavier than the tire opposite, if I had I had to use it?
If I get the same tire it will be 10 pounds, thereabouts, heavier than the rest.
Thanks for all the suggestions.
Old 03-30-2021, 03:22 AM #8
If the tire is the same, then the weight difference in the wheel/tire setup comes down to the wheel. A difference of 10 lbs between an aftermarket allow wheel and the OEM steel spare wheel seems like a lot. I would guess it would be more like 5 to maybe 7 lbs difference. That being said, I have had to put the spare on and ran it for 250 miles before I was able to get the normal tire patched and put back on. I noticed absolutely no difference. I went through some pretty tough off-road terrain, windy mountain roads, and freeways at 70+ mph. Absolutely fine.
Old 03-30-2021, 08:56 AM #9
It is the wheel. It's lighter. If I get a 265 C load ko2 it will be equal in weight but not as durable. Trade offs, I guess but still better than an oem tire.
I think that's the direction I will go.
Old 03-30-2021, 10:42 PM #10
Sounds good! Ya like I said, I've ran the same tire on the spare wheel across from the same tire on a lighter aftermarket wheel for 250 miles through different terrain and driving conditions and never noticed a difference and felt 100% fine the entire time. You would be fine with whatever tire you got.
original , spare , tire , tires , wheels
FS: 245 60 20 Michelin Tires, plus spare wheel/tire - San Diego, CA $50 each saltywolf For Sale: Suspension/Wheels/Tires 3 01-27-2018 11:32 AM
FS: 5th Gen-Set of 4 Stock Tires (3k Miles) + Original Spare(Unused) $500-Denver,CO Spudgey For Sale: Suspension/Wheels/Tires 3 08-14-2017 09:09 PM
FS: 2016 Trail Wheel/Tires + Spare $700 RENO, NV bartvonwolf For Sale: Suspension/Wheels/Tires 7 06-09-2016 12:39 AM
Atlanta: 2015 Limited 20" Spare Wheel / Tire and Set of OEM 245/60-20 Tires NEW TRSAndrew For Sale: Suspension/Wheels/Tires 7 01-03-2016 01:39 AM
FS – Four 3rd Gen – 16” - 5 Star OEM Wheels and Tires, and one spare wheel - $ 350 Ho Ruff For Sale: Suspension/Wheels/Tires 6 09-05-2013 10:24 PM
