AuSeeker
Old 05-02-2021, 05:13 PM #16
David H David H is offline
David H is on a distinguished road
Power Back Window Problem - Extra Advice!
Originally Posted by slide531 View Post
I raised the window one inch and paused it and here is what I see on the pulley. Definitely need to replace the Regulator sub-assembly.
Hey slide531
That looks exactly like the issue I had! (Although with a lot more rust!!)
You'll deffo have to replace the Regulator Sub-Assembly.
Power Window Motor most likely OK, as the metalwork in your photos isn't rusty or corroded. Your cable probably sucked in grit from the dirt/mud/sand/salt inside your tailgate and the to and fro of cable movement frayed the wire.
If you have a local Dealer they should have the replacement part in stock, or an express delivery internet purchase. The full repair took me 8 hours, but at least 3 hours of this was removing the Wire Harness, prepping the replacement and fitting the new Wire Harness (I bought the replacement on eBay and had to swap most of the plastic clips over as the breakers yard had snapped them on removal), so you could get the job done in 4 hours one day/night this week, and still make your camping trip!?
I'd recommend you clean all the mud and grime out of the interior of the Tailgate once you remove the old sub-assembly and before fitting the new one. Otherwise you have the detailed step by step instructions from Rytanium’s Post #31:
Liftgate Window Regulator Corrosion
and lightfreak's repair photo diary:
Liftgate Window Regulator Corrosion , to follow - what could possibly go wrong!!
take note of lightfreak's tip in post #11:
"The coiled end of the [new] regulator cables comes tightly zip tied. It will come flying apart if you're not careful. It's a little tricky to get onto the motor, you just have to wiggle the round coiled part onto the square nut of the motor assembly until it locks in and sits flush. Then press the rest of it into place and screw the cover back on."
I didn't have to do this, as my sub-assembly came (from the breakers yard) with the motor already attached.
If you have any questions, please post here, or send me a PM. I'm not sure where in the USA you live - seems like West Coast? I'm in London, England, so we're 8 hours time difference apart. London being 8 hours ahead of you. So if I don't reply straight away, I'm probably asleep!!
Good Luck with the Repair. Let me know how it goes!
Cheers, David H
David H is offline   Reply With QuoteReply With Quote
back , close , i’ve , rear , window
Back Window Problem. rxshu 3rd gen T4Rs 63 09-01-2022 12:19 PM
Problem with back window beliboy32 3rd gen T4Rs 4 07-10-2016 10:21 PM
New back window problem hickrob Classic T4Rs 1 09-12-2010 08:40 PM
Back window won't power up.....any thoughts? arouth 4th Gen T4Rs 4 10-23-2006 02:31 PM
Back window problem nateb21 Problems & Warranty Issues 1 02-21-2005 02:02 PM
