Old 03-31-2021, 01:23 PM #16
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
Originally Posted by TRDHULK View Post
So I have the same sound in the lower drivers corner of the windshield. I read somewhere this is called windshield cream and is caused by off-roading. The windshield seal is creaking. I plan to take it to the dealer and try to get a new windshield
Actually, mine is coming from the same area. It always comes on after rough roads, but goes away on road after a while - like a day or so. I thought about it being the windshield, but when it's making noise, putting pressure on the glass doesn't change it. Does it mean it's not the seal? Perhaps not, but so long as there's no leak, I'm not gonna worry about it.
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 03-31-2021, 02:31 PM #17
Tedward Tedward is offline
Tedward is on a distinguished road
Update: first, thanks for input / suggestions here! The dealer just called me to provide an update. They have removed the plastic outside air intake that runs along the bottom of the windshield. They then drove it and didn’t hear the rattle. They then drove another Limited they had on the lot and it was making the same noise! They’re proposing to add felt between the air intake and engine compartment wall to see if it solves it. They’re awaiting approval from Toyota before doing so. Stay tuned.......
99 4Runner Ltd (retired)
04 Tundra (retired)
10 4Runner SR5
21 4Runner Nightshade
Tedward is offline   Reply With QuoteReply With Quote
Old 03-31-2021, 02:36 PM #18
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
I have a rattle, almost a buzz, sounds like from my external DRIVER SIDE mirror. Intermittent too. Gonna check some of this stuff. Thanks!
thennen is offline   Reply With QuoteReply With Quote
Old 03-31-2021, 03:57 PM #19
RunTheJoules's Avatar
RunTheJoules RunTheJoules is offline
Real Name: Tyler
RunTheJoules is on a distinguished road
Real Name: Tyler
Originally Posted by Tedward View Post
Been hearing a rattle similar to a loose screw near the lower right passenger side windshield area. Some days it’s very noticeable, others it’s not. Dealer has it now for the 2nd time to try and resolve it. No rhyme or reason as to why it’s noticeable sometimes and then it’s quiet. Did it the entire ride to the dealer but upon arrival when they rode with me it quieted right down. They have heard it, problem is, it wasn’t a service tech. (Service manager & sales rep). Not sure if it’s inside or outside. Dealer has it now, a tech is going to drive it to try and get it to act up. Figured I’d put it out her just in case someone else may be experiencing something like this. No TSB found. Our new 21 Nightshade we’re trying to enjoy but this annoying issue is dampening it. Just hit 1000 on it and nearly a third of that is going back and forth to the dealer to resolve.
Mine had a slight rattle/squeak coming from the front driver side that was more frequent on rough roads, and nearly nonexistent on smooth ones. Started around 6-7K miles out of nowhere. Took it to the dealer and all they did to fix the problem was "adjust the hood risers". Hadn't heard of hood risers, but that's what the ticket says, and I haven't heard the rattle a single time since then. No one ever seems to mention the hood as a culprit, but I'm betting that mine wasn't the first case.
22 TuRDPro
RunTheJoules is offline   Reply With QuoteReply With Quote
Old 06-10-2021, 11:55 AM #20
Update here as this issue is still a mystery. I’ve learned the noise seems to occur when the temperature drops below 50 degrees. The last 3 times it reappeared it was a cold, raw and rainy day. It’s never occurred during warm weather. I think it has something to do with the windshield seal, I told the dealer I’ll pursue it with them in the fall when we have steady colder weather. Going to suggest they consider pulling the windshield.
04 Tundra (retired)
10 4Runner SR5
Old 06-10-2021, 04:59 PM #21
4Rums 4Rums is offline
4Rums will become famous soon enough
The noise coming from the corner of the windshield on my Limited was caused by the issue described in this thread. It was most annoying in cold weather too. A squeaking/crackling noise resolved
4Rums is offline   Reply With QuoteReply With Quote
Old 06-10-2021, 05:26 PM #22
rblt rblt is offline
rblt is on a distinguished road
We had that exact symptom show up 3-4 years ago after a long trip from Vancouver, BC to Portland, OR.
After a lengthy trial and error session, I eventually pressed hard on the black windshield plastic molding on the lower right exterior as if to reseat it and that seems to have worked. I think I may have repeated the process only once in the past 3-4 years.
Presumably a certain cadence of vibration, section strips on concrete highway, etc. may have unseated some cosmetic plastic bits?
2016 Limited - Blizzard Pearl / Black - owner since July 2016
rblt is offline   Reply With QuoteReply With Quote
Old 06-10-2021, 08:04 PM #23
Unfortunately the noise we’re hearing is different than the one described in the post shared, thanks though. What we hear sounds like a loose screw or something similar rattling against glass. As mentioned, colder temps seem to trigger it. I have audio of it and shared it with the dealer. Going to wait until the fall to work with them on resolving.
04 Tundra (retired)
10 4Runner SR5
Old 01-01-2023, 08:18 PM #24
DocHalsey DocHalsey is offline
DocHalsey is on a distinguished road
Hey Tedward (the Tedward?) - did you ever get a resolution here?
Just picked up a 23 SR5 Premium and have an intermittent rattle in the passenger dashboard area.
DocHalsey is offline   Reply With QuoteReply With Quote
Old 01-22-2023, 03:44 PM #25
Dzldust Dzldust is offline
Dzldust is on a distinguished road
I have the same problem but mine starts after a light rain and sounds like pebbles knocking around .Happens between 40-65mph.Never when it’s dry out only during a light drizzle .I’m messing with it now trying to track it down.Has done it since brand new,everything looks secure and nothing loose so far that I’ve found
Dzldust is offline   Reply With QuoteReply With Quote
area , dealer , it’s , resolve , windshield
Windshield area rust RPS99SHO 3rd gen T4Rs 21 09-18-2018 10:01 AM
Rattle Noise From Driverside Dash Area helpmet4r 4th Gen T4Rs 17 03-30-2016 09:58 AM
Rattle Noise from Lower Windshield Area TRDP-FL 5th gen T4Rs 3 01-19-2015 08:51 PM
Windshield rattle? badspell68 5th gen T4Rs 2 04-01-2014 12:07 AM
Sunglass Storage Area Rattle? NoDak 4th Gen T4Rs 4 03-17-2004 09:56 AM
