Old 03-30-2021, 09:11 PM #1
Toyota.ARK Toyota.ARK is offline
Toyota.ARK is on a distinguished road
Factory Spring Marking Orientation After Bilstein 5100 Install
1st Question:
Do the markings on the factory spring need to always face forward?
2nd Question:
Are these markings always on the second rung?
3rd Question:
Do the last rungs of the coil always need to face outward?
Thanks!!
Toyota.ARK is offline   Reply With QuoteReply With Quote
Old 03-30-2021, 10:48 PM #2
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
Originally Posted by Toyota.ARK View Post
1st Question:
2nd Question:
3rd Question:
Thanks!!
The end of the springs, front and rear, must fit in the pocket of the spring seat. Markings mean nothing.
fkheath is offline   Reply With QuoteReply With Quote
Old 03-31-2021, 01:08 PM #3
If the markings came from the factory on the second front-facing rung, does it go back that way after a Bilstein shock swap? With them facing backwards, the end of the coil is in the front now.
Old 03-31-2021, 01:28 PM #4
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
Yes, the paint codes need to face forward. I had a dealer do it wrong and when I mentioned it, they corrected the spring orientation. Paint codes should point forward.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 03-31-2021, 01:30 PM #5
maybe switch front shocks from left to right. Spring should seat properly and paint codes should be facing front. 3rd gens had specific left and right springs. Both my 5th gen fronts appear to be Yellow/Pink. Maybe its Yellow/Purple IDK
1999 4runner
Old 03-31-2021, 11:16 PM #6
The factory repair manual (TOYOTA 2016-2019 4Runner Repair Manual RM27F0U) makes no mention of paint codes. See page 5140 for the front springs and page 5177 for the rear springs.
As I said before, the end of the springs must be seated correctly in the notch of the top and bottom plates. The paint codes are meaningless.
Old 04-01-2021, 01:31 AM #7
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Mine seem to fit the same conditions: Paint codes forward, on the second coil.
Factory Spring Marking Orientation After Bilstein 5100 Install-973d0d5d-0478-4449-9141-b3ca9cf63e35-jpg
1000MPH is offline   Reply With QuoteReply With Quote
face , factory , markings , question , spring
OME front spring install on Bilstein 5100 & SPC UCA's ClamChowder 4th Gen T4Rs 2 01-20-2021 04:38 PM
Bilstein 5100 and Old Man Ema Spring CT_NGO 5th gen T4Rs 15 03-21-2017 05:14 AM
bilstein 5100 Spring seat orientation. RDFISHGUY 5th gen T4Rs 2 07-28-2015 03:56 PM
Bilstein 5100 Spring preferences??? tjhaf2007 4th Gen T4Rs 4 10-06-2014 08:31 AM
Another FJ Spring/Bilstein 5100 set up question bkm Engines / Suspension / Wheels / Tires / Audio / Accessories 22 08-10-2010 12:44 AM
