Old 03-31-2021, 02:46 PM #1
BarberJoeJr BarberJoeJr is offline
BarberJoeJr is on a distinguished road
2021 4Runner Limited: 2" front / 1" rear lift with 275/60R/20 tires ?
Question:
I just ordered the 2" front / 1" rear leveling / lift from Cornfed and want to make up the gap with a taller tire on my stock Limited wheels.
After a bunch of reading it looks like people are having good luck with putting a 275/50r/20 on the stock Limited wheels. So my thinking is,
if that size works, and I am lifting the truck why cant I run a 275/60r/20 for alittle more sidewall and to full up the gap the lift is going
to provide ?
Thoughts ?
BarberJoeJr is offline   Reply With QuoteReply With Quote
Old 04-09-2021, 06:49 PM #2
zrlee zrlee is offline
zrlee is on a distinguished road
Following
zrlee is offline   Reply With QuoteReply With Quote
Old 04-12-2021, 08:27 AM #3
Originally Posted by zrlee View Post
Following
Thanks for the follow, but this topic is dead in the water for whatever reason.
I find it hard to believe that their isn't a Limited owner with the stock 20" wheels running a 275/60/20 tire on this forum..?
Old 04-12-2021, 01:44 PM #4
dezertbomber dezertbomber is offline
dezertbomber has a spectacular aura about dezertbomber has a spectacular aura about
you cant tell me their isnt a Limited owner with the stock 20" wheels running a 275/60/20 tire..
Limited's are less common, so less experienced users to reply back.
I have a 2010 Limited that I bought used that already had a 3" front and 1.25" spacer lift on it with I believe the tire size you're looking to go to (aftermarket wheels but prob same offset as stock so moot point. Also, I've since switched everything out on it.)
I can tell you that with a 33" tire like you want to run, even with my front being lifted 3" the plastics needed to be trimmed a little on the front lower portion. Not a ton, but it'd rub otherwise. Since you'll be an inch lower, you may need to do even more.
I really liked how it sat with the spacer lift. If you're interested I'd sell you my old ReadyLift set. Would have to see how much shipping is to set a reasonable price. (I'll throw in my old XREAS set I removed as well haha! I removed super clean, only a couple minor drips [not sure why everyone does it wrong...])
dezertbomber is offline   Reply With QuoteReply With Quote
Old 07-28-2021, 10:40 PM #5
Update 7/28/21
Finally got around to doing some stuff to my 2021 Nightshade.
Tinted the windows (including the front windshield), removed the factory roof rack, lift and larger tires. Lift is a Cornfed 2/1 lift and tires are 275/55/20 Nitto Ridge Grapplers on the stock Nightshade wheels. No rubbing. No issues what so ever.
First two pics are of the truck with the lift and the stock tires. The others with the Nitto's..
2021 4Runner Limited: 2" front / 1" rear lift with 275/60R/20 tires ?-liftstockwheels-jpg  2021 4Runner Limited: 2" front / 1" rear lift with 275/60R/20 tires ?-liftstockwheels1-jpg  2021 4Runner Limited: 2" front / 1" rear lift with 275/60R/20 tires ?-unnamed-jpg  2021 4Runner Limited: 2" front / 1" rear lift with 275/60R/20 tires ?-newtires1-jpg  2021 4Runner Limited: 2" front / 1" rear lift with 275/60R/20 tires ?-newtires2-jpg  2021 4Runner Limited: 2" front / 1" rear lift with 275/60R/20 tires ?-newtires3-jpg  2021 4Runner Limited: 2" front / 1" rear lift with 275/60R/20 tires ?-newtires4-jpg  2021 4Runner Limited: 2" front / 1" rear lift with 275/60R/20 tires ?-newtires5-jpg
Old 09-29-2021, 07:26 PM #6
Removed the factory roof rack the other day. Truck looks SO much better (my opinion)...
2021 4Runner Limited: 2" front / 1" rear lift with 275/60R/20 tires ?-roofrackdelete-jpg
Old 09-29-2021, 07:43 PM #7
CJmixer99 CJmixer99 is offline
CJmixer99 is on a distinguished road
I replied to another post with this same question, but I recently put tires on my 2022 TRD Sport. I put on a set of K02 tires 275/55/20 and no rubbing
2022 4Runner TRD Sport - All Stock
CJmixer99 is offline   Reply With QuoteReply With Quote
Old 11-11-2021, 05:14 PM #8
CAMERONB123 CAMERONB123 is offline
CAMERONB123 is on a distinguished road
Which 275 ridge grapplers are you running? i see they make a lt 275 and a regular 275. the lt seems to be a e rated tire and a tad bit bigger than the regular 275. your 4runner looks good. im doing the same set up and just wanna make sure the tires dont rub. but wanna fill the fener well as much as i can without rubbing. thanks
CAMERONB123 is offline   Reply With QuoteReply With Quote
Old 11-13-2021, 01:58 PM #9
Superjet Superjet is offline
Superjet has a spectacular aura about Superjet has a spectacular aura about
A went cheap and installed these on the Limited OEM rim a few days ago. Walmart exclusive at $124 each is hard to beat
Cooper Discoverer A/T All-Season 275/55R20 117T Tire - Walmart.com
2016 4Runner Limited
Superjet is offline   Reply With QuoteReply With Quote
Old 12-19-2022, 11:00 PM #10
Mr.Everett2021 Mr.Everett2021 is offline
Mr.Everett2021 is on a distinguished road
This rig looks amazing! well done. Did you have any issues installing this kit? im assuming you have the X-REAS. Have you had any issues with it since installation. Did you gas mileage change much
Mr.Everett2021 is offline   Reply With QuoteReply With Quote
Old 07-04-2023, 10:34 PM #11
LimitedBuild LimitedBuild is offline
LimitedBuild is on a distinguished road
Bump - can we bring this one back. I am going to be building a limited with a similar spec 2/1 and 275/55r20.
LimitedBuild is offline   Reply With QuoteReply With Quote
Old 08-22-2023, 10:43 AM #12
burton4 burton4 is offline
burton4 is on a distinguished road
Update on lifts
have a 2020 limited looking to do similar lift, do you have any information on if it change you factory ride ? MPG ?
Will be removing old x-reas suspension.
Think im going with bilstein with daystar 2/1 level kit ?
any suggestion?
burton4 is offline   Reply With QuoteReply With Quote
gap , lift , limited , stock , wheels
Used 3" Front 2" Rear corn fed spacer lift, and more! Batmango66 For Sale: T4R Items 2 02-22-2020 07:12 PM
Bilstein 6112 2.5" Front Lift, 2" Toytec Rear Springs with either FOX or ICONs..?? fromLRtoT4R 4th Gen T4Rs 13 05-17-2019 05:02 PM
Post your 2.5" front 1.5" rear lift pics here please!! 10ac 5th gen T4Rs 1 05-26-2016 09:25 PM
How could I get a 2"front 1"rear lift for a 2003 Duke Off-Roading 14 12-02-2009 02:04 PM
cornfed 3" front / 2" rear lift for 2003+ 4Runner minghi Classifieds - buy & sell (no commercial ads please) 13 08-24-2007 09:45 AM
