Old 03-31-2021, 06:54 PM #1
RustyAb's Avatar
RustyAb RustyAb is offline
RustyAb has a spectacular aura about RustyAb has a spectacular aura about
RustyAb's Avatar
Parasitic battery drain help
Hey guys, did a search and couldn’t find what I was looking for. I have a 15 SR5. I’ve put 2 new batteries in since fall last year, just drained too many times in winter and got them replaced under warranty luckily. I threw an amp meter on, and I am drawing 175 Milliamps drain. I just went through every relay and fuse looking for issues. I only found 2 problems.
Trailer brake fuse, once pulled I showed a decrease of 20milliamps. So I ended up just unplugging and removing my brake controller.
Now the Dome light relay, when removed will drop approximately 60 milliamps. I don’t have any bulbs out, haven’t done anything with cheap Amazon led’s. Should I replace every single bulb with oem sizes?
My question is, everything I’ve been told is that 50-60mA is normal. So any ideas where to look next for the rest of my drains? I’ve removed all aftermarket electrical mods. So it’s a pure oem system. I’m lost, thought for sure I’d pull a fuse and find it. Thanks!
RustyAb is offline   Reply With QuoteReply With Quote
Old 03-31-2021, 08:10 PM #2
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
You’ve removed all aftermarket electrical mods? What were those?
thennen is offline   Reply With QuoteReply With Quote
Old 03-31-2021, 08:31 PM #3
RustyAb's Avatar
RustyAb's Avatar
Anything that I had tied in electrically. Disconnected my winch, took out my onboard air, ditch lights. Removed headunit and installed oem unit. Even pulled out my URD maf calibrator.
Old 03-31-2021, 10:56 PM #4
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
There are things that are always on you cannot turn off such as the key unlock button sensors.
How long does your 4Runner sit with out running the engine and charging the battery? Any decent battery should be able to last a month with out charging. If yours are not, get a better or different brand battery.
If you go over a month, then put a battery maintainer to keep the charge up.
fkheath is offline   Reply With QuoteReply With Quote
Old 04-01-2021, 12:37 AM #5
RustyAb's Avatar
RustyAb's Avatar
The battery is not the issue. I’ve measured that I’ve got over the normal drain.
Old 04-01-2021, 12:49 AM #6
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
How long are you actually waiting before doing your test and pulling fuses?? Some systems won’t go to sleep for hours after shutting down. When you’re pulling fuses you might be resetting their time out. If you can find out how long it takes for the system to go to sleep on the 4Runner. At 150 milli amps it should take about a week of sitting around before the battery goes dead. You still might have a defective alternator, an alternator could still undercharge and not turn the warning light on since it will only come on when there’s nothing coming out of it.
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 04-01-2021, 04:40 AM #7
thennen's Avatar
thennen's Avatar
No aftermarket remote start then? I had a similar drain caused by a remote start in a Corolla a year ago or so. Pulling the inline fuses fixed it.
Old 04-01-2021, 07:22 AM #8
RustyAb's Avatar
RustyAb's Avatar
Sorry I forgot to say earlier, I had an accessorides remote start that has also been pulled. Also a pedal commander haha.
I’m just stumped, that if I pull the dome fuse there was no change. But if I pull the relay, I had that drop.
Old 04-01-2021, 08:19 AM #9
thennen's Avatar
thennen's Avatar
If you think it's related to the dome light relay, maybe a flaky door or liftgate switch? You could try turning all the dome lights to 'Off' with the doors open and measure, then have someone depress and release each switch one at a time while you watch for changes. Then close each door one at a time (to hold each switch closed in succession) and watch for changes.
Still thinking...
Old 04-01-2021, 01:33 PM #10
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
Mine would run down until I removed a Bluetooth device plugged into the ODBC port. It was taking power all the time.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 04-02-2021, 11:16 PM #11
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Here’s what I get for my 18 ORP. No remote start. I have made electrical mods, almost everything is on ignition power, other stuff is on switched constant power. Removed the OBDII interface dongle.
Hooked up the DVM in series with negative battery post wiring.
After getting out of the drivers seat, did not arm the alarm, and closing the door the dome lights etc are on for 30 seconds or so and it draws about 600mA.
Then it drops to about 135 mA and stays there for about 20 minutes.
Then the ECUs go into sleep mode and it drops to about 12mA.
I saw somewhere in a Toyota service manual that typical is 50 mA or less.
Old 04-04-2021, 01:39 PM #12
trchandler's Avatar
trchandler trchandler is offline
trchandler is on a distinguished road
trchandler's Avatar
I have the same issue with my 1998. Measuring a 175 milliamps draining. When I check all the fuses and relays, no drop in the drain. Had 3 places check the alternator and all say it's good. Good luck and will keep following this post to see if you find a solution. And I'll let you know when I find mine.
trchandler is offline   Reply With QuoteReply With Quote
Old 04-04-2021, 01:53 PM #13
Superjet Superjet is offline
Superjet has a spectacular aura about Superjet has a spectacular aura about
I have a 2016 Limited with prox key. Takes about 30 minutes to go to sleep and rest around 50 - 60ma. I also have a remote start which is about 20ma, a telematics Drone unit which is 5 - 10ma but spikes to short bursts when talking with a cell tower, and a aftermarket radio with Maestro module at around 12m there. Dashcam also there which I havent measured but it does operate and record in an event with ignition off.
50ma should get you a week on a good, fresh battery that hasn't been drained before. Since I work from home for a while I was using a battery tender Jr with a quick disconnect cable out the front grill. I finally broke down and bought a hybrid Northstar battery from batteries+. The battery was well worth it since it's not a daily driver anymore.
2016 4Runner Limited
Superjet is offline   Reply With QuoteReply With Quote
Old 02-16-2023, 09:53 PM #14
Jerrylmac Jerrylmac is offline
Real Name: Jerry
Jerrylmac is on a distinguished road
Real Name: Jerry
Smile Also fighting parasitic battery drain.
I have been looking for my parasitic battery drain too. If I remove the dome light fuse or relay, my amp draw goes down by 130 MA. The dome light relay tests good, but it is energized all the time. All lights in the system work normally! I’m thinking the problem must be in the body computer. I will probably just add a switch in the fuse circuit so when driving at night I can use the dome lights. Otherwise, the switch will stay off. The parasitic draw will take a new battery down to zero in about 4 days so I’ve been using a trickle charger.
Jerrylmac is offline   Reply With QuoteReply With Quote
brake , fuse , i’ve , milliamps , relay
Huge Parasitic Battery Drain Problem pax 3rd gen T4Rs 36 07-04-2019 05:19 PM
Parasitic Battery Drain... Alternator? legokcen 3rd gen T4Rs 25 12-20-2018 08:45 PM
Parasitic drain dgmorr 4th Gen T4Rs 21 12-02-2018 11:17 AM
Parasitic battery drain 2003 Rav4 AntleredRuin Off Topic 12 05-30-2017 04:07 PM
Battery drain- Parasitic? Short? SamJay 4th Gen T4Rs 17 04-28-2015 11:32 PM
