Old 04-03-2021, 01:18 PM #1
Tricio69 Tricio69 is offline
Tricio69 is on a distinguished road
Lift install...LCA or Spidle/UCA method?
Hi, seeing a couple of methods for swapping out the front struts when installing a lift. Either dropping the lower control arm (loosen CAM bolts and remove lower knuckle bolts) or unbolting the the spindle from the upper control arm.
Any thoughts (pros/cons) to either method? The dropping the LCA seems more straight forward, so wondering why someone would use the unbolting the spindle from UCA method.
Pardon me if this has been discussed, I wasn't able to find if it has.
2021 Magnetic Grey Venture (bone stock for now, but give me a couple weeks!)
Tricio69 is offline   Reply With QuoteReply With Quote
Old 04-03-2021, 04:28 PM #2
MyanRagahis's Avatar
MyanRagahis MyanRagahis is offline
MyanRagahis will become famous soon enough MyanRagahis will become famous soon enough
I used the LCA method multiple times because it was easy enough to me after watching YouTube so many times and finally understood the spring decompression.
Didn't have or feel like renting a spring compressor.
Bright side is I did it so many times I learned how to do it quicker and quicker and learn about each part when I first started. Had torque numbers embedded in my head too.
Played around with lift heights on my Bilstein 6112's at the time so I had to decompress the spring a lot to adjust that circlip. Became easier and easier each time and I enjoyed it.
The only negative to me was losing my alignment but that comes with adjusting height anyway.
As for the uca/spindle method, I snapped my ABS wire because I forgot to unbolt the wire from the upper control arm when the uca separated from the spindle. About the only negative to me when doing that method but that was my fault.
I was simply swapping out my upper balljoint, not installing lift.
YouTube
MyanRagahis is offline   Reply With QuoteReply With Quote
arm , bolts , lift , method , spindle
Torque Pro Tranny temp Method 1 Method 2 / Level Check B.E. Coyote 4th Gen T4Rs 1 07-14-2020 11:35 AM
KDSS lift install method - anyone try this? str8flexed 5th gen T4Rs 10 01-06-2019 01:18 PM
Front Strut Removal During Lift **Method** bsdoig 3rd gen T4Rs 4 03-09-2015 12:54 PM
New Method Wheels and Lift todd 4th Gen T4Rs 16 03-08-2015 04:48 PM
Front shock install, no compressor method. TN22Corps 3rd gen T4Rs 23 04-12-2014 12:54 AM
