Old 04-03-2021, 08:51 PM #1
codan codan is offline
codan is on a distinguished road
tire pressure sensors/standard
2019 4Runner SR5
I'm looking at getting some very slightly used OEM rims to mount my winter tires on, but they don't have the tire pressure sensors.
Those tire pressure sensors are $45/each.
Can I just do without the tire pressure sensors? Will the warning light go off?
Dumb question, but this is the first vehicle I've had with tire pressure sensors and I don't know anything about them.
Thx
codan is offline   Reply With QuoteReply With Quote
Old 04-04-2021, 10:54 AM #2
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
I run my 2011 Limited with the OEM 20 inch rims and the TPMS sensors in the summer.
For the winter, I switch to OEM TRD Off-Road 17 inch rims and winter tires with no TPMS sensors.
The TPMS warning light flashes upon start up in the winter, and then will stay lit while the vehicle is operating. There is no audible (noisy) alarm.
To avoid distraction, some people will place a small piece of black tape over the warning light when they do not have TPMS sensors in their tires.
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 04-04-2021, 12:56 PM #3
03_4x4Runner's Avatar
03_4x4Runner 03_4x4Runner is offline
03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about 03_4x4Runner has a spectacular aura about
I have run my 2nd set of wheels and tires with no tpms for years. I just put a piece of tape over the light.
I bought 4 trail wheels for my 2014 4runner from a 2018 4runner and they have the tpms sensors on them. I was hoping to use these sensors on my 2014 but I am being told they are incompatible. They are for a 2018-2019 only.
If you are interested in them make me a reasonable offer. They would have to be reprogrammed every time you swap the wheels and tires though.
03_4x4Runner is offline   Reply With QuoteReply With Quote
Old 04-04-2021, 01:10 PM #4
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
I had my TPMS light come on a couple weeks ago. I checked all the tires with a gauge and they were fine. Turns out, after a little research, the TPMS sensors last about 7 - 8 years before the internal battery goes bad. I don't know about newer 4Runners but my 2013 will not indicate which tire is setting off the light. You'd think for a 40K vehicle it would; plus include the spare. A cheap Chevy van, we had at work, had a little display of each tires pressure - comeon Toyota! Replacing the sensors isn't cheap - probably about $50+ per wheel. With just a light, I'll never know when the other sensors go bad; or how many are reporting. The piece of black tape over the light is probably the best solution!
Old 04-04-2021, 01:45 PM #5
Glenn Goodlett's Avatar
Glenn Goodlett Glenn Goodlett is offline
Glenn Goodlett will become famous soon enough
Newer models report each tire and can be reprogrammed from the dash. Still no spare unless you get a limited.
2020 Army Green TRD Pro
2007 FJ
Glenn Goodlett is offline   Reply With QuoteReply With Quote
Old 04-04-2021, 08:53 PM #6
I ended up buying the wheels, they've got tires on them that look pretty good (maybe 15,000 in wear, so lots left). I think I'll run them with these tires which will last about a year then put on the take-offs and do TPMS at that time.
Old 04-04-2021, 09:53 PM #7
oljedi11950's Avatar
oljedi11950 oljedi11950 is offline
oljedi11950 will become famous soon enough oljedi11950 will become famous soon enough
Lightbulb
Amazon or OEWheels sell oem tpms sensors not to bad 75-80 bucks for 4 & then get em programmed ! Lotta folks don't like but they can save the hassle of flats quicker imo !
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
oljedi11950 is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 12:08 AM #8
Jacabbysal's Avatar
Jacabbysal Jacabbysal is offline
Jacabbysal is on a distinguished road
Jacabbysal's Avatar
I replaced the tpms in my 2010. I had Discount tire do the programing and I bought the sensors off of amazon.
Amazon.com: MORESENSOR Signature Series 315MHz TPMS Tire Pressure Sensor | Preprogrammed for Select 270+ Japanese Brand Models | Replacement for 42607-33011 | Clamp-in | NX-S008: Automotive
2010 SR5 4x4 Ultra Warlock with 285/70/17 FIRESTONE DESTINATION X/T
Toytec Boss 2.0 Front Aluma Series Coilovers, Bilstein 5100 rear
Icon 2" Lift Rear Coil Springs, Shrockworks skid plates and rock sliders
ARB front bumper, Pro Comp UCA. ARB rear air locker, ARB twin 12v compressor.
Jacabbysal is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 12:23 AM #9
flyrv9's Avatar
flyrv9's Avatar
I asked the Tires Plus guy here - and they won't do sensors you take in. They will replace with their sensors and program. I did find on Amazon a set that just screws on the valve stem and comes with a reader. I don't know what each weighs or if there would be a balance problem.
Old 04-05-2021, 01:45 AM #10
cbreze's Avatar
cbreze cbreze is offline
Real Name: Jim
cbreze is on a distinguished road
cbreze's Avatar
Real Name: Jim
This is my first vehicle with tire pressure sensors, so not to familiar with them. What happens when the internal battery goes out? Does the dash light come on? Does that also mean that they are now worthless and need replacing?
My 2012 is approaching about 9 years of age. Also, I want to get new tires this summer for an extended road trip in the fall. Would it be foolish to expect 9 year old TPS to work long enough to be practical with the new tires or should I just get 4 new ones along with the new tires? I'm kind of old school and bought my first Toyota 4x4 back in 1974. I've never had an issue not having TPS since then and if I need new ones and it's a couple of hundred bucks for 4 installed I'm thinking of possibly skipping it. Would appreciate your thoughts.
Lovin' my 4R
cbreze is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 10:37 AM #11
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
on my 2020, i placed my spare without a sensor on the rear and the tire light came on. So, i installed a new sensor i bought for $22 and relearned it into the car and worked out fine. please note the 2020 monitors the tire pressure on each wheel and where it is located. In the dash, i can see the pressure on each tire. If you have the old version which don't monitor each tire, you might be okay. would be best though to have a tire sensor for safety.
Originally Posted by codan View Post
2019 4Runner SR5
Thx
4r-4ever is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 10:44 AM #12
This is the same brand sensor i installed on my spare with an alloy rim on my 2020. bought the moresensor NX-S009. Also, my 2005 4runner's original sensor is still working though. it's showing thought that 2 of them now have a low battery charge.
Old 04-05-2021, 01:11 PM #13
Nuke's Avatar
Nuke Nuke is offline
Nuke will become famous soon enough
Nuke's Avatar
7-8 years? Says who? My '08 T4R still has the original TPMS sensors which are still functional. Do the math.
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
Nuke is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 07:09 PM #14
flyrv9's Avatar
flyrv9's Avatar
A simple search gets gets 7-8 years and 5 -10 years. I did one last week and one just now; so there is some variance in the answers. Either way it's a battery so it will have a lifespan. You probably get more battery life in warmer areas.
Once the light comes on (at least on my 2013 SR5) it stays on. You might be able to turn it off with Techstream - but I doubt it due to it being a safety notification.
Old 04-17-2021, 12:53 PM #15
I ended up by the wheels and tires and having tire pressure sensors put on.
So I've got summer and winter wheels and tires, and an extra set of summer tires with about 13,000 wear on them
It worked out I guess.
light , pressure , sensors , tire , warning
Tire Pressure Sensors luke87gt 4th Gen T4Rs 9 11-20-2016 07:55 PM
Tire pressure sensors Tour991 For Sale: Suspension/Wheels/Tires 3 03-16-2016 01:23 PM
Tire pressure sensors teacherboy 4th Gen T4Rs 5 12-02-2007 07:31 PM
Tire Pressure Sensors iamtwonice 4th Gen T4Rs 14 10-08-2005 06:50 PM
03 have Tire Pressure Sensors TeryT 4th Gen T4Rs 16 04-08-2005 10:05 PM
