Old 04-04-2021, 02:54 AM #1
Rpede Rpede is offline
Rpede is on a distinguished road
130k miles 4Runner suspension replacement?
First time 4Runner owner. My 4Runner has all original stock OEM suspension parts. There is little to no rust on suspension and underneath. Does it make sense to replace the old suspension parts preemptively? What should I look out for that may soon need replacement at this mileage? Read some reports of coils being worn down at this mileage or less responsive.
I’m almost positive that struts/shocks front back need replacement as well as my upper control arms. I want to keep things stock (no lift)...has anyone tried the BillStein 4160 (yellow/blue) struts/shocks? If I don’t go with the 4160s I may just get OEM unless if someone has a recommendation. For stock OEM fit type upper control arms there doesn’t seem to be many options other than moog and ax delco.
Any other maintenance tips at this mileage I should concern myself with? Water pump and radiator are original...expecting these to go bad soon but maybe they last longer on Toyota’s? Replaced my spark plugs, belt, 3 idler pulleys and PCV valve last week. All fluids have been changed. I’m expecting something like a wheel bearing being needed soon at this type of mileage.
Rpede is offline   Reply With QuoteReply With Quote
Old 04-04-2021, 04:11 AM #2
Chubbypanda Chubbypanda is offline
Chubbypanda will become famous soon enough
So far you are on the right track...preemptive maintenance is always best.
I think you meant bilstien 4600 and this are good replacement over stock but for a bit more you can get the 5100 and adjust your front end slightly higher to level.
Have you greased your drive shaft? New wiper blades? Replaced cabin air filter? Brake pads and rotors!
Chubbypanda is offline   Reply With QuoteReply With Quote
Old 04-04-2021, 03:35 PM #3
djeepin djeepin is offline
djeepin is on a distinguished road
I think nothing better than original made in Japan components. Their steel production quality only surpassed by Swiss. All rubber components however deteriorating by that mileage, tear and wear, lubrications out - dirt in, and you have wear out components. Replacing all boots and seals will be cheaper and suffice. Unless someone in a shopping spree, only parts need replacing that bad already and need to be replaced.
djeepin is offline   Reply With QuoteReply With Quote
Old 04-04-2021, 05:35 PM #4
MAD 69's Avatar
MAD 69 MAD 69 is offline
MAD 69 is on a distinguished road
MAD 69's Avatar
Only 130K? I have 280K and all original suspension on my 3rd Gen, don't plan on needing a new one for my new 5th Gen til sometimes in the 2040's.
I would think it all depends on how hard you were riding off road.
98 T4R SR5 V6 4x4
23 T4R TRD OR Premium
MAD 69 is offline   Reply With QuoteReply With Quote
Old 04-04-2021, 07:07 PM #5
4FL 4FL is offline
4FL will become famous soon enough 4FL will become famous soon enough
4FL 4FL is offline
Unless you are doing some extreme driving, there is no reason to replace any of that.
130k is not a lot at all.
Why you expect the water pump or radiator to go bad? Why you replace your idler pulleys?
2015 Trail Premium w/KDSS, nautical blue, tinted windows, factory running boards, Cooper Discoverer AT3 4S stock size.
4FL is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 12:26 AM #6
Thanks everyone for your responses this is helpful. I replaced my idler bearings because of hearing about so many of them going bad around my mileage. The water pump I was thinking of replacing only because of my experience with a Honda which the water pump went out almost every 100k...maybe I should hold off on this and I’m getting too paranoid about something going bad. I don’t see any signs of leaks around and on the water pump yet. This is my first Toyota ever and I’m not certain of what typically goes bad after 130k in mileage. I know the prior owner did some towing which worries me, I did drop the pan and changed the filter and cleaned the magnets. I expected way more debris on the magnets than what I saw, perhaps I am used to the Honda automatics which always seem to shed a lot and the magnet would be saturated. I can’t believe the price of used 4runners with mileage as high as mine which held me back for the longest time in buying this beautiful machine. I couldn’t hold back and finely decided to get one and am praying nothing major creeps up on me. Changing my oil every 5k and doing a drain and fill every year on the trans fluid, diffs/tc, and engine coolant. Probably overkill but it helps me sleep better lol. Still debating which oil filter to consistently use: the OEM or the OEM TRD. Some say the TRD oil filter is too restrictive but I would think Toyota would have already tested this possibility?
Old 04-05-2021, 12:21 PM #7
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
I replaced all four of my shocks at around 140k. One of the fronts was starting to mist some oil on the housing. I researched the Billsteins and almost went with the 4160's, then I thought to myself, my stocks lasted 140k and I drive on some pretty rough washboard roads here and there. So, I went with the stock Tokico shocks. Think I paid around $150 or so and replaced them myself in the driveway. There is a way to do it without a spring compressor if you search around on here. Wasn't to bad, fronts took a little work and I could have used a helper but I got it done. Search on here for user SP8ball posts and you'll find the method I'm referencing.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 01:03 PM #8
Nuke's Avatar
Nuke Nuke is offline
Nuke will become famous soon enough
Nuke's Avatar
Preemptive is one thing. Premature is another.
I've owned 4 T4Rs (still have an '08 and '19), all high mileage with over 200,000 miles except the '19, and never replaced OE suspension components.
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
Nuke is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 01:13 PM #9
Muskrat14's Avatar
Muskrat14 Muskrat14 is offline
Real Name: Dave
Muskrat14 will become famous soon enough
Muskrat14's Avatar
Real Name: Dave
I’m at 115K and know that my shocks and struts are due for replacement.
The handling is bad n she wanders all over.
As far as stock control arms and other suspension components, they all will stay. Nothing wrong with them.
Muskrat14 is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 11:23 PM #10
@Jivewalker how have the 4160s been? Too firm or better than OEM?
Old 04-05-2021, 11:27 PM #11
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
My left front factory shock below at 86k. The rest were well worn. But I do a lot of desert off-road miles. My bushings still look good.
1000MPH is offline   Reply With QuoteReply With Quote
Old 04-05-2021, 11:56 PM #12
Jeremy556's Avatar
Jeremy556's Avatar
That's not a lot of miles. Are your shocks leaking? if you rock the body and let go, does the motion stop in 1 cycle?
My first stock suspension part to fail was a front LCA bushing at about 260k miles, and my use is atypical. I think it probably would have lasted at least 50% longer under normal use.
Old 04-06-2021, 07:57 AM #13
Jivewalker's Avatar
Jivewalker's Avatar
I decided against them and went with stocks (Tokico). Couldn't justify the Billstein price after getting 140k on my stocks. I'm at 218k now on the new set with no complaints.
I am fragile.
Not like a flower.
But like a bomb.
Old 04-06-2021, 09:07 AM #14
Mudballz's Avatar
Mudballz Mudballz is offline
Mudballz has a spectacular aura about Mudballz has a spectacular aura about Mudballz has a spectacular aura about
Mudballz's Avatar
You can have my stock shocks 1800 miles on them just pay shipping and boxing fees lmk
Mike
Mudballz is offline   Reply With QuoteReply With Quote
mileage , oem , replacement , stock , suspension
Advice: Worth buying '97 with 130K miles? Sonia186 3rd gen T4Rs 16 05-31-2015 01:18 AM
WTB: 4th gen SR5 or Sport. Under $15k and 130k miles, PNW. SeaScum_Scallywag For Sale: Vehicles 1 05-16-2014 01:09 PM
Looking for a 3rd generation manual 4R with 130k miles or lower ndsa New Members 2 09-28-2012 12:33 AM
Feeler: 2000 T4R, 130k miles coachjon 3rd gen T4Rs 5 04-07-2011 12:42 PM
Just purchased an '03 V8 with 130k miles... virulosity Maintenance/Detailing 11 04-12-2010 10:54 PM
