Old 04-06-2021, 09:11 PM #16
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Originally Posted by Saturnine90 View Post
+1 for the 400p
Only complaint is the bag it comes with is too perfect of a fit and could use some extra room.
haha... very true. The compressor has plenty of space, but the hose is like trying to fit yourself into pants that are one sizes too small after a large meal. You will get it in there, but it isn't comfortable.
Old 04-06-2021, 10:36 PM #17
5thToy 5thToy is offline
5thToy is just really nice 5thToy is just really nice 5thToy is just really nice 5thToy is just really nice
Another recommendation for the 400P
5thToy is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 05:31 PM #18
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
I have the 400P automatic. Duty cycle is 33% so you can run it up to 40 minutes so no issues filling up all 4 of my tires. It will automatically shut off when you release the trigger. I actually use some 6" velcro straps to hold the trigger down so I don't have to sit there and hold it down for 3 minutes on each tire. Easily comes off to shut off the compressor in between tires.
It does get very hot but I am sure the other ones do too. 2.3 CFM fills up from 15 psi to 35 psi in about 3 to 3.5 minutes a tire.
Shittybuilt has one that has 5.6 CFM so that sounds good but I have never used one. Ironman America has a 5.6 CFM that is usually a little cheaper and is probably the exact same one as the Shittybuilt (only cosmetic differences).
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 04-08-2021, 06:06 PM #19
CajunMikeR's Avatar
CajunMikeR CajunMikeR is offline
CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice
CajunMikeR's Avatar
That's not what that means. It means if you run it 20mins, you have to let it rest for 40mins before using it again. The psi rating for the duty cycle is important in that equation as well, if it's rated at 100psi then you can run longer at lower pressures because there's less heat generated during compression.
My 5.65cfm can fill all four 33in tires at once in about 5-7mins (the rest of my normal 10min inflation time is getting my manifold out & hooked up and putting it all back up in its bag afterwards), so one with about half that capacity will probably never reach the 20min mark filling 4 smaller offroad tires (under 35in).
2019 MGM TRD ORP
Dobinsons IMS 3in lift, FN f(x) Pros 17x8in 0 offset, 285/70 C load Nitto Ridge Grapplers, and all sorts of other fun stuff
shootn4runner on IG
CajunMikeR is offline   Reply With QuoteReply With Quote
Old 04-09-2021, 12:58 AM #20
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
Have the Smittybilt. Price was too good to pass up. Swapped out all the fittings for standard air fittings. It now matches my other vehicles and home setup. Throw away the yellow collapsible hose. Bought a heat rated collapsible hose from Harbor Freight.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 04-09-2021, 10:27 AM #21
1Louder 1Louder is offline
1Louder will become famous soon enough
AIR CHAMP PRO 5.65CFM - 12V Heavy Duty Portable Air Compressor (ICOMPRESSOR004)
Works great. Similar to the Smittybilt but I like the hose style better. It is still a proprietary connection though. For a few bucks more as plenty of others have mentioned the Viairs are great. I got this one as a temporary item until I feel like spending the $$$ on a dual chamber ARB. My FJ had a single chamber under the hood and you really can't over estimate how convenient onboard air is. Big cost difference though.
Dispensing advice 24/7. Usually free and sometimes worthwhile! @4xoa on the gram.
1Louder is offline   Reply With QuoteReply With Quote
air , compressor , model , offroad , tires
Haven't been around for awhile, not going anywhere, but... Kraeken 5th gen T4Rs 4 06-07-2017 07:43 AM
I can't believe I haven't done this yet WTF ! oljedi11950 Off Topic 14 03-19-2015 11:33 AM
If you haven't, do it now. TheArkMaster 3rd gen T4Rs 0 10-01-2013 09:30 PM
For those of you who haven't seen it Mason Fresh Pimp Zone 7 01-17-2010 04:53 AM
I haven't had a red one yet MikesToy 4th Gen T4Rs 11 09-23-2008 12:21 AM
