Old 04-10-2021, 04:42 AM #16
CITYRNR's Avatar
CITYRNR CITYRNR is offline
Real Name: Ben
CITYRNR will become famous soon enough
CITYRNR's Avatar
Real Name: Ben
With that cost, flexibility (I only want the side ones), and the controller being able to be mounted under the hood, I'm 100% in. Let's goooo!
2019 TRD ORP w/ KDSS (Silver) - 6112/5160 w/ SPC UCA, Full+Fuel RCI Skids, SSO Sliders, C4 Lo Pro w/ X20
CITYRNR is offline   Reply With QuoteReply With Quote
Old 04-10-2021, 03:39 PM #17
michalik.piotr6837's Avatar
michalik.piotr6837 michalik.piotr6837 is offline
michalik.piotr6837 is a jewel in the rough michalik.piotr6837 is a jewel in the rough michalik.piotr6837 is a jewel in the rough michalik.piotr6837 is a jewel in the rough
It sure on the connector yet but should be able to plug into most universal power banks. Average cost of a bi or tri fold amazon panel is b/t 120 to 170. So the 300 is not bad to have tailor fit to the hood.
Working on attacking.... most likely will go with plasti dip on the hood first to protect pain and have a uniform look then 3m spray adhesive and/or double stick tape.
michalik.piotr6837 is offline   Reply With QuoteReply With Quote
Old 04-12-2021, 09:10 PM #18
DirtyDanno's Avatar
DirtyDanno DirtyDanno is offline
DirtyDanno is on a distinguished road
DirtyDanno's Avatar
Interested for sure.
Success is not final, failure is not fatal: it is the courage to continue that counts
-Winston Churchill
DirtyDanno is offline   Reply With QuoteReply With Quote
Old 04-12-2021, 09:34 PM #19
NorthPark NorthPark is offline
NorthPark will become famous soon enough NorthPark will become famous soon enough
I'm curious to see how they will be with glare, I suspect having a panel on the hood scoop will be better than my mgm paint
NorthPark is offline   Reply With QuoteReply With Quote
Old 05-27-2021, 01:09 AM #20
Update, received panels and controller today. Initial impression is good. Need to make time to install and will update! Stay tuned!
Hood (w/scoop) solar panel measurements-e9e1997c-ab59-419d-97eb-90cbcf451546-jpeg  Hood (w/scoop) solar panel measurements-6998303b-31c0-4815-b1d2-f1e09313809a-jpeg
Old 05-27-2021, 05:46 AM #21
Blue109's Avatar
Blue109 Blue109 is offline
Blue109 has a spectacular aura about Blue109 has a spectacular aura about Blue109 has a spectacular aura about
Blue109's Avatar
This is bad ass!
If you're gonna scream, scream with me. Moments like this never last.
Raptor lights. eBay PRO grill. Pedal Commander. Plasti dip valence. Very limited edition overlanding stickers and headliner patches.
Blue109 is offline   Reply With QuoteReply With Quote
Old 05-27-2021, 12:15 PM #22
scratchhax scratchhax is offline
scratchhax has a spectacular aura about scratchhax has a spectacular aura about scratchhax has a spectacular aura about
Do they have an air gap under the panel? One of the things I've found with panels is that they really don't want to get hot (ironic huh) and being on the hood would probably compound that. A small air gap between the hood and panels though should keep it sorted.
scratchhax is offline   Reply With QuoteReply With Quote
Old 05-27-2021, 02:12 PM #23
No air gap. Could space it out but then run risk of it ripping off. Could insulate under hood. Others run similar panels with no issues tho.
Old 05-27-2021, 02:12 PM #24
Right on. depending on how they are built they may have a little gap internally. Great idea and props for putting in the work to give this a shot!
Old 05-27-2021, 02:56 PM #25
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
Having looked at the cascadia panels and having a 4th gen sport edition I am kind of interested to know if the dimensions would fit a 4th gen. hmm.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 10:49 PM #26
Room2Fly Room2Fly is offline
Room2Fly is on a distinguished road
I just need some room to fly,
I spent all of my days just trying to keep dry.
Room2Fly is offline   Reply With QuoteReply With Quote
Old 06-02-2021, 11:05 AM #27
Zal4R Zal4R is offline
Zal4R is on a distinguished road
I am going to have to follow this. Do you need to use all three, or can you just use the 2 sides? I do not need crazy amounts of output, but a trickle would keep my plans up and running.
Zal4R is offline   Reply With QuoteReply With Quote
Old 06-02-2021, 11:29 AM #28
Skykomish's Avatar
Skykomish Skykomish is offline
Skykomish will become famous soon enough
Skykomish's Avatar
If you're not planning on selling these yourself would you mind letting us know what manufacturer you're working with? If you are planning on selling them...
Skykomish is offline   Reply With QuoteReply With Quote
Old 06-03-2021, 12:55 AM #29
I’m doing this for myself and as a side effect to benefit the 4runner community not to get rich.
The company is Lensolar but these are not quite yet ready to sell. I’m waiting for some connectors from them, then I will install and test then they should be ready. I will post a promo code for discount as well.
Posting updates fast as I can.
Old 06-11-2021, 02:43 PM #30
Hoping to have the panels on this wknd. Prepping the hood.
Hood (w/scoop) solar panel measurements-de5fa8e6-64da-424f-8dd1-9e15c61c685c-jpeg  Hood (w/scoop) solar panel measurements-0afa2ff9-2bdd-44f2-9ab9-89673e535f5d-jpeg
hood , measurements , panel , solar , w/scoop
Does anyone have a 4th gen with RTT + roof mounted solar panel? vision-quest 4th Gen T4Rs 1 07-27-2021 01:49 PM
Solar panel mounting issues. vision-quest 4th Gen T4Rs 16 05-07-2016 02:01 PM
brunton solar panel jam23r1 For Sale: Non-T4R Items 2 09-05-2013 04:58 PM
WTT: Urban Runner Hood with scoop for non-scoop hood HowardRoark 4th Gen T4Rs 3 06-13-2013 02:59 AM
trade wanted - white plain 4th gen T4R hood for 4th gen hood scoop hood tjgaskill 4th Gen T4Rs 3 12-13-2010 04:58 PM
