Old 09-27-2021, 02:05 AM #91
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
Sweet rig. How do you like the GFC?
Originally Posted by Skykomish View Post
They're pretty meh. I still haven't bothered with the center panel. I don't think I'd recommend these at the price they're going for all things considered. I like the look and It's enough to keep my radios not drawing from the battery while I'm parked so I'm not about to rip them off though.
I've got a couple of bus bars under the hood for all my solar inputs that run back to a Redarc Manager30 + lithium battery mounted where the rear seats used to go.
rageandlove is offline   Reply With QuoteReply With Quote
Old 09-27-2021, 08:52 AM #92
Skykomish's Avatar
Skykomish Skykomish is offline
Skykomish will become famous soon enough
Skykomish's Avatar
Thanks! I'll get around to putting together a thread about it one of these days. Love the tent so far, very well made. The only issues I've had is that the straps tend to come loose when driving for multiple hours on the highway when wet and that it's a little hard to get in/out of when raining without getting a wet tent flap on your back. Setup is a little different but once you get the technique down it's almost as fast as a tent with gas struts and a hell of a lot easier to take down. Otherwise it's everything I'd want out of a RTT, would highly recommend if you're in the market for one.
Skykomish is offline   Reply With QuoteReply With Quote
Old 09-28-2021, 09:35 PM #93
Thanks! I'm definitely in the market, so great to have your perspective.
Old 10-12-2021, 10:32 AM #94
Peripateo's Avatar
Peripateo Peripateo is offline
Peripateo is on a distinguished road
Peripateo's Avatar
I kinda skipped to the end of this thread so I apologize if this was thoroughly covered but; Casacadia is pretty clean and easy.
It took all of 1/2 a second for someone to reply to my post seeking to swap my TRD hood for a smooth non-scooped hood of same color.
I didn't use the provided MPPT b/c my Redarc charge controller has a solar input.
Hood (w/scoop) solar panel measurements-ikamper1jpeg-jpg  Hood (w/scoop) solar panel measurements-image0-jpg
2018 TRD Premium: so...much...planned
Peripateo is offline   Reply With QuoteReply With Quote
Old 10-12-2021, 11:22 AM #95
Coastie6's Avatar
Coastie6 Coastie6 is offline
Coastie6 is on a distinguished road
Coastie6's Avatar
Originally Posted by michalik.piotr6837 View Post
I did not have my power bank going through the controller when I fried it. It was directly plugged into the panels. Obviously I know little about solar power and/but am a fan and learning. I incorrectly assumed i could plug it directly into the panels since I saw that was an option with other portable panels. Why did it not work for me? I don’t know.
This might help explain charging a Jackery with solar HOW TO Charge ANY Solar Generator With ANY Solar Panel | Bypass Controller | DIY Series Parallel - YouTube
USCG (Disabled)
2017 4Runner SR5
Coastie6 is offline   Reply With QuoteReply With Quote
Old 11-17-2021, 01:17 AM #96
ElJefe's Avatar
ElJefe ElJefe is offline
Real Name: Jeff
ElJefe will become famous soon enough
ElJefe's Avatar
Real Name: Jeff
I got mine fully installed and hard wired and so far so good. Not the biggest fan of the Lensun MPPT controller not having bluetooth but not the end of the world.
They are having a Black Friday sale with code: BK10 for anyone interested in buying from them.
2018 SR5 Premium | Dobinsons 3"/2" - F300/549 R325/705 | Dirt King Tube UCA | HIKEit Throttle Controller | Prinsu 3/4 Rack | Xenon Depot High Beams | Boslla B4 Series LED Low Beams | Lensun Hood Solar Panel | Rockpals Powerstation & Fridge
4Runner Mod Inspiration: https://trail4runner.com/
ElJefe is offline   Reply With QuoteReply With Quote
Old 11-20-2021, 04:21 PM #97
OutBreak's Avatar
OutBreak OutBreak is offline
Real Name: Cas
OutBreak will become famous soon enough
OutBreak's Avatar
Real Name: Cas
I used the Black Friday code, and they showed up sooner than expected.
Easy install, used the recommendations of VHB tape. Put four strips down the center, considering water egress and not worry about the edges peeling up. However, I did lay down vinyl, first, will see how it holds since it's not in direct contact with the hood.
This was the best option for me as I park outside and only commute 20miles round trip to work, so the extra trickle helps. I opted out of the controller as my redarc has a solar hookup.
Hood (w/scoop) solar panel measurements-20211120_151306-jpg
Whosoever is delighted in solitude is either a wild beast or a god.
OutBreak is offline   Reply With QuoteReply With Quote
Old 11-26-2021, 04:24 PM #98
CITYRNR's Avatar
CITYRNR CITYRNR is offline
Real Name: Ben
CITYRNR will become famous soon enough
CITYRNR's Avatar
Real Name: Ben
I'm interested in just the middle panel. If anyone buys a set with the black friday code I'll buy the middle panel off of you and pay 1/3, with the vinyl please. LMK.
2019 TRD ORP w/ KDSS (Silver) - 6112/5160 w/ SPC UCA, Full+Fuel RCI Skids, SSO Sliders, C4 Lo Pro w/ X20
CITYRNR is offline   Reply With QuoteReply With Quote
Old 03-04-2022, 04:05 PM #99
koltoncj koltoncj is offline
koltoncj is on a distinguished road
This is an awesome mod! I'll add it on my list of future to do mods Hood (w/scoop) solar panel measurements
koltoncj is offline   Reply With QuoteReply With Quote
hood , measurements , panel , solar , w/scoop
Does anyone have a 4th gen with RTT + roof mounted solar panel? vision-quest 4th Gen T4Rs 1 07-27-2021 01:49 PM
Solar panel mounting issues. vision-quest 4th Gen T4Rs 16 05-07-2016 02:01 PM
brunton solar panel jam23r1 For Sale: Non-T4R Items 2 09-05-2013 04:58 PM
WTT: Urban Runner Hood with scoop for non-scoop hood HowardRoark 4th Gen T4Rs 3 06-13-2013 02:59 AM
trade wanted - white plain 4th gen T4R hood for 4th gen hood scoop hood tjgaskill 4th Gen T4Rs 3 12-13-2010 04:58 PM
