Old 04-06-2021, 04:34 PM #1
phey_05 phey_05 is offline
phey_05 is on a distinguished road
Engine Bay Power Plant U.S. Pat. Pen. No. 63.167.432
This power plant is being powered by the Auxiliary battery called Full throttle FT-750-35. It uses RedArc bcdc 1225D in-vehicle battery charger to keep it charged while driving, ensuring the auxiliary battery is charged to a proven 100%. The RedArc bcdc 1225D uses a multi-stage charging profile to ensure auxiliary batteries are charged to 100% compared to a Smart Battery Isolator/relay will only ‘top up’ the secondary battery as it focuses on the state of charge of the primary battery. RedArc bcdc 1225D has solar regulator, allowing you to charge from solar panels and blankets, lessening the load on vehicle alternators.
The BlueSea Safety Hub 150 is connected directly to the Full throttle FT-750-35 and distribute power to the following accessories:
• Switch Pro 9100
• ARB Dual compressor
• AlphaRex Luxx Headlights
• BlackVue DR900X-2CH 4K UHD DashCam
• weBoost Drive Reach OTR Cell Phone Signal Booster
• Dometic CFX3 75DZ
• Baja Design S8 40” LED Light Bar
• Warn EVO 10s
• MXT275VP4 Micro Mobile® Bundle
• KC Lights 50” Flex LED light Bar
• Baja S2 Pro, LED Driving/Combo, Amber Reverse Light
The 5 gang 100amp bus bar eliminates the needs to IGN fuse taps for the following accessories, thanks to Switch Pro 9100 hidden capability.
• RedArc bcdc 1225D
The main battery is solely used for the vehicle that eliminates the possibility of being drained.
An Engine Bay Temperature monitor is also installed to keep statistics of different environment to make sure that the system always reaches its full potential and its limitation.
I would like to thank the following company/people that gives me perspective and help to put together this design: RedArc, SwitchPro, BlueSea systems, (Instagram) Offgrid Engineering, (Instagram) Power Tray, (Instagram) Sdoffroundmt and last but not the least, my local Guy that helped me make this design a success and U.S. Pat. Pen. No. 63.167.432
Anyone from SoCal that want to be a beta tester at cost HMU. ;)
IG: 4rtrdpro_am_hb
Pictures below: (I could me more detailed and clean on the wiring but this is prototype)
phey_05 is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 04:41 PM #2
Axix23's Avatar
Axix23 Axix23 is offline
Axix23 will become famous soon enough
Axix23's Avatar
^^ badass!!
Axix23 is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 05:12 PM #3
Bassturd's Avatar
Bassturd Bassturd is offline
Bassturd will become famous soon enough
Bassturd's Avatar
That looks amazing!
2004 SR5 V8 AWD
Bassturd is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 10:42 AM #4
Originally Posted by Axix23 View Post
^^ badass!!
Originally Posted by Bassturd View Post
That looks amazing!
Thank You Sir!
Old 04-07-2021, 12:12 PM #5
DangerDan DangerDan is offline
DangerDan is on a distinguished road
Does Las Vegas count as Socal? I'd beta test it
Sent from my SM-G960U using Tapatalk
DangerDan is offline   Reply With QuoteReply With Quote
Old 04-07-2021, 02:16 PM #6
Yes Sir, As long as you can come for the install and pay for the materials at cost.
Old 04-07-2021, 02:30 PM #7
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 will become famous soon enough
Hammer0313's Avatar
Real Name: Buck
Man that looks super clean, love it.
2019 TRD: - Engine 5w30/0w30 - Diffs Amsoil - BFG K02 - TC Amsoil 75-90
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 01:40 PM #8
Thank you!
Old 04-08-2021, 02:40 PM #9
HanginInUtah's Avatar
HanginInUtah HanginInUtah is offline
Real Name: Ben
HanginInUtah will become famous soon enough HanginInUtah will become famous soon enough
Real Name: Ben
As a fleet manager, I see a lot of custom installation work, especially in police and fire equipment. That installation looks well-thought out and very clean. Great job! If I was at a point of needing a secondary power source, I'd definitely hit you up for some help or the install. Awesome work!!
1992 3.0 Auto - First Project -Sold-
1995 3.0 Manual - Second Project - Sold-
2018 TRD ORP Barcelona Red
HanginInUtah is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 02:50 PM #10
ttime4four ttime4four is offline
ttime4four is on a distinguished road
Awesome - thanks for sharing.
I'm very interested in the temp readings your sensor is picking up. The Redarc is sensitive to heat and will throttle down / shut off depending on the temps.
130-175F --> de-rate output
175F+ --> shut off
2021 SuperWhite ORP
ttime4four is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 03:45 PM #11
175F+ --> shut off
Thanks for the comment Sir, Please check my IG & follow me: 4rtrdpro_am_hb
This is the reason why I installed an independent temperature monitor.
So far so good and plus it is the engine bay temperature, the RedArc has heat sink so it has to be accounted for.
I posted some stats in my IG and will continue to do so. That's why I am also interested for beta testers because I cant cover all types of application and environment.
Old 04-09-2021, 09:55 AM #12
Thank you Sir! appreciate the kind words.
Definitely, let me know if I can help.
Old 04-11-2021, 05:00 PM #13
AMLOR AMLOR is offline
AMLOR will become famous soon enough AMLOR will become famous soon enough
VERY NICELY DONE!!!
I have a similar setup in mine, Redarc, sp9100, blue sea aux fuse box etc.
That said, yours is so much "cleaner" of an install than mine is.
Really like your use of the Blue Sea 150. Nice addition to the setup.
Again, very well done. Super clean and professional.
Amlor
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, Whiteline, C4 Fab, BPF, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, Metal Tech, StrongBox, Eibach Load-Leveler rears & TRD Pro front coils, CE Auto Elect., Blue Sea, SP9100, Cornfed, RCI skids, BajaRack "basket", RIG'd Ultraswing, REV Gear 4.88's, NOCO 5x2 onboard
AMLOR is offline   Reply With QuoteReply With Quote
Old 04-11-2021, 10:04 PM #14
ruff4runner's Avatar
ruff4runner ruff4runner is offline
ruff4runner will become famous soon enough ruff4runner will become famous soon enough
175F+ --> shut off
Almost all of my trips are in the Mojave, so if your worried about the BCDC sitting in the heat of the engine bay like I was, you may want to consider using the Long Ranger Prado 150 Redarc mount available from Out of Town 4wd in Australia that mounts the Redarc in front of the radiator in the cool air. The same design mount is available from Redarc Australia, BCDC Mounting Bracket to suit Toyota LandCruiser Prado 150 | REDARC Electronics. The top mounts on the Prado 150 and the 4runner are identical, but you will have to relocate your horn. You may have to get creative with the bottom brace, but it amounts to drilling an additional hole in the brace. No temp worries, no temperature sensor necessary.
Engine Bay Power Plant  U.S. Pat. Pen. No. 63.167.432-screen-shot-2021-04-11-6-46-03-pm-png  Engine Bay Power Plant  U.S. Pat. Pen. No. 63.167.432-img_0212-jpg  Engine Bay Power Plant  U.S. Pat. Pen. No. 63.167.432-img_0216-jpg
2019 TRD ORP with stuff bolted to it and my Alaskan Malamute benevolent overlord, Farley. KN6HZJ
ruff4runner is offline   Reply With QuoteReply With Quote
Old 04-12-2021, 01:43 PM #15
Originally Posted by ruff4runner View Post
Almost all of my trips are in the Mojave, so if your worried about the BCDC sitting in the heat of the engine bay like I was, you may want to consider using the Long Ranger Prado 150 Redarc mount available from Out of Town 4wd in Australia that mounts the Redarc in front of the radiator in the cool air. The same design mount is available from Redarc Australia.
Thank you for the suggestion Sir, the purpose of the design is a modular system, more like Plug and play for guys that are not keen to install different mount and perform wirings, thus the reason of the test. I will keep on monitoring the temps in different environment and will update this forum and I do post it on my Instagram too. IG: 4rtrdpro_am_hb
1225d , battery , light , power , redarc
New power plant? itr1275 6th gen T4Rs 85 01-21-2021 10:45 PM
Buy a 2019 or 2020 if the 3.5 will be the power plant for the 6th gen troopa4life 5th gen T4Rs 21 03-04-2019 11:01 PM
Is the plant building 4Runners right now? Catchlight 5th gen T4Rs 5 05-17-2011 12:25 PM
GM plant closing. Falls Off Topic 3 10-13-2008 12:50 PM
power windows causes drop in engine power? jmfranc 3rd gen T4Rs 3 03-26-2008 08:51 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
