Old 04-07-2021, 11:35 PM #1
SteelStacks SteelStacks is offline
SteelStacks is on a distinguished road
SSO Slimline Bumper light bar
So I’ve finally decided to Install my SSO bumper that’s been sitting in my garage for a couple years. Problem is I don’t remember ever getting instructions for the 20 inch light bar install. Looked everywhere on the net and can’t find anything. Can anyone here help me out.
Light bar came with a bunch of bolts and brackets but I guess I don’t need them all. Is it just 2 bolts and washers that I need to use? Also bolts seem too long. Would love some clarification or a detailed write up if possible. Thank you.
SteelStacks is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 10:43 AM #2
Nalcyon Nalcyon is offline
Nalcyon will become famous soon enough
Yes, the lightbar came with several mounting solutions but the bumper already has tabs on the inside. You loosen the bolts on the sides of the lightbar, slide the bolts into the tabs, rotate the beam to your preference, then tighten up the bolts.
The rest of the stuff in the box is just stuff that came with the lightbar and not from SSO, it is used for several different mounting options.
If you need help holler, I'll try to get some pics.
Nalcyon is offline   Reply With QuoteReply With Quote
Old 04-09-2021, 09:19 PM #3
Thank you for the quick response. Used the 2 bolts and washers and fit perfectly. Guess sometimes the easiest answer is the right answer. Now to attach the winch and install the bumper.
Old 04-10-2021, 03:09 AM #4
DallasTRDPro's Avatar
DallasTRDPro DallasTRDPro is offline
DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light
A couple of years??
DallasTRDPro is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 03:57 PM #5
So finally got the bumper installed with winch and light bar set up. Did it myself and took forever to jack up the bumper and align the bolt holes because it was so wobbly on the jack.
Anyway, seems like the bumper is off center a bit.
Is the driver’s side off because I can see the stripping? Anyone one else experience this? It’s really bothering me.
Also, I wish the instructions would’ve said to cut below the valance outline a little bit. I feel like the gap between the stripping and the top of the bumper is too much when cutting right in the line. Curing a 1/4 below the outline would’ve been perfect.
bar , bolts , don’t , light , sso
FINALLY - 5th Gen Lo Pro/Slimline Bumper (10 - 13) gibburnz 5th gen T4Rs 106 04-11-2022 10:19 AM
HID lights or Slimline bumper Light Bar...Bang for Buck GogDog 5th gen T4Rs 13 08-21-2018 08:39 PM
