Old 04-08-2021, 08:35 AM #1
lewdog998's Avatar
lewdog998 lewdog998 is online now
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
yes i searched, stock pro w/285s
Searched and could not find anything definitive, mostly people asking about pro wheels.
ANYWAYS,
Stock 20 Pro. waiting on Eibach lift springs (in development) and UCA replacement (when springs come) but i need tires.
looking at the duratacs in D load....one of the few tires that approves 7 inch wheel. Weight seems reasonable and load rating seems like good compromise.
Any pro owners out there that have placed 285s on their ride without lift or ucas. i am fine with fender and flap mods if required.
If you did fit 285s, what brand, spec and did you have to realign to make fit?
thanks
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is online now   Reply With QuoteReply With Quote
Old 04-08-2021, 09:11 AM #2
Brick Sprickly's Avatar
Brick Sprickly Brick Sprickly is offline
Brick Sprickly is a glorious beacon of light Brick Sprickly is a glorious beacon of light Brick Sprickly is a glorious beacon of light Brick Sprickly is a glorious beacon of light Brick Sprickly is a glorious beacon of light
ANYWAYS,
thanks
Please use the search bar function and reference about 20,000 threads on the topic.
2019 TRD Pro Voodoo Blue "Cobra Commander"
Brick Sprickly is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 09:23 AM #3
lewdog998's Avatar
lewdog998's Avatar
Brick, I did search the bar...BUT all of the results were about pro WHEELS, and fitment issues as related to rim width etc. I did not find anything on specifically addressing my specific question (fitment to a stock Pro truck, not wheels) I appreciate your effort to keep the forum clean. If you know the answer, or can direct me to the specific thread that would be great.
Old 04-08-2021, 09:27 AM #4
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
Just search for "285s no lift". This will answer all your questions for pro and non-pro alike.
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 09:34 AM #5
omega3651 omega3651 is offline
omega3651 is on a distinguished road
I run 285/70/17 on a stock TRD PRO with the stock Bilstein TRD PRO suspension.
The 285s are Nitto Ridge Grapplers.
I've been running the 285s now for a couple years without issue.
omega3651 is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 09:37 AM #6
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
Pro should have a 1" front lift compared to other stock 4Runners. I think you can fit 285's as long as your willing to trim a bit of the front bumper and push the front fender liner forward.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 10:14 AM #7
This should get you covered:
Going Bigger - 5th Gen Tire Fitment Guide
Old 04-08-2021, 10:22 AM #8
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
Lifting an Independent Suspension does not allow for bigger tires. The geometry of the suspension is unchanged - it will travel in the same arc and start/stop at the same points.
So yes, 285/70R17 will fit a stock TRD Pro, *but* you will have to modify the front fender liner and possibly modify/remove the front mudflaps. If you change wheels or add wheel spacers you may contact the Body Mount or the plastic cover behind the mupflap that hides the pinch weld or even the pinch weld itself.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
Old 04-08-2021, 10:29 AM #9
lewdog998's Avatar
lewdog998's Avatar
Ahhh...makes sense....
Thank you all for your quick feedback.
Even you Brickly
Old 04-19-2021, 01:33 PM #10
lewdog998's Avatar
lewdog998's Avatar
They fit
Installed the 285 70 Duratracs, load D
Fit fine...minor rub that i fixed with heat gun, no trimming required.
yes i searched, stock pro w/285s-20210419_122943-jpg
Old 04-19-2021, 03:21 PM #11
Looks good. The duratracks in that size and load rating is probably the next tire that's gonna go on my truck after the KO2s wear out.
Surprised you have no rub, especially with the front flaps. Mine weren't even close to fitting with the flaps on. Same wheels as you.
Old 04-19-2021, 04:41 PM #12
lewdog998's Avatar
lewdog998's Avatar
I have the newer fox shock upgrade the TSB where they replaced the coilovers with the 21 version. I did not take measurements before, but they definitely sit a little higher than the originals (maybe because they are new...maybe that is not even a factor). They are definitely close though.
Old 04-19-2021, 08:05 PM #13
Gouranga Gouranga is offline
Gouranga is on a distinguished road
would this work for non pro but trd rims on a venture for example
Gouranga is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 08:57 PM #14
Grape Ape Grape Ape is offline
Grape Ape will become famous soon enough
Yes, you can run 285/70/17 on stock TRDP wheels and stock suspension on a TRDP itself. I did for over a year with no issues.
You have to remember that the bumper is trimmed at port on the TRDP in addition to the suspension and not on the other models, so you will have issues with 285s on a non-TRDP.
Grape Ape is offline   Reply With QuoteReply With Quote
Old 04-20-2021, 09:21 AM #15
Suspension lift height doesn't matter. I'm at 2.75" front with Kings. It doesn't matter because you're 'preloading' the suspension to sit higher. It still moves in the same arc through its travel. So if it's gonna rub, it's gonna rub anyway if you really stuff the tires.
But every truck is different slightly.
285s , load , pro , springs , tires
Need some links for getting my 285s to fit at stock height cj80cruiser 3rd gen T4Rs 34 04-19-2020 02:12 PM
285s on Stock SR5 Wheels Berty_K 4th Gen T4Rs 3 04-08-2019 07:29 PM
Show me 285s on Stock Trail 4RunnerTrail 5th gen T4Rs 48 02-02-2018 11:15 AM
285s on stock trail rims. UCA needed? awpsome 5th gen T4Rs 18 12-02-2015 11:24 PM
285s on stock TE RIMS 555R 5th gen T4Rs 17 06-08-2015 01:01 PM
