04-08-2021, 11:06 AM
Starter button inop, please help.
Alright folks. 2010 Limited here. The remote works to unlock the doors per usual, but the starter button will not do anything at all. It lights up how it should, but will not even turn the accessories on.
Some history: I’ve had it for a couple of years now but it’s been mostly sitting as it needed some bodywork done. I’ve started it on a semi-regular basis when I could; it was in a storage garage. Just a couple of weeks ago, the battery was flat. It was old to begin with, so I replaced it. When I replaced it, it came to life as usual. It started up, everything worked, I drove it about a mile to make sure that was the case. Fast forward to a couple days ago, the push-to-start will not work.
Some things I’ve done: I started with the easiest thing and replaced the battery in the remote hoping that’s all it was. Checked all fuses related to ignition and the smart key system. The switch for the brake pedal works as it should since the taillights work. The button itself is getting power. I’ve tried holding the key to the button and pushing it that way as well. Also tried holding the starter button down for 30 seconds for the override that supposedly exists.
If the accessories turned on but it wouldn’t crank, I’d be a lot less confused. But I can’t even get it to do that. It literally does nothing to try and start the truck. It recognizes the key, though. I’m hoping it is something simple that I’m overlooking, but I’m fresh out of ideas. I’ve googled to no end, but all I can find are answers related to a dead key fob battery or the actual battery itself. Any help would be greatly appreciated. Thanks!
2002 SR5 Sport Edition --> A work in progress.
04-08-2021, 11:21 AM
edit: I misread, OP, and thought your remote start wasn't working. Oops
04-08-2021, 11:27 AM
My first thought is the battery. You could have a parasitic drain that caused the battery to go flat -- down to where minimal voltage is there to unlock the car, but not enough is there to light up the dash.
If you have a multi-meter, what voltage are you getting from the battery?
Second thought is the car is not "seeing" the key (assuming we are talking keyless). That could have a bunch of issues (fob battery, malfunction on sensor, etc).
2021 SuperWhite ORP
Ironman FCP / WildPeak 285/70R17 / Sherpa Crestone / Autohome Columbus / OVS 180 Awn / C4 Slider / WD Ladder / OEM Audio+ / Rago Aux Battery with Redarc Charger / Trigger 4 / Husky Mats / Sequential Turn Signals / DD Pro Fogs / Ridgid Ditch Lights / Raptor Lights / EVO Corse DakarZero / Rockblokz Mud Flaps / Blackout Kit / TRD Pro Grill / C4 LoPro Bumper / Superwinch / Anytime Backup Camera / Canvasback / Rago Molle and Shelf
04-08-2021, 11:29 AM
If you have a parasitic drain, the new battery could be flat again after two weeks of sitting. Any way you can get a fresh battery to it, or jump it from another vehicle? Also, because I don't know, does having push-button start eliminate the keyed ignition?
Oops - ttime4four beat me to it.
04-08-2021, 11:44 AM
This was my initial thought, and that’s one thing that I forgot to include in the post; I did try and jump start it. I assumed the battery may have been sitting long or there was a drain of some sort. I have it a good amount of time using my Ridgeline and it didn’t change a thing. And part of the reason it’s so maddening is that there isn’t a place to use a physical key.
04-08-2021, 11:54 AM
I thought about the drain and tried jumping it as well. It didn’t change anything. I’m leaning towards the key not being recognized as far as the starting function is concerned, but I don’t know what could have gone bad or changed. The fob battery is new. And it the remote unlocks the car. And I’m hoping it’s not a proximity issue of not recognizing the fob to start.
04-08-2021, 12:09 PM
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
04-08-2021, 12:15 PM
Wouldn't hurt to check all the brake related fuses as well.
04-08-2021, 05:09 PM
Just for testing...try holding the FOB near the push to start button. Like one inch away and press the start button. I know you said you tried a new FOB battery but holding the FOB very close to the Push to Start button is a workaround for a inoperable FOB. Apparently there is some sort of NFC chip in the fob that works when the FOB battery is dead. worth a try.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
04-08-2021, 08:57 PM
Press the Start/stop button using with the tip of the remote in on it. That is backup method if you have FOB issues.
2016 4Runner Limited
04-09-2021, 06:32 PM
This was one of the more common solutions I’ve found that didn’t work. I was really hoping it would.
04-09-2021, 06:35 PM
Originally Posted by Bossman
I went through this as well. It was one of the posts I had found in my initial search, and part of the problem is that I can’t even get into accessory mode. The button simply does not do anything but light up.
04-09-2021, 07:12 PM
Just curious, why not have the dealer work it out?
04-10-2021, 01:53 AM
Is the vehicle in park? And if it is, try depressing the brake and moving the shift lever out of park and then back into park. And while still holding the brake, push the button to start. If it still doesn't work, disconnect the vehicle battery for a bit, maybe 10 minutes. Reconnect battery and try again. Also make sure battery is charged like someone else said.
Originally Posted by RysiuM
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
04-10-2021, 02:44 AM
Also came here to mention about making sure it is in park. I have not personally had an issue first hand, but I've read that the park neutral switch has been known to rust up and cause issues, especially for you with the vehicle sitting so much.
Edit: Also just came to me. Try to give your steering wheel a wiggle, I have seen when the steering lock on smart key vehicles isn't quite in the right spot/engaged properly, and it doesn't like that for starting. Aside from that, recommend trying to see if there are any trouble codes.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
