Old 07-23-2021, 04:33 AM #1
aaron_clt aaron_clt is offline
aaron_clt is on a distinguished road
Aux battery drain low voltage shutoff redarc bcdc
Looking for some suggestions on where problem lies... I installed the redarc bcdc1225d kit in my 2020 4runner about 3 weeks ago and this week started having issues with the low voltage cutoff tripping my switch pros sp9100 off. I have it connected to the my secondary Full Throttle 750-35g battery.
I took a multimeter to the these points :
Engine off:
Main battery: 12.57v
Aux battery: 10.82v
Redarc main battery wire to chassis ground (brown wire pre inline fuse): 12.56v
Engine On:
Main battery: 13.73v
Aux battery : 10.4v
Redarc main battery to chassis ground (brown wire pre inline fuse): 13.57v
Redarc aux battery wire to chassis ground (red wire pre-inline fuse): 13.23v
So it looks like there isn't much voltage loss from the redarc to the aux battery since the cables are hitting 12.5-13.5 volts. It just seems like it's not charging the full throttle battery...low amperage or voltage changes while driving maybe? Unfort my multimeter can only test up to 10amps so I didnt want to blow it testing the amperage.
Indicators LEDs on the redarc look normal and aren't throwing any faults. Any suggestions before I write it off as a bad battery and get a new one? I guess the full throttle is prob under warranty so I might need to initiate a claim through them.
Sent from my SM-G998U using Tapatalk
aaron_clt is offline   Reply With QuoteReply With Quote
Old 07-23-2021, 09:57 AM #2
RivMan's Avatar
RivMan RivMan is offline
RivMan has a spectacular aura about RivMan has a spectacular aura about
RivMan's Avatar
If you read 13.23v from the Redarc Aux battery feedline to chassis, and only 10.4v across the two posts of the aux battery, you likely have a bad aux battery ground wire or connection.
-Rob
2006 Sport V8 4x4 4Runner | Mods: ARB Front Bumper | Warn XD9000 Winch | Custom Sliders | ECGS 4.56 Gears | Eaton Truetrac rear | JBA UCA | SuperPro LCA | Icon 2.5 Front Coilovers | MetalTech Icon 2.0 Long Travel Rear Shocks | Dobinsons Long Travel Rear Springs | Energy Suspension Front Bumps | Durobump Rear Bumps | Falken WildPeak 285/70/17 | SCS F5 wheels | Custom Roof Rack | Gobi Ladder | OrangeBoxx Molle Panels | Icom IC-2730a HAM Radio | Rigid Ditch Lights | Custom Rear Drawers | 23Zero Walkabout 62 | ARB Awning | Dual Battery System | CVJ Axles | Victory 4x4 Rear Bumper with Dual Swingouts | Front Runner Table
RivMan is offline   Reply With QuoteReply With Quote
aux , battery , main , redarc , wire
Redarc BCDC Chargers 20% off at Autoanything sn_85 General Discussions 0 05-19-2020 10:07 AM
Redarc BCDC Chargers 20% off at Autoanything.com sn_85 General Discussions 0 05-19-2020 01:53 AM
Redarc BCDC Chargers 20% off at Autoanything.com sn_85 General Discussions 0 05-19-2020 01:33 AM
Redarc BCDC Chargers 20% off at Autoanything.com sn_85 General Discussions 0 05-19-2020 01:31 AM
Battery Voltage Help The Jc2203 3rd gen T4Rs 3 06-05-2015 07:09 PM
