Old 04-13-2021, 06:09 PM #16
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Originally Posted by Srt4runner View Post
I have an air compressor and bought a fluid film kit that has a spray gun with different nozzles. It works great for applying it. I've been using fluid film on my 5th gen since new in lovely salty illinois and don't have any rust. I do one thick coating in the fall when I put my winter wheels on. I would put down a large tarp and put it on jackstands. I just spray over what was on there before. I have no apparent rust and it seems to work great so I'm not sure going to something "better" is worth it. The fluid film does get coated in small rocks and dirt by the spring time. Works well enough for me.
How many gallons is your compressor tank?
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 04-14-2021, 09:47 PM #17
skag1T skag1T is offline
skag1T is on a distinguished road
I don't have an air compresson, but for a small-ish job like this i'm thinking a manual or electric sprayer, like a garden sprayer.
Did anybody use one ? I'm thinking fluid film or CRC might clog the sprayer.
I think it's worth a try.
skag1T is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 08:12 AM #18
empty403's Avatar
empty403 empty403 is offline
empty403 is on a distinguished road
empty403's Avatar
Originally Posted by skag1T View Post
Last year i undercoated my 4R with fluid film.
I used spray cans and it was really messy, the can nozzles were clogging up, etc. but i did the best i could and sprayed that stuff everywhere i could reach, including in every hole that I could see.
Now I did more research and it seems CRC 06026 Heavy Duty Corrosion Inhibitor could be a better product, at least it's a one time deal, to my understanding.
I am trying to avoid having to fluid film every year ....
So how do I spray CRC over fluid fild now ? Is it possible ? Last I checked underneath, it's all a bit oily but not too bad.
I don't have a lift and fluid film was a pain to apply, if CRC can be applied one time (2 coats and giving it 12 hours for each coat to cure) I would totally go for that.
Seattle area is not really bad for rust but I still want to overcoat my 4runner.
Any thoughts appreciated.
Yes, from the Project Farm test, the CRC HD is better. It’s also important to spray inside the frame using a 360 degree hose attachment. FYI, Fluid film will come off with a pressure washer. Fluid Film now has the black version which is better than their original. If available in your area, just go to an authorized NH Oil undercoating shop and do annual touch ups. If a shop, that does NH Oil or Fluid Film Black is available, remove the spare and skidplates and have your undercarriage steam cleaned before getting the oil based product installed. You can spray the skidplate yourself with CRC after you get home. FYI, oil based products will stay a bit wet/moist but that’s what makes them a better rust inhibitor.
2007 Limited V8 FT-4WD
4x4Labs front and rear bumpers, 4.56 Gears with Harrop E-Locker Front & Rear, Icon CVDC w/ 700lbs spring Ext C/Os & Icon MetalTech Long Travel rear CVDC with HD springs, SCS Ray10s with GY MTRs 305/70R17, Prinsu Rack, Rago MSP and ditch light brackets, Wheeler's Super bumpstops
2007 Toyota 4Runner Limited V8 160,000miles
http://www.toyota-4runner.org/4th-ge...-thread-2.html
empty403 is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 09:28 AM #19
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
I'm sure whichever one you choose will do the job great. I got FF done professionally this year to get the first coat done right with a sprayer, inside the frame with the 360 nozzle, etc. I will try myself this year and see how bad it is just using the cans. Regardless, will get it done every year. They say to drive down a dirt road after you get it done to build up that layer.
Only downside I've seen to FF is the smell for the first few drives and also after driving in the rain the first couple times the tailgate had a nice layer of FF on it.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 11:41 AM #20
Thank you for your input everybody !
Old 04-19-2021, 11:41 AM #21
Ok the garden spray version is definitely nort going to cut it. Pressure is way to low and it only last a few seconds, after which you have to pump again. Looks like I need a pretty good compresson if I want to go this route.
Srt4runner, what compressor do you use ?
Plan B is still the spray cans ...
Old 04-19-2021, 12:27 PM #22
Matt831 Matt831 is offline
Matt831 will become famous soon enough
Woolwax(R) "Pro" Undercoating Gun-wwprogun
Matt831 is offline   Reply With QuoteReply With Quote
bad , crc , film , fluid , time
Advice Needed - Rust, considering ditching 4R thejuice 5th gen T4Rs 38 10-09-2020 03:10 PM
Rust prevention other then Fluid film? Charlievee Maintenance/Detailing 11 04-28-2020 02:38 PM
Rust prevention - Is fluid film enough? BriAntic 5th gen T4Rs 4 04-02-2018 11:50 AM
A little fluid change advice needed. Blanco 3rd gen T4Rs 10 12-25-2011 10:53 AM
3M paint protection film bbates 4th Gen T4Rs 7 04-15-2004 07:08 PM
