Old 04-11-2021, 07:52 PM #1
skag1T skag1T is offline
skag1T is on a distinguished road
Rust protection advice needed - CRC over fluid film ?
Last year i undercoated my 4R with fluid film.
I used spray cans and it was really messy, the can nozzles were clogging up, etc. but i did the best i could and sprayed that stuff everywhere i could reach, including in every hole that I could see.
Now I did more research and it seems CRC 06026 Heavy Duty Corrosion Inhibitor could be a better product, at least it's a one time deal, to my understanding.
I am trying to avoid having to fluid film every year ....
So how do I spray CRC over fluid fild now ? Is it possible ? Last I checked underneath, it's all a bit oily but not too bad.
I don't have a lift and fluid film was a pain to apply, if CRC can be applied one time (2 coats and giving it 12 hours for each coat to cure) I would totally go for that.
Seattle area is not really bad for rust but I still want to overcoat my 4runner.
Any thoughts appreciated.
skag1T is offline   Reply With QuoteReply With Quote
Old 04-11-2021, 07:57 PM #2
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
Just pay a shop that does Fluid Film full time to do the job right. Take down your spare and skid plates and rinse off the undercarriage a few days early so its dry when you take it there.
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 04-11-2021, 10:07 PM #3
Srt4runner's Avatar
Srt4runner Srt4runner is offline
Srt4runner is on a distinguished road
Srt4runner's Avatar
I have an air compressor and bought a fluid film kit that has a spray gun with different nozzles. It works great for applying it. I've been using fluid film on my 5th gen since new in lovely salty illinois and don't have any rust. I do one thick coating in the fall when I put my winter wheels on. I would put down a large tarp and put it on jackstands. I just spray over what was on there before. I have no apparent rust and it seems to work great so I'm not sure going to something "better" is worth it. The fluid film does get coated in small rocks and dirt by the spring time. Works well enough for me.
2017 Limited 4x4, Stock
2001 SR5 4x4, Sonoran Steel 3.0 Lift
2004 Dodge Neon SRT-4, Lots o mods
Srt4runner is offline   Reply With QuoteReply With Quote
Old 04-11-2021, 10:36 PM #4
ruff4runner's Avatar
ruff4runner ruff4runner is offline
ruff4runner will become famous soon enough ruff4runner will become famous soon enough
Have you looked at 3m cavity wax plus? It's used at a lot of bodyshops when they do repairs and replace panels. They also sell a wand to get inside frames as well.
2019 TRD ORP with stuff bolted to it and my Alaskan Malamute benevolent overlord, Farley. KN6HZJ
ruff4runner is offline   Reply With QuoteReply With Quote
Old 04-12-2021, 02:42 AM #5
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
Check out Project Farm on youtube...he did a test on both the crc and fluid film...
Just search project farm rust.
As I recall the crc is cosmoline(sp?) ...same stuff they put on guns for super l ong term storage.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 04-12-2021, 02:44 AM #6
lewdog998's Avatar
lewdog998's Avatar
Nothing better than a freshly waxed cavity...
Old 04-12-2021, 10:28 AM #7
_JT_'s Avatar
_JT_ _JT_ is offline
_JT_ is on a distinguished road
_JT_'s Avatar
Now that's funny...
_JT_ is offline   Reply With QuoteReply With Quote
Old 04-12-2021, 11:26 AM #8
Srt4runner, do you clean the surfaces before you spray ? I'm thinking soap and water ? Or you just spray a new coat on top of the old one ?
I have a thin layer of grime on my underbody and it does not go away with water only.
Old 04-12-2021, 11:29 AM #9
I have watched that, and several more.
The appeal of CRC is that you only apply it once and that's it, no need to re-apply every year - as far as I understand.
Old 04-12-2021, 08:42 PM #10
Srt4runner's Avatar
Srt4runner's Avatar
I've been just applying over everything every year. I figured having a coating of grime is better than a coating of rust. Keep in mind my 4runner is 95% on road. If I had layers of thick mud from off roading I would probably try to wash most of it off first.
Old 04-12-2021, 09:45 PM #11
I highly recommend the wand.
Old 04-13-2021, 07:38 AM #12
BigGy's Avatar
BigGy BigGy is offline
BigGy will become famous soon enough
BigGy's Avatar
Did cosmoline (RP342) and am very happy with the results. Cosmoline dries, fluid film, woolwax, etc, stays wet. YMMV, of course.
2021 TRD Pro
BigGy is offline   Reply With QuoteReply With Quote
Old 04-13-2021, 11:07 AM #13
Back to my original question:
- can I apply CRC over fluid film ? I have not found any instructions on what is the surface requirement for applying CRC.
Old 04-13-2021, 11:30 AM #14
SlickTRD SlickTRD is offline
SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about
i think you can apply it over fluid film but if you want best results it will probably work better on a clean surface. so really its up to you to decide how much effort you want to put into this.
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
SlickTRD is offline   Reply With QuoteReply With Quote
Old 04-13-2021, 05:41 PM #15
Mr_Bingley Mr_Bingley is offline
Mr_Bingley will become famous soon enough
Mr_Bingley is offline   Reply With QuoteReply With Quote
bad , crc , film , fluid , time
Advice Needed - Rust, considering ditching 4R thejuice 5th gen T4Rs 38 10-09-2020 03:10 PM
Rust prevention other then Fluid film? Charlievee Maintenance/Detailing 11 04-28-2020 02:38 PM
Rust prevention - Is fluid film enough? BriAntic 5th gen T4Rs 4 04-02-2018 11:50 AM
A little fluid change advice needed. Blanco 3rd gen T4Rs 10 12-25-2011 10:53 AM
3M paint protection film bbates 4th Gen T4Rs 7 04-15-2004 07:08 PM
