Old 05-04-2021, 04:20 PM #16
Shuutr Shuutr is offline
Shuutr is on a distinguished road
It seems to have worked. No shake at 60 on the way home. Cheers
Shuutr is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 07:37 PM #17
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
Originally Posted by CajunMikeR View Post
Mine had a slight vibration at 55-60mph while stock (with TRD Pro wheels and 265/70 Nitto Terra Grapplers). Very slight, just enough to feel it in the steering wheel, then after that speed it smoothed back out.
After my lift & new UCAs, putting on FN f(x) Pros & 285/70 Nitto Ridge Grapplers, EimKeith PCK, and having the alignment done (with 4.5 on the caster on both sides)... there is no vibration, shimmy, shake, or whatever at any speed. It actually rides better, more controlled, and smoother than it ever did stock.
Positive caster helps in the same way people say Mercedes has that on-center feel.
Did it resolve the tendency for the 4Runner to feel like it’s pulling right despite “perfect” alignment numbers (according to the dealer)?
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 07:42 PM #18
BorotHex BorotHex is offline
BorotHex has a spectacular aura about BorotHex has a spectacular aura about
I’ve had Discount Tire attempt to balance three sets of tires a total of 8 times. All three times in various places around the US. Doesn’t matter what tires, where you go, etc, Discount Tire cannot balance tires to save their lives. Tire balancing has gotten much, much worse since these fancy machines came along. Now I hate getting tires because I know they will ride like shit no matter what brand or tire if I have to buy them at Discount.
BorotHex is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 09:25 AM #19
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
So, my shakes are still there (I'm the OP), but they kind of come and go.
Whenever the truck sits for more than a day, they seem worse. If I drive it consistently, they are better or go away.
I was wheelin' for two days straight last weekend and after hitting pavement two days later the shakes were nearly gone. Who knows, maybe the carcass really needed to be 'massaged' given mine sits a lot as I work from home.
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 10:14 AM #20
the_economist's Avatar
the_economist the_economist is offline
the_economist will become famous soon enough
This is some great intel — thank you for documenting OP!
2016 4Runner SR5 4x4. BFG A/T K02s (275/70/17 E Rated). 2-inch Icon rear springs. Bilstein 6112s front (1.2" setting), 5160s rear. RCI skid plates package + gas tank (3/8 in. steel), RCI rock sliders. Warn semi-hidden winch mount + Warn Zeon 10-S Platinum winch. Raingler cargo nets (roof and rear). TRD wheels. LFD rooftop crossbars.
the_economist is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 10:29 AM #21
What I’ve collected so far:
1.) Control arm bushings are extremely soft, users reported improvement after replacing with firmer material (Polybush, etc.).
2.) Alignment spec is great for low-speed and bump-forgiving, not highway comfort oriented. That’s why they benefit if you can get a little bit of positive caster in there. (Fixes the “pulling right” on road crown without compensating in a way that would cause it to pull left on a flat surface).
3.) Stock tires are only 245/60R20 on platinums. Thinner tires get squirrelly at higher speeds. Wider tires are just starting to wake up. Trade off is wide (especially flat, lower profiles) will “grab” and pull into every pothole at lower speeds.
Engineers were definitely “going” for something when they designed this, but a 60-80 MPH road warrior was not what was dialed in. Fortunately, it’s customizable to be better at this.
Old 05-10-2021, 10:34 AM #22
Like the OP said, it comes and goes. The more I drive, the less it comes.
Old 05-10-2021, 02:48 PM #23
My theory is that the belts take a while to 'round out' after sitting and flat-spotting. It sounds a bit much, but in my experience, it can take 50+ miles in some cases for it to smooth out after sitting for a week.
At the end, it tall boils down to the steering geometry and the design particulars, which give a lot of feedback into the steering wheel. I can live with the shakes as long as they are more low low vibes rather than outright shakes. I've grown to accept it now.
make , shakes , shop , steering , work
Steering Wheel Shakes and Pulling to the right. Ogbassist182 4th Gen T4Rs 5 04-06-2016 10:16 AM
Braking shakes steering wheel II JCDM 4th Gen T4Rs 2 09-01-2014 02:37 PM
Braking shakes steering wheel? Silvergrowler 4th Gen T4Rs 16 08-30-2014 03:42 PM
Help diagnosing steering vibration and shakes redkaz04 4th Gen T4Rs 14 07-20-2014 03:27 PM
Steering Shakes at 60-65 MPH Nitro_Rabbit Problems & Warranty Issues 16 11-07-2011 09:36 AM
