Old 04-20-2021, 12:39 PM #16
Gouranga Gouranga is offline
Gouranga is on a distinguished road
Originally Posted by CutthroatSlam View Post
My money says you will be back with the same steering wheel shake complaint on a windless day.
time to pay up boyo like i said its the wind
i was driving 500km from ottawa to toronto the other day
each time im on open highway shakes a lil when high wind soon as i go through trees on both sides of the highway shaking stops and soon as i come out and wind the shakes starts
its the shitty stock tires Bridgestone Dueler H/T 684
because the edges on then are really narrow and soft so when wind pushes left and right starts to tilt you side to side while going highway speeds the rubber basically softens up on the edges cuz of the rebound effect of weight side to sid causing the streering to turn left and right ever so slightly hence feeling the stterring wheel slighht move from left to right over and over
now pay up
Gouranga is offline   Reply With QuoteReply With Quote
Old 04-20-2021, 12:50 PM #17
repo repo is offline
repo has a spectacular aura about repo has a spectacular aura about
Welcome to the thrills of driving a giant brick with factory sloppy steering in windy conditions.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 04-20-2021, 01:47 PM #18
well thats exactly what i expected but people keep trying to blame the tires instead of the obvious lol
Old 04-20-2021, 02:19 PM #19
Well to be fair vibrations and shimmys usually do come from unbalanced tires and I suspect it would exaggerate the wind effect. Playing around with different tire pressures can help. I notice it less with heavy E-rated tires. There's probably all kinds of factors like how much weight is in the back, sway bars, panhard bar, lift height creating more updraft, suspension stiffness, etc that amplifies it. On my 3rd gen I actually changed the steering rack guide/spring/torque to tighten up the steering a bit and it feels like a BMW now compared to the 5th gen. In fact I much prefer driving the 3rd gen from how it handles. Also have poly rack bushings. I wouldn't screw with it on a new one though.
99 SR5 v6 4WD
11 SR5 v6 4WD
Old 04-20-2021, 03:52 PM #20
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
Actually, tire shake is not as simple as it seems. Yes, balance is often key, but how much of that imbalance is felt by the driver -- that's where it gets more complex. Suspension design including geometry, bushings, materials, etc., all of that comes into play. You also have external factors because no tire is naturally perfectly round or perfectly balanced. There is also air pressure in the tire and conditions of the road. Road imperfections can make the assembly hit just the right resonance of vibration where vibration increases and is felt by the driver.
Wind, however, is a far smaller force when you're talking about all of those above, but it's plausible, I suppose. I'm not necessarily disagreeing with you, but I still have my doubts based on personal experience.
But overall, because there are so many factors, is why no one has defined the one single solution to the highway vibes.
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 04-20-2021, 04:02 PM #21
yes but none of those are related to me .. i started this thread saying this is a brand new stock venture (with the large roofrack and i suspected its the wind from the start .but didnt drive it long enough to know for sure until the other day.
Old 04-21-2021, 11:07 AM #22
CutthroatSlam CutthroatSlam is offline
CutthroatSlam has a spectacular aura about CutthroatSlam has a spectacular aura about CutthroatSlam has a spectacular aura about
now pay up
Happy you solved your problem. That's my payment.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 04-21-2021, 02:39 PM #23
Rpede Rpede is offline
Rpede is on a distinguished road
“Road imperfections can make the assembly hit just the right resonance of vibration where vibration increases and is felt by the driver.”
So very true! Mine will do some shaking and I thought it was the tires, suspension or wheels. I finally realized the same patch of road heading to and from work is when this would happen. Based on the feel I could never imagine a smooth looking road could cause this problem but it certainly did! Took me awhile to figure this out and I was digging into everything but the road surface.
Rpede is offline   Reply With QuoteReply With Quote
Old 04-21-2021, 03:07 PM #24
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
Make sure the dealer is using adaptor plate to balance
2015 4runner Limited
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 04-21-2021, 06:28 PM #25
Iron_Will Iron_Will is offline
Iron_Will is on a distinguished road
Hope you get it fixed. That's the ultimate nightmare with a new vehicle is having problems out of the gate
Iron_Will is offline   Reply With QuoteReply With Quote
Old 04-22-2021, 01:06 PM #26
MAD 69's Avatar
MAD 69 MAD 69 is offline
MAD 69 is on a distinguished road
MAD 69's Avatar
This happened to me while driving thru Alabama - it wound up being mud in the tires, that's right mud in the tires....
98 T4R SR5 V6 4x4
21 T4R TRD OR Premium
MAD 69 is offline   Reply With QuoteReply With Quote
Old 04-23-2021, 12:41 AM #27
4RFritz 4RFritz is offline
4RFritz is on a distinguished road
A buddy had me try this and it worked. Unplug the battery for ten seconds and it resets some sort of steering angle and yaw sensor. It worked for me with the exact same issue.
Take note that I have no further proof or details, but it did work for me.
4RFritz is offline   Reply With QuoteReply With Quote
lil , steering , tires , wheel , wind
Steering Wheel Shakes and Pulling to the right. Ogbassist182 4th Gen T4Rs 5 04-06-2016 10:16 AM
Rotated tires-now pulls to side and steering wheel shakes MidwestJ 5th gen T4Rs 2 09-21-2015 02:48 PM
Braking shakes steering wheel II JCDM 4th Gen T4Rs 2 09-01-2014 02:37 PM
Braking shakes steering wheel? Silvergrowler 4th Gen T4Rs 16 08-30-2014 03:42 PM
Got a little cavalier in my off road exploits now my steering wheel shakes.... SupraRacer 4th Gen T4Rs 12 02-20-2007 05:36 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
