Old 04-14-2021, 09:00 AM #1
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
Roof rack option for Kayak mounts with wide cross bars
Recently bought a kayak and I'm looking for mounting options. I have after market roof bars on my 4R from Artec industries, see pics below.
The rack rails are 5 inches across with about 3/4 inch clearance underneath..any recommendation on a mount that will work with this set, I can't seem to find anything and I'm sure there's got to be something out there..Thanks.
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 04-14-2021, 09:48 AM #2
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Check out either Thule or Yakima web sites. Both have kayak mounting hardware.
fkheath is offline   Reply With QuoteReply With Quote
Old 04-14-2021, 09:57 AM #3
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
I've looked but didn't really see anything that will work with these cross bars..it would pretty much require me to buy another set of bars which I'd really like to avoid if possible.
Old 04-14-2021, 09:57 AM #4
jetmechG550 jetmechG550 is offline
jetmechG550 is on a distinguished road
Just one kayak? With that little clearance under the bar you're probably going to need one that the yak just lays flat like you would transport a SUP or canoe but then you may run into issues opening the rear tailgate with a kayak on top. If you are looking for upright versions, most wrap around the bars someway or another. Although the Malone is kind of an older style that has bolts that go through a top plate and a plate that goes under the bar. You may be able to use just the top plate and cut the bolts to length and line up with those slots on your crossbars?
jetmechG550 is offline   Reply With QuoteReply With Quote
Old 04-14-2021, 10:40 AM #5
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
yeah, just a single..you're right, the clearance under the bar is an issue..when I brought it home, with the kayak flat on the rack, the back wouldn't open, but I could always just drop the window. I'd like to be able use one of those j-cradle style mounts if possible..maybe I can fab something up to use as a base mount for the rack..
Old 04-14-2021, 08:17 PM #6
I will try and get a picture of my Malone J cradle to help explain what I mean by how they mount around the crossbar. I have a Yakima that I love and can mount two Kayaks on but you don't have enough clearance for it. I'm anxiously waiting my new roof rack so I can carry all three of my yaks
Old 04-14-2021, 09:02 PM #7
zcruiser's Avatar
zcruiser zcruiser is offline
zcruiser has a spectacular aura about zcruiser has a spectacular aura about
zcruiser's Avatar
2012 4Runner Limited, Shoreline Blue Pearl / Beige leather, RCI skid, ext rear diff breather, Derale 13504 cooler, 110K
1993 300ZX Cherry Red Pearl with some bling, K&N intake, PowerTrix suspension, 130K
zcruiser is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 07:04 AM #8
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
Thanks..I'm curious to see what it looks like mounted up close..maybe it will work..I'll never get to the point where I'm hauling 3, maybe 2 but that would be it..
Old 04-15-2021, 07:05 AM #9
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
Originally Posted by zcruiser View Post
that's one hell of a contraption..
Old 04-15-2021, 07:56 AM #10
hunthorde hunthorde is offline
hunthorde is on a distinguished road
I have a new Venture with the Yakima Megawarrior on top. In your opinion, is anything else needed to mount a kayak up top? Should I just lay it on top and strap it down, or would I need something additional up top?
hunthorde is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 10:35 AM #11
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Any pics with kayaks? Perhaps paint it black :-)
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 10:48 AM #12
Big Daddy K's Avatar
Big Daddy K Big Daddy K is offline
Real Name: Kevin
Big Daddy K will become famous soon enough Big Daddy K will become famous soon enough
Real Name: Kevin
Check out something like a Yakima Jay Hook that has 2 bolts that go down to a lower flat bar. You may get lucky on your hole spacing and it match up but more than likely you should be able to modify a hole or the lower mount to work. Many of the J cradle types have inline bolts that attach them to the mounts. You may be able to take off the mount and screw the cradle directly to you rack.
2016 Trail Edition Supa Dupa White
Dobinson's IMS lift, SPC UCAs, 285/70R17 Yokohama X-AT tires on Icon Rebound wheels, RCI Sliders and Skid Plates, Prinsu full length rack, C4 Fabrication rear bumper and fuel tank skid, and BPF molle panels.
Big Daddy K is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 04:12 PM #13
zcruiser's Avatar
zcruiser's Avatar
Sorry, I don't. They fit side-by-side, cockpits down. Black paint would just get chipped off and look worse.
Old 04-21-2021, 02:57 PM #14
JAXJeremy's Avatar
Real Name: Jeremy
JAXJeremy's Avatar
Real Name: Jeremy
Curious whether anyone is using a loader like this one for their kayaks..bought it because of the reviews, but now looking at the way it mounts on the rear window, I'm not sure it's going to work..that rear trim piece looks like it still might hit the bottom of the kayak..
[IMG][/IMG]
guess I need to take the kayak down and find out..
clearance , kayak , rack , roof , set
FS T4R kayak roof rack attachments 75$ Central MA Philbush1127 For Sale: T4R Items 2 05-20-2020 04:16 PM
Kayak on stock roof rack Timjtitus 3rd gen T4Rs 5 08-02-2017 09:35 PM
Kayak Roof Rack raxel 5th gen T4Rs 3 09-23-2016 05:04 PM
Long Kayak Transport On Roof Rack writchie 5th gen T4Rs 17 04-28-2013 09:08 PM
Kayak on roof with no roof rack? kylebacc Engines / Suspension / Wheels / Tires / Audio / Accessories 4 06-10-2011 02:41 AM
