Old 04-14-2021, 04:42 PM #1
Röde Orm's Avatar
Röde Orm Röde Orm is offline
Röde Orm is on a distinguished road
Röde Orm's Avatar
Power outlet - cargo area
Hello
Have anyone replaced this part before?. Picked this truck up. And it has a broken power outlet.
Thanks for any input.
Power outlet - cargo area-3050f414-6a2b-4f21-a05e-67c406fbec50-jpeg
2016 4R- LMT MG RW , ODX-AGM34R, H11 AND 9005 XTREME LED PRO, Pedal Commander, Baja Squadron SAE, W/T mats, TRD pro wheels, TOYO OPEN COUNTRY A/T III
265-70/17,
Röde Orm is offline   Reply With QuoteReply With Quote
Old 04-14-2021, 05:27 PM #2
Tieyota Tieyota is offline
Tieyota is on a distinguished road
Are you looking for the part number? If so, the outlet should be 85530-35050-C0
Tieyota is offline   Reply With QuoteReply With Quote
Old 04-14-2021, 10:01 PM #3
Röde Orm's Avatar
Röde Orm's Avatar
Thanks for that. Well now with the part number I could find a pic. And it looks like it’s just a couple of pesky tabs.
Trying to figure out how to get the old one out without breaking anything. ��
Thanks again.
265-70/17,
Old 04-15-2021, 11:37 AM #4
numbay numbay is offline
numbay will become famous soon enough
Thanks again.
TOYOTA 4RUNNER POWER VOLTAGE INVERTER OEM 2010 - 2019 W/ Panel And Plugs | eBay
look at pictures there in that post
numbay is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 02:35 PM #5
Rack Rack is offline
Rack has a spectacular aura about Rack has a spectacular aura about
You should remove the tray on top, there is a tab on the bottom of the receptacle, pull up on this and the whole assembly comes out.
Go to my album pages and click on the one that has adding the constant hot plug to the storage area. I have a pictorial of how to remove the tray and gain access to the plug. Removing the tray is the hard part.
signature not available
Rack is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 06:53 PM #6
ttime4four ttime4four is offline
ttime4four will become famous soon enough
If I recall, you can pry our the bottom edge and remove the plug assy by itself. Remove and reconnect the two connectors to the new plug assy and re-insert.
2021 SuperWhite ORP
Ironman FCP / WildPeak 285/70R17 / Sherpa Crestone / Autohome Columbus / OVS 180 Awn / C4 Slider / WD Ladder / OEM Audio+ / Rago Aux Battery with Redarc Charger / Trigger 4 / Husky Mats / Sequential Turn Signals / DD Pro Fogs / Ridgid Ditch Lights / Raptor Lights / EVO Corse DakarZero / Rockblokz Mud Flaps / Blackout Kit / TRD Pro Grill / C4 LoPro Bumper / Superwinch / Anytime Backup Camera / Canvasback / Rago Molle and Shelf
ttime4four is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 10:10 PM #7
Röde Orm's Avatar
Röde Orm's Avatar
Removal
Thanks for the help!
I found out through the eBay picture. There is what it looks like 6 pesky tabs on this.
Or just 2 on the socket assembly itself.
Shouldn’t be able to break to much. ��
Power outlet - cargo area-95d59dca-52dd-4128-a127-d1104029ca86-png
265-70/17,
Old 04-23-2021, 01:08 PM #8
Röde Orm's Avatar
Röde Orm's Avatar
Solved
Well the stealership finally got the part in. So I took the old one out and installed the new socket.
Came out easy and yes no problems at all.
Thanks for all the help.
Power outlet - cargo area-7ca46fd5-99dc-467d-95fb-fb5c9441f51e-jpeg  Power outlet - cargo area-9a7232c7-39ba-4194-b175-6e0ee4501b07-jpeg  Power outlet - cargo area-1752a6ff-0095-48c7-b0db-bb2d33b2a095-jpeg
265-70/17,
Old 04-23-2021, 01:46 PM #9
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
Nice work @Röde Orm
Did you end up taking out the top tray as well, or did you manage to do this by just taking out the plastic insert that holds the plug?
And how hard was it to take out the plastic insert that holds the plug? That may actually be a better way to run wiring through that area if it's fairly straightforward (which the top tray is not).
Thanks!
rageandlove is offline   Reply With QuoteReply With Quote
Old 04-25-2021, 12:12 PM #10
Röde Orm's Avatar
Röde Orm's Avatar
Originally Posted by rageandlove View Post
Nice work @Röde Orm
Thanks!
Hello
I just removed the whole tray. It came out with ease. Now that plug has 2 tabs on either side. And as I was removing the old one. One of the tabs broke off. They are really hard plastic. And kind of brittle.
Easiest is to remove the whole tray.
265-70/17,
Old 04-25-2021, 02:03 PM #11
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
Nice work @Röde Orm
Thanks!
It's pretty easy to take out the electrical panel. Just a few tabs on both sides using a trim tool. After you take it off you can slip your hand into the opening and use a stubby philips head to undo the two screws on the top tray and simply pop it off. I did this to run wires under the wheel well area. FWIW I put the tray back on but did not screw it back in if I ever needed to access it again. It doesn't rattle or make any noises unscrewed.
Now the driver side top tray that's an entirely different question. I think if you wanted to remove the top tray without breaking tabs you have to remove that entire side cargo panel. If I ever have to remove that entire panel I'll be sure to remove those two screws holding the top tray.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
broken , outlet , picked , power , truck
Cargo Power Outlet Usage Question alext72888 5th gen T4Rs 12 09-26-2019 11:53 AM
No power to 12v in rear cargo area BikeDestroyer 3rd gen T4Rs 5 06-17-2019 01:52 PM
Questions about the inverter/power outlet in the cargo space... acolle 5th gen T4Rs 9 01-02-2017 01:47 PM
FS 3rd Gen Cargo Area 12V Outlet and Trim Tan/Oak FL $20 Troybylt For Sale: T4R Items 0 10-26-2016 06:14 PM
Cargo area aux power cover drto9999 4th Gen T4Rs 1 02-09-2014 07:41 PM
