Old 04-15-2021, 05:58 PM #1
TheJokingExplorer TheJokingExplorer is offline
TheJokingExplorer will become famous soon enough
Prinsu install
Hey everyone is talking my full length prinsu. When installing the side rails I noticed they don’t sit straight up and are slanted. Is this i normal? No matter how I move the rail it’s still slanted which I think would make it difficult to mount the cross bars. Below I attached a photo not sure if you can see the slant or not.
TheJokingExplorer is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 06:19 PM #2
Old Tanker Old Tanker is offline
Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about
That doesn't look right - sure you didn't put the right side mound on the left side?
Old Tanker is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 06:24 PM #3
Theres no way. Each side bar can only go on one way otherwise the brackets will face outward instead of in?
Old 04-15-2021, 06:28 PM #4
NotaTRD's Avatar
NotaTRD NotaTRD is offline
NotaTRD will become famous soon enough NotaTRD will become famous soon enough
NotaTRD's Avatar
Can we get more pictures of the mounting point?
2017 SW SR5
NotaTRD is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 06:36 PM #5
Old 04-15-2021, 06:56 PM #6
NotaTRD's Avatar
NotaTRD's Avatar
Sorry, I meant with the prinsu mounting bracket and side rail attached as you had it in the pictures you have in your original post.
2017 SW SR5
Old 04-15-2021, 06:58 PM #7
Oh bummer I took the side rail off. The bracket is flush with the spacers. At first I thought I just need to adjust the rail so the boots would be in the middle of the bracket but that just made it worse.
Old 04-15-2021, 07:12 PM #8
NotaTRD's Avatar
NotaTRD's Avatar
I don’t have a prinsu, but all the install vids I just watched have them building the rack first on the ground then putting it on top. Maybe attaching the crossbars and tightening them bring the side rails in more and straightens them up?
2017 SW SR5
Old 04-15-2021, 07:29 PM #9
I suppose I could try that and see what happens.
Old 04-15-2021, 09:54 PM #10
arehman11 arehman11 is offline
arehman11 has a spectacular aura about arehman11 has a spectacular aura about
This is common, install both rails, then install the crossbars to square things up and make sure everything is all lined up, once you have done that, install the legs that are held on by 3m tape. Once it’s all together the rack is solid.
2017 MGM TRD Off Road Premium
arehman11 is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 10:46 PM #11
Gotcha! Thanks
Old 04-16-2021, 08:56 AM #12
danyo492's Avatar
danyo492 danyo492 is offline
danyo492 is on a distinguished road
danyo492's Avatar
Mine looked like that too before I installed the cross bars. The cross bars help pull everything all together. It's still a pretty crappy design for the mounting since all the weight is on those little spacers.
danyo492 is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 11:26 AM #13
T4R_Canuck T4R_Canuck is offline
T4R_Canuck has a spectacular aura about T4R_Canuck has a spectacular aura about
I'm fairly confident mine looked like that during my install as well, its been a few months sorry.
I installed the 4 main bolts per side loosely, just enough to keep the spacers from falling out, then installed a bunch of cross rails to pull everything together. Then I doubled checked that the rack was square and in the centre before removing 1 mounting bolt at a time and filling it with silicone sealant and tightening it down to spec.
Once all of the bolts were tightened, I rechecked centre/squareness and installed the 2 front 3M tabs. I let the tabs adhesive stick overnight with a bunch of boxes on the front of the rack to hold the 3M in place.
2014 Trail Premium w/ KDSS. OME 3" Lift w/ medium springs, Greenlane Diff Drop, SPC UCA, LT285/70R17 Falken Wildpeak AT3W E Load, Level 8 MK6 17" x 8, 0 offset, Element by RA Automotive Engine Skid, Prinsu Full Length No Drill Rack, ICS Dash mount.
T4R_Canuck is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 10:02 PM #14
Solid! This is exactly what I will do. Thanks for the info.
attached , bars , cross , prinsu , slanted
Have Prinsu, need cargo box.... MrH4RTRDPro 5th gen T4Rs 1 01-03-2021 06:20 PM
Prinsu roof rack install climone 4th Gen T4Rs 12 11-25-2020 10:00 AM
is a prinsu rack easy to install? bradze 5th gen T4Rs 1 03-02-2019 09:46 PM
Prinsu Rack Install bearisasquare 4th Gen T4Rs 6 12-26-2018 03:51 PM
Prinsu and LED light bar Chilow 5th gen T4Rs 0 04-03-2018 10:47 AM
