Old 04-15-2021, 11:08 PM #1
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is offline
GX4SEVEND has a spectacular aura about GX4SEVEND has a spectacular aura about
GX4SEVEND's Avatar
Factory JBL box with JL 8w3
Just installed it and it sounds amazing. Running off a Rockford prime amp giving it about 300 watts. Put two lays of sound deadening behind the box.
The box comes from Toyota with the factory sub. Toyota lists it as only 2017-2020 I believe but it fits mine perfectly and Iíve got a 2014 SR5.
Also running the focal fronts with power bass rears. Using the factory deck but an Audio Control LCQ-1 and its way beyond what I expected. The focals are pointless in my opinion with out being amped. Using a JL amp giving 75x4 and its perfect
For anyone looking at upgrading the factory sub or adding one but want to keep cargo space this is the perfect mod. Worth every penny
Ď14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinsonís 3Ē Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8ís w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 11:32 PM #2
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a name known to all daytonaviolet is a name known to all daytonaviolet is a name known to all daytonaviolet is a name known to all daytonaviolet is a name known to all daytonaviolet is a name known to all
Is the amp only for the sub or all the speakers? Did you install the bass knob too ?
I ran focals and jbl subs back In the day. They are awesome. I wonder how your setup would sound with the T10 HU ?
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 04-15-2021, 11:38 PM #3
Dude Dude is offline
Dude is on a distinguished road
How does this get trimmed out in a SR5? I have a 2015 TEP with cubby hole area and would gladly give up the space for this sub+enclosure. I am just unclear if you also have to swap out the trim panel.
Dude is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 12:28 AM #4
GX4SEVEND's Avatar
GX4SEVEND's Avatar
I used two separate amps. Then used the audio control line out converter. The bass knob I already had before I added the amp for the door speakers and line out
The focal sound 10 times better amped vs just deck power. The line out has a built in EQ so between that and the factory deck thereís a ton of room for making it sound perfect.
My SR5 has a third row and the holes for the box are already pre drilled. I literally just bolted it in. Super easy
Forgot to add........the panel with the cubby is the exact one I have. You literally just remove the cubby. Thereís clips on the back side of it.
Ď14 SR5 in white
Full RCI skids
Old 04-16-2021, 10:12 AM #5
I donít have a third row... so I am guessing this is not an option. I am running Focals flax series in the doors and have the rear hatch omitted. Ran off the OEM headunit and then upgraded to a T9. Sounded much better with the EQ control and extra power.
Just got a T10 dropped at my door an hour ago and going to install it with a amp. Just trying to decide if I am going to need additional DSP control outside the headunit and how to handle the sub. Really wish I could do a stealthy install like this one.
Old 04-16-2021, 10:28 AM #6
97BlackAckCL's Avatar
Real Name: Chris
97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of 97BlackAckCL has much to be proud of
Real Name: Chris
I detailed all of this in my DIY threads which OP referenced for his install
Third row seat removal to access rear panel pocket, subwoofer install
2017 Nautical Blue SR5 Premium - Black Emblems, AFE TB Spacer, AFE Momentum GT Intake, URD MAF Calibrator, Borla Touring Cat-Back Exhaust, RCI Skid Plate, Morimoto MLED 2.0 Headlight Retrofit, Morimoto LED Fogs, Eagle Eye Smoked Black Tail Lights, FyreFlys LED Interior, Meso Puddle Lights, Tinted Mirror Turn Signals, Smoked Amber Raptor Lights, Odyssey 34 Battery, 32" LED Bar with Rago Hidden Brackets, Rago Molle Panels, Side Shooter LED Ditch Lights, sPod w/ PowerTray, Raceline Matte Bronze Wheels w/ Cooper Discoverer RTX, CaliRaised Rock Sliders, BajaRack Full Length Roof Rack, Alpine Halo9, Infinity Kappa Door Speakers, JBL 3.5's in dash, JL 8w3v3 in JBL Enclosure, Husky Weather Beaters, CanvasBack Liners, Blackvue DR900S Dash Cams
Old 04-16-2021, 02:40 PM #7
Real Name: Chris
Real Name: Chris
There's a couple options for your setup depending on what size sub and enclosure you're looking to do.
Here's a couple options
2010-2018 Toyota 4Runner Custom Phantom Fit Subwoofer Enclosure
Toyota 4Runner Subwoofer Box Ported Fiberglass 12 inch - Taco Tunes - Toyota Audio Solutions
Old 04-23-2021, 06:04 PM #8
llDemonll llDemonll is offline
llDemonll is just really nice llDemonll is just really nice llDemonll is just really nice llDemonll is just really nice llDemonll is just really nice
Is this the part number that you purchased: 86150-35080
llDemonll is offline   Reply With QuoteReply With Quote
box , factory , giving , perfect , toyota
Fs: Factory toyota workshop manual(1994-vol.2)& factory wiring diagram(1992&1994)-ca Clockworkmotors714 For Sale: T4R Items 0 11-09-2019 11:26 AM
Factory to Factory stereo upgrade help (JBL Owners) MoJoe Engines / Suspension / Wheels / Tires / Audio / Accessories 30 12-11-2015 10:48 AM
3rd Gen - Factory Diff Lock Button / Factory Clock fire931 For Sale: T4R Items 2 05-08-2012 11:53 PM
Factory backspacing on 4runner factory wheels Veritas 4th Gen T4Rs 0 11-15-2011 02:13 PM
Factory Keyless on Non Factory Installed SR5? slampe 3rd gen T4Rs 3 12-13-2010 09:45 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
