Old 04-15-2021, 11:45 PM #1
edizzle edizzle is offline
edizzle is on a distinguished road
2021 Head Unit Replacement
Just bought a 21 SR5 Premium XP. I was excited to start ordering a replacement head unit. I have had my eye on the Alpine or Pioneer floating display units. I have watched several videos of the installation in prior year models. I went to Crutchfield to look at install kits, harnesses, etc. and they have nothing listed. Metra doesnt have anything either.
Does anyone have any info on whether previous year install kits and harnesses will fit?
edizzle is offline   Reply With QuoteReply With Quote
Old 04-18-2021, 07:44 AM #2
Following up. Anyone have any info?
Old 04-18-2021, 09:26 AM #3
firepilot firepilot is offline
Real Name: Phil
firepilot is on a distinguished road
Real Name: Phil
I just installed a Kenwood in my 2020 Off Road Premium and found the same thing. I used the Metra kit which was ok. I have the Schosche kit as well and just need the time to paint it. In my opinion the Schosche is going to be a better fit but only comes in silver. The Metro kit matches perfectly but doesn't mount as well.
They do fit, but are not listed. I also used the Maestro Idata link and it worked perfectly. It is confusing because when you compare the factory harness to the Maestro RT03 the factory harness has more plugs.
The Maestro didn't use them all which was confusing but it does work.
2020 TRD Off Road Premium
firepilot is offline   Reply With QuoteReply With Quote
Old 04-18-2021, 12:23 PM #4
21TOR 21TOR is offline
21TOR is on a distinguished road
I wanted to change the head unit on our 2021 ORP and could not find any wiring that matched up, so I kept the head unit went with an AMP and DSP as I am very electronic/tech challenged.
21TOR is offline   Reply With QuoteReply With Quote
Old 04-18-2021, 12:38 PM #5
Yes that’s what I am finding. There is absolutely nothing listed for a 21. Which scares me a little bit. Was there anything different between a 20 and a 21? I know they look similar was there anything functionally different between the head Units for each year? I guess my concern would be the wiring harnesses. The fact that there is nothing listed makes me think that the 21 is different. If it was the same I’m sure Metra and Scosche would have one listed.
Ultimately I guess I wouldn’t mind doing a factory audio interface as I know there are many really good ones out there. I have access to audio control and JL audio equipment. I will be using a DSC either way. I wanted a new unit for the performance, update ability, clean 4v+ outputs, etc.
Old 04-18-2021, 01:49 PM #6
I went with the tacotunes plug and play harness which uses the factory speaker wires. While changing my speakers and looking at the truck the thought of running new speaker wire looks like a real pain.
Went with an Audio Control DSP-610 and a cheap AMP. Waiting on my harness still to put it all together.
Much rather had a new head unit but maybe in a few years once products start coming out for the newer 4runners.
Old 04-18-2021, 02:23 PM #7
have you confirmed the harness is different between 2020 and 2021 models? or are you just basing this off of the fact no one has a harness out yet? Im just trying to get a definitive answer on whether or not the stock head units and harnesses are or are not the same.
Old 04-18-2021, 06:09 PM #8
have you confirmed the harness is different between 2020 and 2021 models? NO or are you just basing this off of the fact no one has a harness out yet? Yes Im just trying to get a definitive answer on whether or not the stock head units and harnesses are or are not the same.
Had no choice but to try it, worse case is send it back and chop wiring.
Same with my shock/springs...even Bilstein would not confirm fitment......if they ever show up Ill see.
Old 04-18-2021, 06:16 PM #9
Skidmarcx's Avatar
Skidmarcx Skidmarcx is offline
Skidmarcx will become famous soon enough
Skidmarcx's Avatar
I can tell you that the Alpine Halo unit is not plug n play for 2020, just went through that and unfortunately returned the unit, I’m sure you’ll run into the same on a 21
97 Limited 4x2 ---> 4x4 (SOLD)
SS 1.3 | ToyTec | RadFlo | Aussie | SOR | AOR | CBI | DC Power | Rigid | Alpine | Audison | JL Audio | Second Skin
King | BFG | Rago | AudioControl | AudioFrog | JL Audio | Dynamat
Skidmarcx is offline   Reply With QuoteReply With Quote
Old 04-18-2021, 07:31 PM #10
Cheers!'s Avatar
Cheers! Cheers! is offline
Cheers! will become famous soon enough
Cheers!'s Avatar
I thought for $25 crutchfield will build you a mating harness if you buy the deck from them.
Cheers! is offline   Reply With QuoteReply With Quote
harnesses , head , install , kits , year
JBL Head Unit Replacement runokc 4th Gen T4Rs 4 07-29-2020 09:46 PM
replacement head unit? Will_4R 4th Gen T4Rs 4 01-29-2020 09:40 AM
05 4Runner head unit replacement Hocecoach Engines / Suspension / Wheels / Tires / Audio / Accessories 4 11-19-2012 04:26 PM
Head Unit Replacement Recs MarieDJ Engines / Suspension / Wheels / Tires / Audio / Accessories 11 09-10-2012 05:28 PM
3rd gen head unit replacement spoonman Engines / Suspension / Wheels / Tires / Audio / Accessories 2 08-08-2005 03:21 AM
