Originally Posted by e60ral
anyone? bueller?
Diagram I have shows one fuse for all outlets. "P/outlets" fuse, 15Amp on driver side junction block.
With a voltmeter or test light connected to ground on the other end carefully see if you have power in the center of the outlet. The outter ring should be ground. Check both.
If one is missing, go from there. If both present consider the device/adapter you're using to have a contact issue.
Good luck
4Reak
