sure74
Old 04-17-2021, 09:32 AM #1
scrodd scrodd is offline
scrodd is on a distinguished road
MagSafe Charger Install
I had previously installed a Qi wireless charger based on Sure74s posts on this forum but when I got my new phone I decided I would try to install a MagSafe charger so I could charge much faster. I figured it would also have the added benefit of making the phone more secure and not having to worry whether it was lined up correctly for charing.
The first thing I did was purchase a Aukey 21w car charger with USBC and Power Delivery 3.0, that way it would put out enough juice to fast charge over the MagSafe. I opened that up so I could separate the connections:
Then I soldered the contact points to the back of the 12v adapter, as described in Sure74s's post:
Then I reassembled the charger (for the most part) to keep the components protected. Ultimately, I probably could have gotten rid of a lot of the excess but if I had to do it over again, I would still do it this way.
Then I made a whole in the back of the cubby with a Dremel that was large enough to fit the usbc cable of the MagSafe charger through:
Then I used a glue gun to mount the Aukey charger and the excess MagSafe cabling to the back of the cubby:
Then I mounted the puck portion of the MagSafe charger to the cubby with a command strip:
At first I was going to place the MagSafe puck underneath the cubby like my Qi charger had been but after trying it, I wasn't satisfied with the connection - especially if the phone was in a case. I was going to make a larger whole in the bottom of the cubby and mount the MagSafe puck flush, however, thus far I've actually enjoyed it being raised a bit. It makes it easier to grab the phone and I think it helps the phone stay a little cooler while charging. I may just order a new cubby and give it a try to see how I like it but for now I'm very happy with this.
Thanks again to Sure74 for the instructions on the install of the Qi charger which was the inspiration and instruction for this.
scrodd is offline   Reply With QuoteReply With Quote
Old 04-17-2021, 04:16 PM #2
Engineer's Avatar
Engineer Engineer is offline
Real Name: Charles
Engineer has a spectacular aura about Engineer has a spectacular aura about
Engineer's Avatar
Real Name: Charles
There are days I consider moving all my switches that I located there to make room for wireless charging.......
2014 Trail Edition Premium, 285/70/R17 BFG KM2, RadFlo 2.5" Coilovers and Rear Shocks, 50qt ARB Fridge, OTRATTW Switches, BudBuilt Bumpout Sliders, Gobi Rack + Ladder / 40" Rigid E2 /Rotopax and MaxTrax mounted, ARB CKMTA12, 270amp Alternator, Southern Style Slimline Hybrid Front Bumper w/ Warn Zeon 10S and Front Fogs, Metal Oil Canister, Sound Deadening Insulation w/ Focal Front Speakers,Black Weather Tech mats and custom pin striping & dents (the trees & bushes did it for free)
Engineer is offline   Reply With QuoteReply With Quote
back , charger , cubby , magsafe , phone
Always on USB charger KENGNJ 5th gen T4Rs 3 06-27-2020 06:49 PM
USB Charger In 2nd Row sLADe781 5th gen T4Rs 29 07-22-2019 10:52 AM
Charger name? Nashvillerunner 4th Gen T4Rs 1 03-28-2019 06:11 AM
Help me cleanly install my various devices plz! Dashcam, radar detector, car charger khalid74120021 5th gen T4Rs 0 05-25-2018 01:51 PM
K&N Air charger kjfswkr Engines / Suspension / Wheels / Tires / Audio / Accessories 0 02-06-2007 11:21 AM
