04-18-2021, 10:11 PM
#16
Hawk HPS FTW
2012 4Runner Limited, Shoreline Blue Pearl / Beige leather, RCI skid, ext rear diff breather, Derale 13504 cooler, 110K
1993 300ZX Cherry Red Pearl with some bling, K&N intake, PowerTrix suspension, 130K
04-18-2021, 10:39 PM
#17
Originally Posted by zcruiser
Hawk HPS FTW
Do you guys get much dusting from the Hawk HPS pads?
04-19-2021, 04:09 PM
#18
Dusting, yes, but not excessive.
04-19-2021, 04:22 PM
#19
If you wash your 4runner once per month, you never notice. If you never wash your 4runner (like me), then you will see brown dust build up on your rims.
04-19-2021, 04:27 PM
#20
i just put a set of raybestos performance rotors and hawk LTS pads on mine. big improvement over stock.
04-19-2021, 09:02 PM
#21
The OEM pads have been good to me and that’s likely what I’ll use when I change them. The only brake complaint I can think of is the “OMG, we have to stop NOW!” thing that happens when you stab the brake in an emergency. The other vehicles I drive are much heavier so the 4Runner seems like a performance vehicle in comparison.
The rotors look really good. The only vibration I get is the steering wheel shake at around 60 mph sometimes and I know that’s from the tires. Maybe this weekend I can pull the tires off and measure the thickness of the rotors. Anybody know what the minimum should be?
I have honestly never heard of changing brake fluid before. I just looked at mine and it has a bit of a brown tint to it. Looks kinda like watered down iced tea. Guess I’ll start looking for a tutorial on that.
2014 MGM TEP - Dobinsons’ C59-300, Bilstien 5100 (front set to stock height), Cornfed 1/2 spacers in rear, Spidertrax, Airlift 1000
04-19-2021, 09:09 PM
#22
I was surprised when I changed the brake fluid out I saw bubbles come out of 1 if the rear calipers and 1 out of the front caliper. No one had touched the brakes for any kind of service.
When I went to replace the fluid I turkey baster sucked out the reservoir and filled it up with fresh fluid and started to bleed the brakes. In theory there would be zero chance of introducing air.
My brake pedal firmed up after the brake fluid change I did.
04-19-2021, 09:27 PM
#23
you have 93K miles on your OEM brake pads.. you inspected them and the pads are worn too much .. the rotors have no rust blisters and no pad wear damage on the rotors.
many do replace the brake pads around 75K miles but some always drive in traffic congestion they replace the pads 35K miles.
buy the toyota pads use silicone brake grease to lube the pins and coat the caliper weather boots. use a wire brush if there is some corrosion on the caliper / bracket.
put the brake pedal down keep the pedal locked in place . put a clear bottle with some brake fluid in it connect to the caliper bled fitting using a clear hose .. open the bled screw .use a C clamp to push back the caliper to the max ... then lock up the bled screw then clean up the brake area put pads in and then set in place ... then pump the brake pedal then keep the pedal down then open the bled screw and see if the brake fluid has air or dirty fluid .. repeat again then if no air and clear fluid it is good then do the next brake caliper repeat.
04-19-2021, 10:29 PM
#24
Bleeding brakes is easy. I would budget for 3 bottles of brake fluid (36oz) or 1 litre.
1.) Take a damp rag and clean the brake fluid reservoir cap and the reservoir near the opening so you don't get dust or gunk going in
2.) sipon, suck, syringe, whatever to get all the old brake fluid out of the reservior
3.) open a brand new bottle of brake fluid and fill to max (never use brake fluid that has already been opened)
4.) set car to "on" but engine not turned over. So it goes off -> acc -> ON (but don't turn engine over)
5.) start at back of car, passenger rear. Put clear brake hose on nipple, hose goes to a bottle, open bleed with a flared wrench (if you live in rust belt, this is important else you could be in for a brake caliper replacement as well).
6.) depress the brake pedal with the bleeder open about 25% of travel. The ABS pump will activate and push brake fluid out. Don't hold pedal for longer than 5 seconds at a time until you get a feel for how fast the fluid is coming out. Don't let the reservior go below MIN. The ABS pump moves a lot of fluid out very fast. I would budget about 75% of a bottle for this one side.
7.) Close bleeder, wipe the bleeder with a paper towel.
8.) Move to driver rear, and redo #4 to #7. Always making sure the reservoir is above MIN. I'd budget 60% to 75% of a bottle of brake fluid for the driver's rear
9.) close bleeder, wipe etc etc
10.) Move to passenger front, put hose on, crack bleeder, and let it slowly dribble out. This is the Gravity Bleed method. The SCCA guys swear by this method. I do it this way for 10+ years now. I'm also not being paid or on the clock. Budget 30% to 50% of a bottle for passenger front.
11.) close bleed, etc etc,
12.) Move to Driver front (make sure reservior is full). Crack bleeder, let it dribble out. Spend about 25% to 50% of a bottle here.
13. Close bleeder... done.
The reason why you use less and less as you go around the car as fresh brake fluid has already made it's way around.
You can pump and open bleeder etc if you have 2 person. If you are solo, then it's pretty much gravity bleed, or you find a vacuum bleeder etc. I've always used Gravity, and it helps prevent you from over traveling your master cylinder. The bore of the master cylinder usually wears over time or has build up. As you go max pedal travel the piston seal rides over this ridge and you end up damaging your master cylinder and have an internal bypass leak. With Gravity bleed you never encounter that.
Also don't ever let your master cylinder go empty. To bleed a master cylinder is not so trivial on modern cars.
Good luck.
04-19-2021, 11:44 PM
#25
I do a similar process as above using the gravity bleed method but use tubing and a bottle on the fronts. Just make sure the bottle is above the bleeder and air will not get into the system. You can do a one person pump this way as well.
Brakepad check at 32,000 Miles, 80,000+ Miles,101,000 Miles
04-20-2021, 08:24 AM
#26
That’s one of the threads I searched for before starting this one. Thanks for the link.
04-20-2021, 08:29 AM
#27
I'm at 220,000 miles and on my 3rd set of OEM pads all kinds of driving. Averaging 100k per set.
0446560320 fronts
0446660140 rears
Have to make sure you get the above and not the pads the dealer uses for their changes, they aren't worth a crap.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
04-20-2021, 10:37 AM
#28
I have 80k miles and am on our second set of Pad's and Rotors for the front and back. I aquate this to living in a city and having LOTS of stop and go traffic. this being said we always just replace with factory stuff seems to work great for stopping the vehicle. when I was younger i used to get aftermarket stuff but unless you're buying oversized rotors or are trying to get drilled / slotted rotors I would be willing to bet you'll see negligible differences in day to day driving.
2003 - 4Runner Limited V8 (Sold)
2014 - 4Runner Limited V6
2019 - GX460 Premium V8
04-20-2021, 11:25 AM
#29
To your original question, you can reuse the pins and clips.
I just did all new rotors and pads (Duralast Gold, never have to buy pads again with the lifetime warranty) and the rear pads came with new clips, but the fronts did not. I bought a hardware kit from Oreilly and lower clip was a different design, so couldn't use it, but did use the pins and inner clip.
I'm experimenting with the hardware, driver side was all old hardware and pass side has all new except the lower clip. Doubt it matters since I cleaned up and greased the old stuff.
04-20-2021, 09:27 PM
#30
OEM pads and rotors: 22k miles (they were 25% remaining). I also imprinted the ceramic pad onto each rotor face badly.
EBC Yellow Stuff and OEM rotors: changed at around 40,000 miles. Rears were paper thin. All 4 rotors were heavily dished and not worth surfacing
Hawk HPS and OEM rotors: on going... now at 60,000 miles, I think I'm about 30% wear on the pads, rotors actually look decent with no lip yet.
95% stop and go driving. 5% driving up and down the mountains.
Also I like to trail brake to take the late apex around all turns (left and right).
