Old 04-18-2021, 03:02 PM #1
jkdrew jkdrew is offline
jkdrew is on a distinguished road
Worse Gas Mileage After Spark Plug Change
I just had the spark plugs on my 14 Runner changed at the dealer after some rough idling at 120,000 miles. Now the rough idle is gone, but I've noticed slightly worse gas mileage, when I was expecting it to be the same or a little better. Lately, I had been averaging 18.5 mpg on the computer, 75% highway, 20% small town, 5% off-road, but hasn't recently been confirmed by calculations. I reset the computer at the time of install and I've had about the same mix of driving, but now only averaging 17.0, which I've confirmed with calculations. Nothing else was done at the dealer at the time. Is this at all expected or is that a big enough drop to think there could have been an issue with the plugs or install?
jkdrew is offline   Reply With QuoteReply With Quote
Old 04-18-2021, 04:42 PM #2
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
No, it’s not normal to expect a drop in MPGs. It’s possible it has to do with the install even if unlikely. IMO, if you take it back with the complaint that it runs better but mpgs are worse, you’re not going to get a very sympathetic ear. If you take it somewhere else you would get a better inspection/diagnosis but it’ll cost you. Are you mechanically inclined enough to do a visual of the vacuum lines? The newer 5th gens with the air pump have plumbing that must be removed and replaced, preferably with new gaskets. Did they charge you for these gaskets? Did you verify the plugs installed, or on your invoice are correct for your year?
1000MPH is offline   Reply With QuoteReply With Quote
Old 04-18-2021, 11:11 PM #3
oljedi11950's Avatar
oljedi11950 oljedi11950 is offline
oljedi11950 will become famous soon enough oljedi11950 will become famous soon enough
Lightbulb
Changed mine cpl thou ago & if anything better ! So they left one of vacuum lines off or worse ? Any different sounds on start up , do visual to see if any of them are hanging off !
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
oljedi11950 is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 12:13 AM #4
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
Any chance your computer had learned to deal with bad plugs and now learning to work with new plugs?
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 03:28 AM #5
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
Did they install the same part number OEM Denso plug that they removed? There are a few different manufacturers for our 4.0L. If not, this may be a problem based on the heat range of the plug. Although, most of these plugs come pre gapped to the correct specs, I always double check the gap. If it is running smooth, I doubt a vacuum line or a plug connection is loose. Did they inspect your plug wires and coil packs? I doubt it. Being 7 years old with 120k I might have considered a new set of plug wires.
There are so many variables to onboard or self calculations, I.e.;air temp, humidity, wind, tire pressure, etc.
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 08:38 AM #6
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
How many miles since the plug change? May take a while for the MPG's to creep back up. I have noticed it is quick to drop MPG's and slow to raise but over time, especially while computer re-learns your habits. Mine have always come back up slowly, but not instantly.
May also want to clean your MAF sensor and throttle body. Cans of cleaner have instructions on them and there are some write ups on here.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 10:16 AM #7
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
There is a possibility of counterfeit spark plugs:
PLUG STUDIO / NGK
https://www.denso-am.eu/media/137417...paper-_pk3.pdf
just google it.. its out there
1jzgte is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 01:20 PM #8
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
it runs smoother and now you are jamming on the throttle more.
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 01:43 PM #9
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
Did you change anything else like new tires or change psi? I'd clean MAF (although this 5th gen airbox is always amazingly clean when I check) and remove battery negative overnight then drive like a grandma for a few days. What was said about counterfeit parts is why I do this stuff myself and only buy parts from the dealership or big place like Napa or Summit for Denso/NGK. If its still low I'd probably replace the air filter (non-amazon OE), o2 sensors (non-amazon Denso) and pcv valve (OE) because its cheap and easy. And check all vac hoses were put back properly.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 02:20 PM #10
Yeah I think if there was old or bad plugs it could have adjusted to run lean due fuel not burning properly so mpg would be "better". And now its still trying to figure out the correct mixture with new plugs which takes some driving to learn.
99 SR5 v6 4WD
11 SR5 v6 4WD
Old 04-19-2021, 03:26 PM #11
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
18.5 to 17 is probably within the variance margin, where wind direction, slight traffic pattern difference and even temperature changes and gas source may have an impact.
I'd say give it more time/miles and see how consistent it is.
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 08-24-2021, 11:32 AM #12
dawudih's Avatar
dawudih dawudih is offline
dawudih is on a distinguished road
dawudih's Avatar
I replaced my oem plugs at 124,000 miles & now have 131,500 miles. I also changed my front brake pads for the first time, rear diff fluid, engine oil and the new designed air filter at the same time. All Toyota oem parts. The only variable would be the oil was 5w-20 instead of the usual 0w-20.
My commute to work is 78 miles round trip; most of it is cruise control in the HOV lane at 70mph, and I work for 7 days straight from 0700 to 1900. I also mostly use the same fuel station pump. Very consistent and controlled test.
I was getting 20.8 mpg for the last 2 years & after I serviced the car, it dropped to just under 19.9 mpg (almost a 5% decrease). I blamed the spark plugs, thicker brake pads or 5w oil. I just changed the oil back to a 0w-20 and fuel economy is up slightly to 20.1 mpg, but still less than before the service. Anybody have any real life experience with this reduction?
(The only reason I check my fuel economy is to find potential issues)
2015 Trail
dawudih is offline   Reply With QuoteReply With Quote
averaging , calculations , confirmed , gas , time
Regular spark plug change on a 02 3rd gen 4wd. How do they look? salgood 3rd gen T4Rs 16 08-13-2017 11:18 PM
Spark plug change - had all Densos brianhuntRVA 4th Gen T4Rs 6 03-25-2017 11:25 PM
Spark plug change out ? tmaxx13 3rd gen T4Rs 23 12-05-2012 03:36 PM
04 T4R Spark Plug Change cgarrett5119 4th Gen T4Rs 5 03-08-2012 04:48 PM
spark plug change 91bulldog Maintenance/Detailing 3 11-25-2005 02:24 AM
