Originally Posted by edizzle
thanks for the info. you are correct i am looking for something in the 33" range and width similar to the stock 265/70r17. but i definitely want a bigger wheel and less sidewall. i know it is not as good for off roading but it will be good enough for what i will ever be doing with it!!! i just like the look of a smaller sidewall.
so it safe to say to say finding something at 33" overall height and similar width to stock with proper backspacing should be fine?!?!
Something that is 32.5" and under should fit with the lift you mentioned. You may need a slight trim at the fender and a proper alignment to keep it from rubbing still.
If you're set on 20"s the stock limited trim comes with 245/60/20 which is a good place to start. If you want to keep the sidewall small the 285/50/20 is an option.
Not trying to shoot down your idea but 295/50/20 is a really obscure size and I only found one tire manufacturer that produces that size. There's plenty of 20" tire sizes out there, just not this one. The best place to start is find the tire manufacturer that you want. Go to there website and select size(s) they produce, select a wheel based on the tire width you need to run that tire. Then get back to me
