Old 04-19-2021, 12:06 PM #1
edizzle edizzle is offline
edizzle is on a distinguished road
295/50r20?
does anyone know if this combo will fit on a SR5 PRemium with Eibach Shocks at level +1" settings? In my little on line tire diameter calculator it shows this as a 33" tire equivalent to a 285/70R17
edizzle is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 03:03 PM #2
El Dusty's Avatar
El Dusty El Dusty is offline
El Dusty has a spectacular aura about El Dusty has a spectacular aura about El Dusty has a spectacular aura about
El Dusty's Avatar
What brand tire and wheel specs are you looking at running?
A 295/50R20 interpreted literally is a 31.6" OD x 11.6" wide and would likely fit without rubbing if you have enough width & offset in your wheel. I know this tire size is not specifically listed on the link below but worth referencing similar tires in OD and width.
Going Bigger - 5th Gen Tire Fitment Guide
Just my opinion, but this would not be a good tire if you're looking at gaining clearance offroad. Look for something taller and not as wide.
El Dusty is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 03:58 PM #3
thanks for the info. you are correct i am looking for something in the 33" range and width similar to the stock 265/70r17. but i definitely want a bigger wheel and less sidewall. i know it is not as good for off roading but it will be good enough for what i will ever be doing with it!!! i just like the look of a smaller sidewall.
so it safe to say to say finding something at 33" overall height and similar width to stock with proper backspacing should be fine?!?!
Old 04-19-2021, 05:32 PM #4
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Changing Tire Size or Wheels? Read this first! - Toyota 4Runner Forum - Largest 4Runner Forum
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 08:17 PM #5
El Dusty's Avatar
El Dusty's Avatar
Something that is 32.5" and under should fit with the lift you mentioned. You may need a slight trim at the fender and a proper alignment to keep it from rubbing still.
If you're set on 20"s the stock limited trim comes with 245/60/20 which is a good place to start. If you want to keep the sidewall small the 285/50/20 is an option.
Not trying to shoot down your idea but 295/50/20 is a really obscure size and I only found one tire manufacturer that produces that size. There's plenty of 20" tire sizes out there, just not this one. The best place to start is find the tire manufacturer that you want. Go to there website and select size(s) they produce, select a wheel based on the tire width you need to run that tire. Then get back to me
Old 04-19-2021, 10:20 PM #6
Thanks for the info!!! I’ll do my homework.
295/50r20 , calculator , diameter , line , tire
33x12.50r20 gladiator mt & limited 20s 2.1k OBO CHARLOTTE NC kingyager For Sale: Suspension/Wheels/Tires 1 10-02-2018 07:56 PM
Kumho Road Venture M/T 35x12.50R20 Impossible? kylebacc Engines / Suspension / Wheels / Tires / Audio / Accessories 2 03-09-2013 11:08 PM
265/50r20 brand opinions MiRunner 4th Gen T4Rs 6 09-15-2010 07:15 PM
