Old 04-19-2021, 10:54 PM #1
JettyHopper JettyHopper is offline
JettyHopper is on a distinguished road
Front shocks and spring change. Need opinion...
Members,
I was hoping to get better insight and first-hand experience on changing front shocks and springs ONLY.
Currently running OME shocks and springs (3" 884). The front is disappointingly sagging quite a bit after two years. Considering swapping in BP-51 front coilvers. Will this work? Make the ride better or worse?
Any advice will be appreciated.
JettyHopper is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 11:06 PM #2
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Originally Posted by JettyHopper View Post
Members,
I'd go ahead and do the fronts and see what you think. If for some reason the ride isn't what you prefer you really only need to change the rear shock which is pretty easy. If your happy with the rear coils I wouldn't replace them. And honestly if it's just the ride height up front you could consider just swapping that coil and leaving the strut. (Although buying a pre built coil-over could be the same cost as paying to have the coil swapped.) Kind of depends on your budget. If you have money to burn go for it.
comtn4x4 is offline   Reply With QuoteReply With Quote
coilvers , front , members , shocks , springs
WTB: 5th Gen OME Front Strut w/ 2884/5 spring and rear shock w/ 2889/98 spring lhg9105 For Sale: Suspension/Wheels/Tires 3 11-05-2014 11:43 AM
03 V8 timing belt change opinion hamiltonj2w1 4th Gen T4Rs 34 12-02-2011 11:16 PM
New Front Shocks- Spring Compressor??? clemson4rnr 5th gen T4Rs 46 07-07-2010 03:42 PM
Xreas front shocks change cost d_cool 4th Gen T4Rs 10 11-07-2009 12:27 PM
Opinion on (longer) oil change interval... eorange Maintenance/Detailing 15 06-30-2006 11:28 AM
