Old 04-17-2021, 06:16 PM #1
emmantik emmantik is offline
emmantik is just really nice emmantik is just really nice emmantik is just really nice emmantik is just really nice
A pillar grab handle - NO BRACKET REQ'D!
Added a driver's side A pillar grab handle without a bracket. Here's a quick write up!
(No, it won't be as strong as with the bracket but it is pretty strong as is to be honest. There is another post with the bracket if you choose to go that route)
What you will need:
1. Extra grab handle with 2 covers
2. Extra M6 bolt for top location. Needs to be at least 1/2-3/4" longer than stock bolt.
3. Extra M6 bolt. At least 3/4".
4. Extra nuts and washers.
5. Dremel/drill/drill bit
Here is the end result. Took about 1/2 hour.
The following is a quick write up!
A pillar grab handle - NO BRACKET REQ'D!-20210417_132638_resized-jpg
2015 Magnetic Gray SR5P
emmantik is offline   Reply With QuoteReply With Quote
Old 04-17-2021, 06:18 PM #2
Remove A pillar trim. Note that you can remove inner black piece easily. Just make slits to the following welded spots.
A pillar grab handle - NO BRACKET REQ'D!-20210417_113750_resized-jpg
Old 04-17-2021, 06:19 PM #3
With a little force you can pry it up.
A pillar grab handle - NO BRACKET REQ'D!-20210417_114319_resized-jpg
Old 04-17-2021, 06:20 PM #4
trim square tabs and round tab on bottom hole. You can leave the round part on the top hole.
A pillar grab handle - NO BRACKET REQ'D!-20210417_130038_resized-jpg  A pillar grab handle - NO BRACKET REQ'D!-20210417_130044_resized-jpg
Old 04-17-2021, 06:22 PM #5
Test fit handle. Mark the hole for bottom.
A pillar grab handle - NO BRACKET REQ'D!-20210417_131505_resized-jpg  A pillar grab handle - NO BRACKET REQ'D!-20210417_130307_resized-jpg
Old 04-17-2021, 06:23 PM #6
Connect bottom to the trim with extra bolt, washers, nut.
A pillar grab handle - NO BRACKET REQ'D!-20210417_131501_resized-jpg
Old 04-17-2021, 06:24 PM #7
I was gonna leave as is but decided to re-attach black trim. Drilled a hole to fit the new bolt. You can attach the black piece with glue or whatever. I decided to leave as it seems to be snug just pressure fitted.
A pillar grab handle - NO BRACKET REQ'D!-20210417_145939_resized-jpg
Old 04-17-2021, 06:26 PM #8
Use new longer bolt and washers for top hole. Add the covers and you are good to go! Enjoy your new driver's side grab handle1
A pillar grab handle - NO BRACKET REQ'D!-20210417_132133_resized-jpg  A pillar grab handle - NO BRACKET REQ'D!-20210417_132638_resized-jpg
Old 04-17-2021, 07:15 PM #9
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Nice write up. But IMHO it’s stronger with the bottom bracket. I have this setup with the bracket.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 04-17-2021, 07:20 PM #10
KSJ088 KSJ088 is offline
KSJ088 will become famous soon enough
Yeah you grab onto that W/any force you're gonna ripped that lower bolt right outta the plastic. Not trying to be negative/critical, just being honest.
I too did it W/bracket/kit I purchased from fellow member here.
Take Off You Hoser
Boston Bruins #1 2018 TRD OR Super White, Few Mods: Tinted Frt windows,Eibachs Set @ 0.85 up Frt, , Cooper Discoverer ST/MAXX 275/70/17 Interior LED's, H9 Lo Beams, Anytime LED Fog lights, Led Backup lights, CF overlays above Glove Box, Steering Wheel & all Door Control Panels to match OEM CF Center Console, Pro Grill, Fangs, Bruins on Startup Screen.
KSJ088 is offline   Reply With QuoteReply With Quote
Old 04-17-2021, 07:21 PM #11
Saker's Avatar
Saker Saker is offline
Saker's Avatar
I can envision pulling the bottom out when trying to get in.
No support from the frame.
YMMV
Best Regards,
Saker
Old 04-17-2021, 07:22 PM #12
I agree! But I don't plan on putting a lot of weight on it so it will do just fine for me. It's actually pretty strong on there as is. But yes, I think it would be stronger with the bracket.
Old 04-17-2021, 07:50 PM #13
CajunMikeR's Avatar
CajunMikeR CajunMikeR is offline
CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice
CajunMikeR's Avatar
While that would be great for "the look", I personally would be afraid to put any real stress on it in an "oh shit" situation.
At 230lbs, I don't think I would trust it to help me climb up in or readjust in the seat without some stress issues on the lower portion.
2019 MGM TRD ORP
Dobinsons IMS 3in lift, FN f(x) Pros 17x8in 0 offset, 285/70 C load Nitto Ridge Grapplers, and all sorts of other fun stuff
shootn4runner on IG
CajunMikeR is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 12:38 PM #14
alphabeast's Avatar
alphabeast alphabeast is offline
Real Name: Shawn
alphabeast is on a distinguished road
alphabeast's Avatar
Real Name: Shawn
Smile
My 4Runner already came with a driver side grab handle.. its the round one...
2014 TE w/ KDSS: ToyTec BOSS Suspension Kit / Toytec 1" Body Lift / JBA A-Arm's / Cooper Evolution MT 35" 12.5" / SCS Ray 10 17 X 9 / Budbuilt Bump Out Slider's / Gobi Stealth (No Rise) Rack / Hefty Fabworks Front Bumper / Ellis Precision Auto Shifter & Transfer Case Shifter/ Rigid D-Series LED Fogs / Precision LED Interior Lighting
alphabeast is offline   Reply With QuoteReply With Quote
Old 04-19-2021, 02:23 PM #15
ragin_cajun ragin_cajun is offline
ragin_cajun will become famous soon enough
No way... If you are going to do this mod, do it the right way. A grab handle is supposed to be used. This is nothing more than cosmetic - you grab it getting in off your rock sliders and it gives loose, guess what's going to happen.
Completely unsafe suggestion.
ragin_cajun is offline   Reply With QuoteReply With Quote
bolt , extra , grab , handle , quick
A-Pillar grab handle bolts. dustxking 3rd gen T4Rs 43 10-26-2020 02:45 PM
Driver side a-pillar grab handle? dedonderosa 5th gen T4Rs 30 05-04-2019 02:10 AM
How to Fix this? - A-Pillar grab handle bolts Lamer 3rd gen T4Rs 23 01-29-2019 10:42 PM
A pillar grab handle seadog1022 General Discussions 0 01-13-2010 09:37 AM
A-pillar grab handle is back! (oops - nevermind) GatorGreg 5th gen T4Rs 13 08-19-2009 09:11 PM
