Old 04-20-2021, 10:14 PM #16
Old3Tow Old3Tow is offline
Old3Tow is on a distinguished road
Originally Posted by El Dusty View Post
....curious on your tire size which we dont see often. What is your measured OD on the 235/75/17s and how do you like them compared to other sizes you've run? Thanks
Correction made: 235/80/17
An FYI PM sent on the tires... so I don’t derail my own thread.
2012 Trail Edition, Silver w/ KDSS, Shrock Works front bumper, warn M12,000 winch, RSG Rock Sliders, Full RCI AL Skids w/steel on gas tank, OME 888/889 springs and OME 90021 Nitrochargers, Camburg UCAs, 32” Cooper 235/80/17 LT on Trail wheels, 1.25” wheel spacers, LEDs inside and out.
Old3Tow is offline   Reply With QuoteReply With Quote
Old 04-20-2021, 11:58 PM #17
oljedi11950's Avatar
oljedi11950 oljedi11950 is offline
oljedi11950 will become famous soon enough oljedi11950 will become famous soon enough
Red face
235s ? really what
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
oljedi11950 is offline   Reply With QuoteReply With Quote
Old 04-21-2021, 01:58 AM #18
5thToy 5thToy is offline
5thToy is just really nice 5thToy is just really nice 5thToy is just really nice 5thToy is just really nice
Since opinions have been requested, mine is desired outcome provided by spacers is best accomplished via wheel selection and the effects of their width, offset and backspacing.
5thToy is offline   Reply With QuoteReply With Quote
Old 04-21-2021, 07:51 AM #19
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
Anyone have pics of Spidertrax spacers on an otherwise stock 5th gen? I have just a 1" level and stock sized KO2s and would love some extra width (giggity), but I don't want it to look like a toad.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 04-21-2021, 10:09 AM #20
Arnezie's Avatar
Arnezie Arnezie is offline
Arnezie will become famous soon enough
Arnezie's Avatar
I’m curious as to why you are running such skinny tires?
Arnezie is offline   Reply With QuoteReply With Quote
Old 04-21-2021, 11:38 AM #21
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
I've had Spidertrax 1.25" spacers on my truck for almost 3 years now. They are on there purely for aesthetics. I don't have any issues in the front of the fender due to the high-clearance cut, but I did need to do a BMC and occasionally the tire will get up into the area of the pinch weld at the rear of the fender. I have lost the plastic trim piece that covers the pinch weld several times and ended up notching it so the tire clears. My tires are about 2" wider than yours tho.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
Old 04-21-2021, 12:06 PM #22
kouki_monster kouki_monster is offline
kouki_monster is on a distinguished road
I've run spacers on many of my sporty cars and have always loved them. I've never had one complaint other than they can be a pain to remove, especially if you don't use some anti-seize on the mating surfaces. When it comes to cars, I drive HARD, and have never felt unsafe at all due to spacers. When installed correctly, as long as they aren't extremely wide, what's to fear?
That said, I come from European cars that use wheel bolts, not studs/nuts. So a spacer for me meant I sourced a longer wheel bolt.. and at that point you're basically just using longer bolts with lower offset wheels. Everyone who claims wheel-bearing issues is being overly-sensitive to the issue. Sure, more stress is added, but how much? We are all modding our vehicles here and "adding stress" all over. Spacers don't add any more stress than aftermarket, lower-offset wheels, add. But if neither of those mods are for you, that's perfectly cool.
Anyway, I've held off on spacers for the 4Runner because 1) I'm not keen on the bolt-on style, and 2) rocks hitting the side of my truck when off-road. To alleviate both of these concerns, and hopefully attain a nicer stance, my interests are in something custom.. so I wonder about y'alls thoughts?
I'm thinking something like a custom 1/2" plate spacer, and then fitting studs that are 1/2" longer than factory studs. The spacer would just slide onto the studs and sit there, and is only held on by the sandwich between the hub and wheel. Functionally, the biggest difference is that I'd then be using longer studs (which are essentially just bolts), so I think their physical properties should be considered since they may now stretch differently than the stock studs would, etc. Can anyone think of any reason this wouldn't work well, or any issues I might run into?
Cheers.
"DYNO4" Midnight Venture : Falken . C4 Fabrication . TRD
kouki_monster is offline   Reply With QuoteReply With Quote
Old 04-21-2021, 07:26 PM #23
SLC Punk SLC Punk is offline
SLC Punk is on a distinguished road
I've been running spacers for about 4 years. I have yet to encounter a tire shop or the dealer say anything about them nor refuse to work on it.
I do check them at every rotation (I rotate myself). The only time I found them to be an inconvenience was when I was replacing the rotors.
-Travis
2014 4Runner TE: 285/70/17 M/T ATZP3, 5100's 2.5" front/1.5" DS rear, Spidertrax spacers, RCI Sliders, FrontRunner Slimline II, Gobi Ladder, TRD Intake, Borla Catback, Pedal Commander, TRD Pro: Wheels, Skid, Grille
2018 Audi S5 Sportback, 2017 Toyota 86
SLC Punk is offline   Reply With QuoteReply With Quote
Old 04-21-2021, 09:13 PM #24
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
One of the best looking 4Runners I've ever seen.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 04-21-2021, 09:55 PM #25
edizzle edizzle is offline
edizzle is on a distinguished road
dude!!! you have one of the nicest looking 4runners here!! beautiful.
edizzle is offline   Reply With QuoteReply With Quote
Old 04-22-2021, 11:33 AM #26
baldrik78's Avatar
baldrik78's Avatar
Thanks guys! She's my pride and joy =)
Old 04-22-2021, 12:46 PM #27
ryguytheman's Avatar
ryguytheman ryguytheman is offline
ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice
Been running spacers for over a year. Originally had 275/70/17 tires when I put them on, and I was very happy to get them untucked from under the vehicle. It's for looks, but I like the effect.
Before spacers (275/70/17)
After Spacers
Spacers with 285s
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
ryguytheman is offline   Reply With QuoteReply With Quote
Old 04-22-2021, 02:32 PM #28
Does anyone know the width (outside of tread to outside of tread) on a stock 5th gen?
Just thought to measure and I’m at 69.5 in the front and 70” in the rear. Also put a tape on a stock Bridgestone and there is about 1.25 more tread width to them than I’m running.
Thinking out loud, between the narrower tires and 3” of lift, spacers might go a long way to bringing the COG back closer to stock. And yes, rims with more offset would do the same thing, but 7-hole Trail Edt wheels are best looking wheels, sooo...
Old 04-22-2021, 03:19 PM #29
chester4Run chester4Run is offline
chester4Run is on a distinguished road
I'll try to measure mine when I get home (as I mentioned earlier in this thread, similar setup to yours). I have the 1.25 inch spidertrax and I have JBA UCAs. I don't recall the measurement right after installing lift, UCAs, and alignment, but I think mine was slightly wider in the front (not noticeable, but measurable).
My experience with the spacers has been similar to others: no issues and I've never had a shop raise any question. I had them on two jeeps prior to this 4Runner, so I've probably got about 400K miles on spidertrax spacers with at least 10 tire changes in there. I suspect if you tried to rip a front wheel off somehow, other things would break before the wheel/spacer/hub connection does. Also as others have mentioned, it's important (and very straight-forward) to install these correctly.
2011 SR5 4wd
2004 SR5 4wd
1994 SR5 4wd (SOLD)
chester4Run is offline   Reply With QuoteReply With Quote
Old 04-22-2021, 03:37 PM #30
vt100 vt100 is offline
vt100 is on a distinguished road
What caster do you have on front?
2018, TRD Offroad, KDSS, 2.5" Kings w/ reservoirs, TC UCA, Toytec Superflex 2.5", 285/70R17 LT Falken Wildpeaks, BMC, 4x4 labs sliders, Gobi rack/ladder
vt100 is offline   Reply With QuoteReply With Quote
i’m , lift , narrower , rest , tire
talk me into a first gen Whitson Metalworks Classic T4Rs 18 01-08-2015 05:54 PM
Talk me out if it. Or talk me into it haha poser 3rd gen T4Rs 21 12-12-2014 06:16 PM
Stuck at Hood - Can't Talk about it so Let's Talk about My Truck? Ryan1975 5th gen T4Rs 4 04-03-2014 01:06 AM
Talk About Bad Ass! Koz All Other Vehicles 2 08-25-2007 08:25 PM
V8'ers: gas talk mole177 4th Gen T4Rs 25 02-24-2006 06:30 PM
