04-20-2021, 03:04 PM
Sway Bar End Link
Hi,
I am seeing tons of aftermarket REAR sway bar end links. Not so much for the front sway bar. Are any of you running aftermarket end links? if so, what kind? I called my dealer to order as I saw them for 75 dollar each online, stealer quoted me 135 each!! I need to replace as I pinched a boot when installing me new suspension....thanks in advance.
2018 SR5 Premium 4x4 - King 2.5 Adjustable coil overs, Total Chaos UCA's, King Rear shocks, Bilstein B12 1.5" rear spring. LED everything.
04-20-2021, 03:15 PM
Not sure if you're talking about the fancy aftermarket upgraded links, or just general replacements for worn-out OEM ones.
I'm just using some RockAuto $20 end links for the front. My old ones were totally clapped out and when I removed them (which required an oxy torch and the trusy heat-n-beat method) the boots were full of water and rust-colored grease.
The cheap replacements seem to be working fine, but they're only 6 months old and already covered in rust. I'll probably upgrade to some better ones with built-in grease zerks soon.
'14 SR5 in Classic Silver, Wilpeak AT3Ws, miscellaneous electrical odds and ends.
04-20-2021, 03:19 PM
For the price the dealer quoted, I thought id look into some cool aftermarket ones. I did buy some cheapies as well, ill run them for now. Thanks for the info.
04-20-2021, 06:26 PM
official vendor
official vendor
There are a few company's selling extended aftermarket links, and I'm one of them. Here's my site, and you have a couple options to choose from.
You'll notice that my links are not welded together like others. My heim joint links will require maintenance to keep them clean, and you'll need to use a PTFE dry lube on them after cleaning. I also offer a forged ball end link that is maintenance free with an OEM fit. The ball joint links are my own design, and are overbuilt to last. Both options for the rear are an inch longer out of the box, and extendable beyond that if need.
Mike
04-20-2021, 07:10 PM
I have front end links from Overland Custom Design, quite happy. I wanted something a bit more heavy-duty after putting on my lift, mainly because it would be one less thing to worry about when on the trails.
2017 T4R OR Super White
RRW RR4-V bronze wheels, Diode Dynamics SS3 Fog + Ditch, C4 Fab Lo Pro Winch Bumper + Smittybilt 10k synthetic, UpTop Overland Bravo Roof Rack
Dobinson's full suspension 2.5" front 1.5" rear - Dobinson's UCA - DirtKing LCA
Kenwood eXcelon 10.1 headunit + Kenwood speakers
04-20-2021, 08:59 PM
MSTUDT are excellent I love mine
04-20-2021, 09:07 PM
Have a set of these in the garage, waiting for me to get to them.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
04-20-2021, 09:12 PM
Real Name: Chris
Real Name: Chris
Can't help with the front but the rear can be done nice and cheap. OEM rear 3rd gen links are a direct swap and they're longer. I run them under the back of mine with my 2" lift.
04-20-2021, 09:18 PM
official vendor
official vendor
3rd Gen fronts are even longer if needed.
Mike
04-21-2021, 12:01 AM
i have the full shebang from overland customs, bought the original ones that i never got around to, got the new forged ones that i will install soon.
my dobinsons apparently failed after a few months.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
04-21-2021, 10:24 AM
official vendor
official vendor
These are what I offer for 03+ 4runner's, and these are my forged version.
04-30-2021, 01:25 AM
Mike
happen to know how much longer vs the rear?
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Sway bar link
runner823 |
3rd gen T4Rs |
8 |
07-12-2014 06:43 AM |
Sway Bar End Link
price311usn |
3rd gen T4Rs |
6 |
03-07-2010 12:14 AM |
sway bar link
Mr. Dabadina |
3rd gen T4Rs |
3 |
08-31-2007 06:12 PM |
Sway Bar Link?
4RUNR88 |
3rd gen T4Rs |
9 |
11-29-2006 02:50 PM |
sway bar link
drtlvr |
3rd gen T4Rs |
2 |
07-19-2005 05:23 PM |
