02-03-2017, 08:13 PM
Trail wheels "better" than TRD Pro wheels?
Done some searching but it looks like everyone goes from Trail wheels to TRD Pro wheels. Is it just for the looks? Is one wheel any "better" than the other?
02-03-2017, 08:28 PM
Trail wheels are wider, but I expect that the TRD wheels have a little better backspacing and are lighter.
Here is my 4Runner Trail beside a coworker's Pro. Both are stock.
2023 4Runner TRD Pro, 2023 GR Corolla
02-03-2017, 10:34 PM
I'd venture to say that most of the time it's for looks. Black wheels yay!
02-03-2017, 11:17 PM
I had the trail wheels and i upgraded to the TRD wheels and there is no difference in performance. I black prefer the look over the silver on my white car.
Also, the wheels seem to stick out slightly more than the trail wheels giving it a better stance in the wheel well - or that's completely untrue and it just appears that way to me.... I don't know.
2015 White Toyota 4Runner Trail w/ KDSS
02-03-2017, 11:18 PM
For the two rigs having the same size tires it are shows the bridgestone's don't measure up on width. It's pretty much my least favourite part of my trail edition, soon to be fixed with a set of proper ko2's or duratrac's. The trail wheels look nicer once a proper set of tires are mounted on them.
The trd pro wheels have a different offset and therefor they do stick out a bit more, this is true for all trd pro models, gains width for more stability to accompany the added height as well. I believe the Tacoma trd pro gains 1/2" at each corner for 1" overall wider track.
02-04-2017, 12:15 AM
Real Name: Jeff
Real Name: Jeff
I'm currently on the stockish appearance, sleeper look kind of thing with tasteful mods. I like my Trail wheels the more I look at them, and are a "big part of the formula" as a friend put it for not having rubbing issues.
Coming out of Tacoma ownership for 8 years, the trends where everything was debadge, plastic dip, black wheels, and satoshi this and that- I got pretty burned out on that look. I'm sticking with my Trail wheels for a while.
2016 Trail Premium
02-04-2017, 12:45 AM
The trail wheel has a little recessed slot to protect the tire valve. Small detail, but worth noting in the direct comparison.
'14 TEP w/ BFG KO2s and 62,000 miles of stories
02-04-2017, 01:04 PM
Real Name: Ron
Real Name: Ron
SR5 wheels do the job - all scraped up from rocks - fit the E rated LT265s just fine - easy to clean because they don't have a bunch of non-functional extra ribbing -
Totally stock 2013 SR5 4WD. Have added Toyo Open Country M/T LT 265/70-R17 (E) tires the first week I owned it. Added second set of Toyo M/Ts at 86900 miles.Added RCI OFF-ROAD Rock Slidersat 84000 miles. Added RCI OFF-ROAD front skid plate at 90,000 miles. Daily driver and so far spending about 30% of time/mileage off-road. Previous truck 2004 Land Rover Discovery that also spent about a third of it's life off-road. I HANG AROUND HERE "THE T4R FASHION FORUM" JUST FOR LAUGHS.
Perfect vehicle as it stands for northern Nevada terrain. Keep it stock - it'll go most anywhere as is.
02-04-2017, 02:06 PM
I really like the look of the trail wheels, and they work just fine, so I don't really see a reason swap them out.
Stay quixotic my friends.
2015 TE, RCI Sliders, TRD skid plate, RCI TRD integration plate, Alu RCI transmission skid, KO2 265/70/17 E
02-04-2017, 02:16 PM
I've seen a pair of black powder coated Trail wheels and they looked pretty good. Can't go wrong with either.
'15 TEP w/KDSS. Nfab steps and some PlastiDip
'94 Wrangler on 33's
02-04-2017, 03:21 PM
TRD Wheels FTW! But I'm biased!
02-06-2017, 02:41 PM
Yep. Half an inch wider with a valve stem protector. Functionally they are "better" than the TRD wheels, but they're not black and don't say "TRD" so there you have it.
2014 Trail - 5100s at .85, 265 KO2s
02-06-2017, 02:44 PM
If you intend to hit trails etc go with whatever wheel is cheaper since they all get trashed the same anyways
2019 Toyota 4Runner SR5
TRD Pro Wheels
Nitto Terra Grapplers
02-06-2017, 02:47 PM
What was your cost on the powder coat?
'14 Mag Grey Trail
Installed: Bilstein 5100 with Toytec Super Flex Coils, Gobi Stealth Rack, Rigid SR in front and rear, 265 Duratracs, Shrockworks Sliders, RCI Skids, LED light swap, Rotopax mounted in cargo area.
Sold-2008 Shadow Mica SR5
Sold-1996 Silver SR5
02-06-2017, 02:51 PM
The machined areas of my Trail Edition wheels are plenty scratched but you have to get close to notice it. I'm sure if they were the black TRD wheels they would look horrible.
