01-15-2018, 06:02 PM
Headlight Bulb Replacement - Sylvania vs Phillips
I am still running the original bulbs in my '10, and honestly I am happy with them overall. On rare occasions I find myself looking for a little more light. That being said I am looking at either the:
Sylvania Silverstar Ultra
or
Phillips X-tremeVision
I did I search here but found very limited information, which begs the question, is there a reason not to upgrade?
I know most people say go the HID route, but I plan to replace this 4R in the next year or so not do not feel it is worth the investment.
I have read these 'aftermarket' bulbs burn out faster than the OEM's, if so, at what rate? How long do OEM's bulbs typically last for reference?
I also don't want to be 'that guy' blinding others on the road, but if my lights are adjusted fine now, will going a brighter cause issues for other drivers?
Thanks!
2010 SR5 Magnetic Gray Metallic
Leather Package, Sunroof, Front & Rear AC Outlets, XM Radio, USB, IPod, Bluetooth, Backup Cam, Sliding Rear Deck, Floor/Cargo Mats, Wheel Locks, Cross Bars, Cargo Cover, FIAMM El Grande Horns, WeatherTech Digital Liners, Rocky Road SuperSliders (SR5 Version), aFe Power Pro Dry S Air Filter, Yokohama Geolandar A/T G015's
01-15-2018, 06:08 PM
On the recommendation from Daniel Sterns Lighting I bought Philips H11 X-tremeVision Upgrade Bulb off Amazon for my low beams and I’m happy with the purchase.
https://www.danielsternlighting.com/
I did not have to realign my headlights afterward. I tested them on the garage door and had the same cutoff.
2015 Trail Premium Super White
2018 TRD PRO Super White
01-15-2018, 06:14 PM
Does anyone know what oem bulb manufacture is in Toyota 4Runners from the factory?
01-15-2018, 06:42 PM
OP the extremevisions are a little brighter, you will notice it. And unless you are driving a lot at night, they should last you another year easily. Good luck on replacing your 4Runner.
2019 ORP KDSS MagGrey RSG Sliders/ICS Fab above console mount
01-15-2018, 08:27 PM
So these types of bulbs don't even last a year? Do most people buy 2 of each to keep a spare for when it blows?
01-15-2018, 09:44 PM
Real Name: Jason
Real Name: Jason
I believe when I removed my OEM bulbs they were OSRAM.
2015 SR5 Premium 4x4 Super White
TRD CAI - n-fab Nerf Steps - Philips X-treme LED fogs - XenonDepot Philips HID Low Beam - Interior & Exterior LEDs - Bilstein 5100 All Around: Front 1.75", Rear 1" Cornfed spacers - Prothane/Whiteline front & rear sway bar bushings - General Grabber ATX 265/70/17 - ARB On Board Air
01-15-2018, 10:43 PM
Believe Osram is oem !
2011 SR5 Mgm 4x4 alpharex pro headlights & depo black tail lights level 8 trackers wheels & p285/70/17 cooper at3s, 6112s all around set 2.5 rear rancho spacer 11/4, FJ coils TRD intake.w/afe-dry filter Urd y-pipe flowmaster super70ii TE roofrails! 2014 Sr5 Superwhite Bils 6112s/eibach 2.5 /1 "rear springs 285s Cooper at3 ms on fj pc-d satin black, Urd y-pipe/Flow delta 50 muffler/all interior led lights & low beams sealights h7 led with laminx yellow fogs & oldreds puddle harness w/2010-13 mirrors
01-15-2018, 10:56 PM
neither.. retrofit a h9 by simply cutting a small part of the tab and cleanng the glass throughly w/ alcohol. OEM H11's put out about 1300lumens vs h9's around 2000 lumens. Yes the h9's burn out faster than h11 just as the silverstars and xtremevision will burn out quicker as well. However h9's wil cost you a fraction of what you'd pay for those fancy bulbs.
If you're not keeping your car for that much longer, then just go with H11's again. Bulbs lose light output efficiency after a couple years of use and bulb makers recommend replacement. I find their claim to be very true. Take out your h11 and look at the filament. If it looks a bit burnt or ashy then you've lost some light output over time. Compare to a new h11 bulb and the filament is bright and shiny.
01-16-2018, 06:18 AM
When I was looking at them figured if you drove 2 hours at night 5 times a week for 11 months out of the year they would probably last a year. Most people don't drive that much at night though.
01-16-2018, 09:45 AM
Just did mine several months ago with the Phillips X-treme vision. They were $26/$25 set for lows and highs. I do a lot of backroads night driving and I was very happy with my OEMs once I aimed them correctly. These are fine but no revelation. When these go I’ll go back to OEMs probably. Maybe just replace the high beams with the X-tremes?
Edit: Osram owns Sylvania.
01-16-2018, 10:59 AM
Real Name: Chris
Real Name: Chris
Silverstar Ultras are great headlights and will last you well over a year
01-16-2018, 11:45 AM
I plan to mod my 9005 high beams to 9011 once they go out. According to Daniel Stern the 9005 bulb is spec'd for 1870 lumens and the 9011 (HIR) for 2350. That's more lumens than any of these fancy lightbars can throw out. Lots of info on this simple mod.
09-24-2018, 01:04 AM
I've been planning to do this to my 2010 sr5 hoping for more lumens at the same wattage. Does anyone have some before and after pics of the beams? Or any regrets on doing the mod? Since the stock headlight housings have a cover over the lowbeams, the glare shouldnt be dangerous for other drivers right?
09-24-2018, 02:51 PM
I have the Philips Xtreme Vision ( https://smile.amazon.com/Philips-X-t...reme+power+h11 ) on my 4R (and had them on my Xterra before that). No regrets, just be aware of the trade-off - a little more lumens for less life. Much cheaper and safer (non-blinding) alternative over HID or LED bulbs.
If your 4R is a 2010 and you've never changed the bulbs, then I would imagine this would be a significant difference for you, as halogen filaments wear out over time w/ usage.
09-24-2018, 03:20 PM
Just got a couple of pairs of Phillips bulbs from XenonDepot. Great reviews on these bulbs, reviews on Sylvania bulbs make them look even better.
