Old 04-25-2021, 02:04 PM #1
Old3Tow Old3Tow is offline
Old3Tow is on a distinguished road
Question Lift, Thrust Angle, Track Bar
TLDR: Thrust angle is rather off. Should I do an adjustable track bar given my specs and lift while I’m at it?
This past week I swapped out to full OME Nitrochargers and stiffer springs on my 5th gen 2012 KDSS Trail Edition. Upgraded to Camburg UCAs too. Now I’m rocking a full +3” lift with just over 1” of rake and really like it a lot. Yesterday I went to have it aligned, and subsequently discovered that one tie rod is fully seized and the other is getting pretty worn. But it was too late in the day to do a fix. So I’ll change them out myself tomorrow night and take it back in later this week, no big deal.
Here is the wrinkle tho, when we had it hooked up, the Thrust Angle on the rear axel seemed excessive at 0.24*. Not sure what it was prior to this OME lift but spec is supposed to be below 0.15* as I recall.
So my question is do I get an adjustable track bar to correct the Angle before I go in again? (This was recommended to me along with doing the tie rods).
Maybe with new tie rods I could do without an adjustable TB... but maybe adding is worth it while I’m at it, I dunno?
Your collective experience, thoughts and guidance is appreciated.
Lift, Thrust Angle, Track Bar-926cf812-1ea8-4ccf-8f58-c7074dac2531-jpeg
2012 Trail Edition, Silver w/ KDSS, Shrock Works front bumper, warn M12,000 winch, RSG Rock Sliders, Full RCI AL Skids w/steel on gas tank, OME 888/889 springs and OME 90021 Nitrochargers, Camburg UCAs, 32” Cooper 235/80/17 LT on Trail wheels, 1.25” wheel spacers, LEDs inside and out.
Old3Tow is offline   Reply With QuoteReply With Quote
adjustable , angle , i’m , lift , thrust
CV axle angle after lift tom5191 4th Gen T4Rs 29 07-10-2018 04:29 PM
Thrust Angle Off phillipeino 4th Gen T4Rs 3 05-21-2014 03:38 PM
what caster angle with adjustable uca for lift Forrrrest 3rd gen T4Rs 8 02-02-2014 08:02 PM
Post-lift CV angle swimmerdude1127 5th gen T4Rs 69 10-09-2013 11:07 AM
Thrust angle in rear - rear toe RPS13 4th Gen T4Rs 12 07-22-2013 11:17 PM
