Old 04-28-2021, 04:39 PM #1
Wbflyer Wbflyer is offline
Wbflyer is on a distinguished road
Bilstein 5100 and KDSS
Hey All!
I have 5100's on all around. I've got KDSS on my 2020 TRD and .80 or the second notch on the front. I'm thinking of going to the third or 1.75 on the front. Do you see any issues with KDSS doing that? The rear is stock except for the 5100's on the rear. Getting Firestone bags in the rear springs in case I tow.
Wbflyer is offline   Reply With QuoteReply With Quote
Old 04-29-2021, 06:59 AM #2
jk24runner's Avatar
jk24runner jk24runner is offline
Real Name: Nick
jk24runner is on a distinguished road
jk24runner's Avatar
Real Name: Nick
You will have no issues bumping your ride height up
jk24runner is offline   Reply With QuoteReply With Quote
Old 04-29-2021, 02:22 PM #3
Ok, sounds good!
Old 04-29-2021, 02:27 PM #4
mrbrenan's Avatar
mrbrenan mrbrenan is offline
official vendor
Real Name: Brenan
mrbrenan is on a distinguished road
official vendor
mrbrenan's Avatar
Real Name: Brenan
No issues at all on my end; however I did have a slight KDSS lean. You can fix that though by stacking one shim on top of your 5100 from Ekstrom Design or anyone else that makes strut shims. Some guys have said they have lean, and some have not. We did have lean running the 5100s with 889 OME coils but one shim on the passenger side fixed it.
Ekstrom Design: Ekstrom Design & Fabrication Corporation -- A Coachbuilder Company -- – Shop Coachbuilder
My 4Runners; 1999 SR5 4WD Jade Green, 2014 TEP KDSS White, 2016 SR5P White, 2016 TEP KDSS MGM (Jade) and 2023 SR5P on Portal Axles.
Trail 4Runner (5th Gen 4Runner Mods):Trail4R.com
6th Gen 4Runner Mods
https://6g4r.com/
mrbrenan is offline   Reply With QuoteReply With Quote
Old 04-29-2021, 02:39 PM #5
ATC556 ATC556 is offline
ATC556 is on a distinguished road
Does the KDSS make the install any different than with the normal Sr5 suspension setup? I'm wondering if any shops will balk when they see the KDSS when I get around to getting the 5100s.
ATC556 is offline   Reply With QuoteReply With Quote
Old 04-29-2021, 03:03 PM #6
mrbrenan's Avatar
official vendor
Real Name: Brenan
official vendor
mrbrenan's Avatar
Real Name: Brenan
Yeah, KDSS does make the install a little more time-consuming as you're working with the stiff hydraulic sway bar as opposed to the typical SR5 sway bar suspension setup. It shouldn't warrant a higher install price but who knows. Depends on the shop and how experienced they are with Toyotas/KDSS in general.
https://6g4r.com/
Old 04-30-2021, 01:58 PM #7
bluebullet's Avatar
bluebullet bluebullet is offline
Real Name: Blue Bullet
bluebullet is on a distinguished road
bluebullet's Avatar
I got front 5100s on my 2011 Trail in 2011 for $400 installed. When I asked about 5100s for my 2020 ORP in 2019 I was quoted $1400 installed. Same dealership different accessories manager both 4Rs had KDSS. When I asked why so much more accessories manager said it was due to the difficulty of the install with KDSS according to the techs. I passed b/c I thought it was a ripoff. 5011s at 1.75" leveled the 2011 and reduced the nose drive when braking for deer. It was so bad before I was losing them in the headlights. Bad juju.
At 1.75" I had to get the headlights adjusted as I was getting flashed a lot. More bad juju.
Happy Trails
2020 ORP w/ kdss, 1999 SR5 5sp, 2017 Chev Duramax (Shimmy), KTMs and ATVs for offroad
As a lady recently said "If you can't fix it with a hammer, you have an electrical problem."
bluebullet is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 02:13 PM #8
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
You can do it yourself! KDSS is not a huge deal, just unbolt the end brackets and support the piston where it meets the bar so it doesn't extend and hang there. Others have let it just hang without issues. You can do the whole thing in your driveway if you have a floor jack and the vehicle jack.
How To: Lift Installation (on KDSS equipped vehicles)
There are also some pdf's with pictures floating around since the images in this post disappeared.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 08:37 PM #9
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
Last year, an off road performance shop told me they wouldn't do anything to guarantee no lean or resolve any lean related issue when they gave me a quote to lift my 2011 Trail with KDSS. I wanted 0.85 inches front lift with Bilstein 5100s. I elected to install the shocks myself 3 months ago. No lean. Be sure to ask your shop how they would handle any lean issue that may arise. If the tech decides to loosen the KDSS shutter valves, they have to know how to count turns or measure height. I used a method that didn't involve loosening the valves.
DougR is offline   Reply With QuoteReply With Quote
Old 05-03-2021, 12:25 AM #10
bboy626's Avatar
bboy626 bboy626 is offline
bboy626 is on a distinguished road
bboy626's Avatar
Been running the Bilstein 5100 at 1.75" on my 2012 Trail with KDSS for years. I did go with Toytec rear springs to stiffen up the rear. No issues. Perhaps some slight lean when fuel tank is low but doesnt bother me one bit.
bboy626 is offline   Reply With QuoteReply With Quote
Old 05-03-2021, 04:10 AM #11
Blue109's Avatar
Blue109 Blue109 is offline
Blue109 has a spectacular aura about Blue109 has a spectacular aura about Blue109 has a spectacular aura about
Blue109's Avatar
Eibach kit at 2.75" on my KDSS truck. Hardly noticable lean. Local shops wanted way to much so I followed the suggestions from this board and did it myself. Had zero issues. Used a ratchet strap to hold piston in place and removed end links from LCAs. After that it's just like doing a lift on a non KDSS truck.
If you're gonna scream, scream with me. Moments like this never last.
Raptor lights. eBay PRO grill. Pedal Commander. Plasti dip valence. Very limited edition overlanding stickers and headliner patches.
Blue109 is offline   Reply With QuoteReply With Quote
Old 05-03-2021, 05:29 PM #12
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
I'm at a hair over 3" lift up front with my Dobinson/5100 combo, with KDSS, for almost 3 years. No issues, other than digressive valving on the shocks, plus the heavy KDSS sway bar makes washboard roads a little rough.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
Old 05-03-2021, 09:41 PM #13
BlueRidge77's Avatar
BlueRidge77 BlueRidge77 is offline
Real Name: Michael
BlueRidge77 will become famous soon enough
Real Name: Michael
Digressive shocks is what has kept me from getting the 5100’s. Many like the stiffer shock because it can help with handling, but I don’t need that with the KDSS. Perhaps it would be worth the stiffer ride and rough washboard performance if I had a non KDSS... Have you looked into a more linear shock? I’ve been looking into the Eibach shocks which are also digressive, but not as much as the 5100 and perhaps I could live with those on my stock springs... IDK. I’m in a bit of analysis paralysis...
2016 MGM TEP w/KDSS - P285/70-17 Toyo Open Country AT3 on Stock Trail wheels, no spacers - Dobinsons IMS Lift 2.75”/2” (302/505 Springs) - Freedom Off-road UCAs - TRDP Grill - Redarc Trailer Brake Controller - SumoSprings Helper Spring Bumpstops (black)
BlueRidge77 is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 10:21 AM #14
baldrik78's Avatar
baldrik78's Avatar
I'm going to go with Dobinsons IMS. Probably next year. I'm working on getting a rear bumper this year.
5100s , front , issues , kdss , rear
Bilstein 6112 & OME906/Bilstein 5100 BikeDestroyer 3rd gen T4Rs 12 09-05-2019 08:47 AM
Overextending Bilstein 5100 rears with my 3" lift, which Bilstein 5125 part? str8flexed 5th gen T4Rs 20 02-22-2019 12:45 AM
Wtb bilstein 5100 adjustables front and 5100 rears yotamaine For Sale: Suspension/Wheels/Tires 0 04-08-2015 05:04 PM
SR5 w/ Bilstein 5100's vs KDSS Mossyoakglock 5th gen T4Rs 3 10-04-2014 07:46 AM
FS: 3rd gen Bilstein 5100 w/ Eibach Coils & Bilstein 5125 Rears - Honolulu - $425 +S awpsome For Sale: Suspension/Wheels/Tires 4 08-21-2014 10:47 PM
