Old 04-29-2021, 10:56 AM #1
orcking orcking is offline
orcking is on a distinguished road
Grease
What is the best NLG1 #2 grease to get for lubing the driveshaft.
Also for Full time 4WD, if I just keep moving the truck back slowly until I see the zerk fittings, is that doable? as I do not want to lift the truck.
Thanks
orcking is offline   Reply With QuoteReply With Quote
Old 04-29-2021, 11:05 AM #2
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Thanks
Drive shaft slip joints get grease with moly. Spider joints get grease without moly. Two grease guns.
I crawl under mine without lifting and can usually get to the zerks with a little work. Once or twice i had to move the truck a few inches.
Search on here for everybody's opinions on grease, there are a ton. IMO, as long as your greasing them every 5k or so with the appropriate grease, brand wont matter. Grease the spiders until all air is purged and new grease comes out. Slip yokes are a mystery, I just put in a few pumps every time. Not sure where it goes after that. Oh, and I am currently using amsoil, but probably will get something off the shelf when that runs out.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 04-29-2021, 12:08 PM #3
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
I use Green Grease on the shafts and whatever with moly I found at auto parts store on the ujoints. That reminds me that I gotta do my them again soon.
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 04-29-2021, 12:14 PM #4
The manual says you could use NLG1 #2 grease for both the shaft and spider joints, is that bad?
Old 04-29-2021, 12:41 PM #5
Jivewalker's Avatar
Jivewalker's Avatar
I dont think its "bad". Slip yokes move in a different way with different forces than the spiders hence the moly option. no bearings in slip yokes so grease needs to stick to surface and handle extreme force. So, lithium based nlgi2 with moly would be better for yokes than nlgi2 without, but nlgi2 would be fine, just not best. One thing I have read somewhere that its best not to mix different greases as they can interact and actually cause issues. So, just stick with whatever you pick. Does that make sense?
I am fragile.
Not like a flower.
But like a bomb.
Old 04-29-2021, 12:42 PM #6
Whippersnapper02's Avatar
Any brand that meets the standards just like when choosing oil.
Old 04-29-2021, 12:50 PM #7
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
Not bad, it's better than nothing or never lubing those joints. If you don't want to keep 2 separate grease guns then I'd suggest have one with a grease that will cover all applications. My understanding is that molybdenum helps with sliding/friction which is why it is preferred for the slip joint but keeping it greased is the most important factor.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 04-29-2021, 01:58 PM #8
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
Mystic jt6 hi-temp #2 and Mystik jt6 hi-temp moly if so inclined on the slip joints. Napa usually has it. Get guns with a flexible hose.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 04-29-2021, 08:40 PM #9
I got the lock and lube grease gun, heard great things about it.
Old 04-30-2021, 08:52 AM #10
blanchard7684 blanchard7684 is offline
blanchard7684 is on a distinguished road
I have a grease gun chambered with Mobil XHP 222 (moly, for the slip yokes) and another with Mobil 1 for the spiders.
blanchard7684 is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 09:31 AM #11
I have did lots of research, and I think I will be going with the Mystik you suggested.
read lots about Mobile 1 leaking , etc...
I will buy two grease guns and do it right...
Thanks
Old 04-30-2021, 09:07 PM #12
Thanks
Yes I keep a mobil 1 gun in a plastic bag, in another plastic bag, in a catch pan and still have red juice all over the place. Plus the Mystik is the only proper moly grease I can find sold in stores around here, other than Valvoline Palladium sometimes.
99 SR5 v6 4WD
11 SR5 v6 4WD
Old 04-30-2021, 09:19 PM #13
Whoa that coupler is more expensive than the guns I have. Looks worth it though I'm going to pick one up. Should eventually pay for itself in shop towel and qtip savings ha.
99 SR5 v6 4WD
11 SR5 v6 4WD
Old 04-30-2021, 09:20 PM #14
NorthPark NorthPark is offline
NorthPark will become famous soon enough NorthPark will become famous soon enough
I actually just got done washing my hands from lubing mine up.
The thing is, since I'm not lubing things full time, I can afford to buy the best (I was looking at Aeroshell at one point, which I do have tubes of for other stuff).
I'm pretty sure it doesn't matter that much. I got mystik #6 and Shaeffers 221 moly in the lock n lube grease guns - they seem ok. Wasn't a big deal to tack on to an amazon order.
The reason for the 221 is that I saw Icon using it in their delta joints which I also have.
Just go to walmart and buy some lucas for $4 though
NorthPark is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 10:45 PM #15
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
i use whatever toyota recommends, and the manual states that NLG1 #2 is fine for both shaft and spider joints..so thats what i use.
fittings , grease , slowly , truck , zerk
Steering rack polyurethane bushings: grease or no grease? fourfive 3rd gen T4Rs 14 05-07-2017 02:59 PM
can i use this grease kolelt 3rd gen T4Rs 49 06-06-2014 07:40 PM
Grease gun? Supra725 3rd gen T4Rs 28 10-12-2012 02:28 PM
If you were to use just one Grease... freshley Maintenance/Detailing 6 09-18-2012 06:21 AM
Hub grease cap A/V1 Maintenance/Detailing 0 08-14-2011 04:25 AM
