Old 04-30-2021, 08:53 PM #1
jdSnake jdSnake is offline
jdSnake is on a distinguished road
Bilstein 5100 @ 1.75 with .4" OME rear?
Has anyone tried this set up? Got both on the way and was initially planning to run the bilsteins at .85 with the .4 spacers in the rear bc I like the rake but if this would give me a slight rake at 1.75 I might try that. Thanks for any insight.
-JD
jdSnake is offline   Reply With QuoteReply With Quote
Old 05-01-2021, 11:33 AM #2
meltdown meltdown is offline
meltdown will become famous soon enough
Just my opinion, if you go 1.75” in the front, I think you’ll want to go .75” or 1”in the rear.
I have 1.75 lift in the front with .5 in the rear. With no weight, it sits perfectly level with maybe a .5 rake measured at the top of wheel wells. Any amount of load in the back drops it to a reverse rake. I originally had 1” spacers in the rear and thought it was too much forward rake (1.5-1.25 depending on side/fuel) so I switched to .5 spacers. Really wish I had gone .75. When I hook up to my empty utility trailer, I get reverse rake.
2014 MGM TEP - Dobinsons’ C59-300, Bilstien 5100 (front set to stock height), Cornfed 1/2 spacers in rear, Spidertrax, Airlift 1000
meltdown is offline   Reply With QuoteReply With Quote
Old 05-01-2021, 12:30 PM #3
Harrisnc Harrisnc is offline
Harrisnc will become famous soon enough
I have a .75” rear spring and 1.75” in the front. I wouldn’t want the back lower than it is.
2022 Limited 4x4 Silver
2017 TRD Offroad. Barcelona Red, 265 BFG KO2, Eibach Pro-truck 1.6/1, Shrockworks sliders-TRADED
Harrisnc is offline   Reply With QuoteReply With Quote
Old 05-01-2021, 05:52 PM #4
Supercowcc Supercowcc is offline
Supercowcc is on a distinguished road
This is mine with 5100s all around set at 1.75 in the front with a corn fed 1inch in the back. Love it when its unloaded. When it is loaded the rear sags a bit. Currently looking to get stiffer springs.
Imgur: The magic of the Internet
Supercowcc is offline   Reply With QuoteReply With Quote
Old 05-01-2021, 08:15 PM #5
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
When you say loaded, do you mean trip to the grocery store loaded or 12 bags of mulch loaded?
And when you say sags a bit, does it sag enough to give it a negative rake?
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
Old 05-01-2021, 10:03 PM #6
Thanks fellas. This is what I was imagining and not looking for in my set up. I’ll go with the .85 front and the .4 spacers in the rear for now and get springs to lift it higher at some point down the road.
Old 05-07-2021, 06:07 PM #7
with a RTT, 2 dogs, girlfriend, and camping gear I have a slight bit of reverse rake. Not terrible but noticeable. 12 bags of mulch would still have me level. groceries don't affect it.
Old 05-07-2021, 09:52 PM #8
21TOR 21TOR is offline
21TOR is on a distinguished road
I am going with Bilstein 6112s @ 1.6 in the front and .75 spacer rear. Hope for a little rake.
If they ever get here so I can get them installed.
21TOR is offline   Reply With QuoteReply With Quote
Old 05-08-2021, 12:46 PM #9
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
Get it close to level and add air bags. I'm at 0.85 in front, nothing in the rear. Looks almost level. When carrying a load or trailer, I pump up the air bags.
Bilstein 5100 @ 1.75 with .4" OME rear?-085-jpg
BobsTrail is offline   Reply With QuoteReply With Quote
Old 05-08-2021, 01:05 PM #10
Dynamo's Avatar
Dynamo's Avatar
Looks good!
I've got my 5100's ready to be installed with Cornfed 1/2" rear spacers. I'm going to go with 0.85" in the front and the spacers in the rear.
2019 TRD ORP
Old 05-15-2021, 11:22 PM #11
Keith M Keith M is offline
Keith M is on a distinguished road
-JD
I have this setup. Zero complaints. That is, your original question 1.75 & .4 OME spacers. Actually I have the eibach's
30 years of 4runner ownership and counting. #1 1987-2001, 220k, #2 2001-2017, 215k, #3 2017 Off Road 50k, #4 2020 ORP. I'm done.
Keith M is offline   Reply With QuoteReply With Quote
Old 05-18-2021, 06:18 PM #12
Nick Nostril Nick Nostril is offline
Nick Nostril is on a distinguished road
Got my 5100s today!! (Thanks TAP!).
Now, it sounds like I probably am gonna need a spacer for the rears. I'd originally thought I'd just go .85" right now, but I'm really considering 1.75" now and 265 A/T tires.
'21 MGM ORP. Bilstein 5100s (0.85"), Pirelli Scorpion A/Ts (265), Husky mats, No-name crossbars, dashcam, and now with 100% more mud!
Nick Nostril is offline   Reply With QuoteReply With Quote
bilstein , give , rake , rear , slight
Bilstein 5100 2.5" Front and Daystar 1.5" Rear Spacer Write-up power818 Engines / Suspension / Wheels / Tires / Audio / Accessories 5 07-30-2022 10:21 PM
Bilstein 5100 kit with sotck spring, 2.5" lift up fron 1.5" daystar spacer in rear jb24dolphins 5th gen T4Rs 13 02-26-2020 08:21 PM
Bilstein 5100 2.5" front and daystar 2" spacer rear, on stock springs. Good?Bad?Ugly? Warwicke36 4th Gen T4Rs 13 02-25-2020 11:07 PM
Rear Bilstein 5100 0-2" $125 SKINUM For Sale: Suspension/Wheels/Tires 7 08-27-2015 10:22 AM
Urgent: >2" rear lift with Bilstein 5100's 07V8 4th Gen T4Rs 1 07-23-2015 01:31 AM
