Old 05-02-2021, 09:10 PM #1
Erock75 Erock75 is offline
Erock75 is on a distinguished road
Bilstein 6112’s/5160’s. I’ve got some questions
I’d like to run 6112’s at the 7/5 position for about 2.5 inches of lift and pair that with 5160’s and am looking for a level to very slight rake. The question is which rear springs to use? I’ve done a lot of searches and can’t seem to find what I need. Bilstein springs or wheelers? Maybe dobinsons or ome? Just looking for someone with this lift combo and what they used. I’ll be installing it on a 21 ORP without kdss or additional weight front or rear. Thanks!
Last edited by Erock75; 05-02-2021 at 09:29 PM. Reason: Additional information added
Erock75 is offline   Reply With QuoteReply With Quote
Old 05-02-2021, 09:55 PM #2
PCRIDE4RUNNERORG PCRIDE4RUNNERORG is offline
PCRIDE4RUNNERORG is on a distinguished road
I would say Dobinsons. They are the few that have multiple sizes from what I’ve seen. It seems that there is an OEM, and a 3” version mostly. Dobinson has the stiffer OEM size, and 1” more inch higher which is what you probably need. Maybe a combo of cornfed spacers and coils. Email the cornfed guy and ask. He is really responsive.
I have the same set up and currently lifted 1.65/1.75 3/4 C clip setting, with OEM springs in the rear and 1” cornfed spacer. 275 ko2’s
I’d like to go to 2” or even max them out, but then I’d probably need the drop kit and 285’s.
At that point I’d get control arms as well.
PCRIDE4RUNNERORG is offline   Reply With QuoteReply With Quote
Old 05-02-2021, 10:23 PM #3
dajosh dajosh is online now
dajosh is a jewel in the rough dajosh is a jewel in the rough dajosh is a jewel in the rough
6112’s up front at 2.5”. 5160’s out back.
Top: 2.5” Wheeler’s T12 springs
Bottom: 1.5” Wheeler’s T13 springs (which I still currently use)
-3937f2f9-63aa-4aab-b7dc-d5da31a6711c-jpg
dajosh is online now   Reply With QuoteReply With Quote
Old 05-02-2021, 11:50 PM #4
LeekT4R's Avatar
LeekT4R LeekT4R is offline
LeekT4R will become famous soon enough
LeekT4R's Avatar
I have 6112/5160’s
I am currently using the bilstein 600lb springs up front and the Wheelers T13 springs? They are 1.5” lift.
The bilstein springs SUCK! They are super soft, feel like stock springs. The Wheelers springs are good for the rear. Ive never had a problem.
I am installing King offroad 650lb springs front, and Dobinsons 325 rear springs rear this coming friday.
LeekT4R is offline   Reply With QuoteReply With Quote
Old 05-03-2021, 09:19 AM #5
RY11AN RY11AN is offline
RY11AN is on a distinguished road
I have this set up and went with OME springs. I haven't had any issues with 20K miles and it will give you a slight rake similar to stock.
RY11AN is offline   Reply With QuoteReply With Quote
Old 05-03-2021, 11:04 AM #6
Originally Posted by LeekT4R View Post
I have 6112/5160’s
Curious as to how it will look and ride with that combo. Let me know.
Old 05-03-2021, 11:05 AM #7
Which OME rear springs did you go with?
Old 05-04-2021, 09:54 AM #8
I went with the OME 2889 Medium Springs. I typically don't carry a lot of weight. Might need something else eventually if I keep adding things....
Old 05-04-2021, 10:04 AM #9
Check out the thread "Bilstein lift do I need rear springs" I added an older pic of my car in there that can possibly help.
Old 05-04-2021, 11:12 AM #10
dezertbomber dezertbomber is offline
dezertbomber has a spectacular aura about dezertbomber has a spectacular aura about
I have the 7/5 6112's but w/the 650lb springs up front, Dirt King UCA's, and Ironman 4x4 2" HD springs in the rear. The 5160's are not valved strong enough for the HD springs, so will prob go to Kings at some point.
Also to note, the increased spring strength front and back give a higher stance. If you're going stock or medium load springs your truck will sit a hair lower. This pic the truck is basically unloaded except for prob 60lbs of tools.
-2021-04-23_07-18-42_339smaller-jpg
dezertbomber is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 02:19 PM #11
anomalous's Avatar
anomalous anomalous is offline
anomalous will become famous soon enough anomalous will become famous soon enough
anomalous's Avatar
I have the TRD Pro Bilstein 6112 upfront with the FJ TTUE ~600lb spring to yeild around 2.5inch lift with Bilstein 5160 in the rear paired with Eibachs 1inch lift coils and OME 10mm trim pack spacers to get me ~1.5inch in the rear. So far I feel the 5160s and Eibach 1inch lift springs match pretty well. I'm pretty close to stock weight though, no bumpers, sliders, or gear. I think the Eibach rear lift springs are rated at around 210lbs-ish ? or about 10 - 15% over stock spring rate. I do like the feel of the larger body shock in front over the smaller 5160s in the rear. I'll probably go with 2.5inch shocks for the rear if\when the 5160s fail
∙ Toyota Racing Development ∙ Magnuson Superchargers ∙ Underdog Racing Development ∙ Baja Designs ∙ King Off-Road Racing Shocks ∙ Dirt King Fabrication ∙ Eibach ∙ Victory4x4 ∙ Hefty Fabworks ∙ Lil B Fabrication ∙ FN Wheels ∙ DuroBumps ∙ Toyo Tires ∙ Jomax Customs ∙ FJToyman ∙ UpTop Overland ∙
anomalous is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 06:06 PM #12
Six_Actual's Avatar
Six_Actual Six_Actual is offline
Real Name: AJ
Six_Actual will become famous soon enough
Six_Actual's Avatar
Real Name: AJ
OP, your planned setup will work well for level (or slight rake). I ran that setup with Bilstein standard weight springs. I don't know that they are soft (as someone else state). They are more firm that stock and feel good IMO.
Did you decide on anything yet?
Six_Actual is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 08:20 PM #13
I haven’t decided yet. The standard front springs should work perfect for me. I’m thinking the wheeler t13 rear springs at 1.5 inches should work well. Did you use the b12 bilstein rear lift springs?
Old 05-29-2021, 09:07 AM #14
DriftingOverland DriftingOverland is offline
DriftingOverland will become famous soon enough
Reviving this thread...
Got a Bilstein 6112/5160 Lift Kit. First... there is nothing wrong with it. All good, except...
I ordered the OME 898’s originally with the expectations of installing a 300lbs rear bumper. Bumper was put on hold. However, I have a winch and C4 bumper up front. The rake was BAD!
So, I put the original coils back in. But began to have a negative rake as I added gear in the cargo area. A few months later, I swapped out the originals for some 889’s, thinking it would level the rear. Well, no...I’m currently now 39.5” rear and 37” up front.
Terrible? Eh, but...
Suggestions for coil weight for the 6112’s up front (that fit over them and avoid shims) to give it a little lift? Even if it’s an inch?
Also, the future plan is to add dual battery set up and I’ve got JBA UCA’s if that helps you.
Trial Safe,
-JB
DriftingOverland is offline   Reply With QuoteReply With Quote
bilstein , i’ve , lift , springs , wheelers
FS: Bilstein 6112 & 5160 bebop For Sale: Suspension/Wheels/Tires 2 06-12-2020 04:49 PM
Bilstein TRD Pro suspension or Bilstein 6112/5160? MK_Ultra 5th gen T4Rs 7 05-20-2018 03:14 AM
Bilstein 6112/5160 vs Fox 2.0 - ??? fifthcircle 5th gen T4Rs 48 11-08-2017 09:24 PM
FS: Bilstein 6112/5160 RockyRider For Sale: Suspension/Wheels/Tires 7 12-31-2016 02:43 PM
