Old 05-04-2021, 07:15 PM #16
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
Originally Posted by Gouranga View Post
oh sorry didnt realize you got em in SL ..... only a lil heavier than the k02s in C in 265 44lb vs your 46lb... fair match
but you still goofed because the SL in 46 only have 14/32 of tread depth while the E has 18/32
I didn't goof. You goofed thinking I care about having maximum tread depth.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 08:04 PM #17
Gouranga Gouranga is offline
Gouranga is on a distinguished road
then why you get the tires just to be missing the aggressive tread lol
ok then
Gouranga is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 08:15 PM #18
ok then
I drive my 4Runner mostly on the road, with an off-roading trip maybe once a month. I want good onroad manners as well as good off-road performance, which the p-metric wildpeaks deliver.
1998 BMW M3/4/5
Old 05-05-2021, 01:56 AM #19
pull4adv's Avatar
pull4adv pull4adv is offline
pull4adv is on a distinguished road
pull4adv's Avatar
Originally Posted by mo_mo View Post
275 vs 265 may or may not yield more 'grip' depending upon the terrain and traction available.
TIRES. FAT OR SKINNY for Overland Touring? AndrewSPW Land Cruiser build-7 - YouTube
Regardless, it's going to be almost immeasurable. It will raise the vehicle CG slightly, but again it will be very small. Same with gas mileage. Once you take into account that your odometer is under reporting by the same amount, and if you reduce your speed to match, you won't see a measurable difference in mileage/range due to the tire size change you're looking at. Tread pattern, weight of the tire, P vs LT, tire pressure etc. will play a much larger roll in off road and on road manners and mileage.
A larger diameter tire may smooth the ride out over bumpy terrain, but we're talking small values here. A skinny tire will comply (deform) more readily at the same tire pressures to yield more grip... the answer to your question is do whatever makes you happy.
Thank you for this! I think i've made up my mind as well. Going with the 265s
21' TRD ORP Nautical Blue Pearl | KDSS
XPEL PPF Full Front | XPEL Ceramic Tint | Weathertech Visors | Falken A/T Wild Peaks | NW2 Rocksliders | CROR Molle Panel | Full RCI Skids | Westcott Designs Rack | Roam Adventure Awning
pull4adv is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 07:18 AM #20
aldi99 aldi99 is offline
aldi99 is on a distinguished road
how are the k02 taller? its 31.6" while the stock duller tires dueler are 31.7''
That’s non load bearing size. They are essentially the same with load, per the 657 revs per mile number. Also, those size numbers you mention could be rounded up or down, depending on source.
aldi99 is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 10:27 AM #21
Pedro367 Pedro367 is offline
Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all Pedro367 is a name known to all
Probably because the Duellers were low on tread or just aren't that tall to begin with. Otherwise I'm not sure. They definitely fill the wheel wells more and my trailer I pull had to be raised higher to get on my hitch afterward.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
Pedro367 is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 12:38 PM #22
BlueRidge77's Avatar
BlueRidge77 BlueRidge77 is offline
Real Name: Michael
BlueRidge77 will become famous soon enough
Real Name: Michael
Not to mention, I got 60k miles out of my SL 265/70 AT3W’s regardless of “less tread depth”. How many miles does one need from a tire? I’m itching to change much quicker than that lol... But it was a very good value for me. Performed very well. Same as you, I did notice a loss of pep due to the weight. My next tire with be TOYO Open Country AT3’s in stock size. 39lbs. See if I can get my lost zip back...
2016 MGM TEP w/KDSS - P285/70-17 Toyo Open Country AT3 on Stock Trail wheels, no spacers - Dobinsons IMS Lift 2.75”/2” (302/505 Springs) - Freedom Off-road UCAs - TRDP Grill - Redarc Trailer Brake Controller - SumoSprings Helper Spring Bumpstops (black)
BlueRidge77 is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 07:21 PM #23
21TOR 21TOR is offline
21TOR is on a distinguished road
Had these on another truck and soon to be on our 4Runner, great riding, great looking and long lasting tire.
21TOR is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 08:36 PM #24
StoneDog StoneDog is offline
Real Name: Jon
StoneDog is on a distinguished road
Real Name: Jon
Brand new E-rated 265 Toyo AT3 on my stock SR5. The TRD wheels would have pushed them just a bit further out.
275/70/17 vs stock 265/70/17-dsc01589-crop-jpg  275/70/17 vs stock 265/70/17-dsc01593-crop-jpg
StoneDog is offline   Reply With QuoteReply With Quote
275/70/17 , choice , plan , size , stock
Spidertrax 1.25" - Stock 2000 Suspension - 265/75/16 on stock 5 stars... SlickmisterN 3rd gen T4Rs 3 01-24-2015 05:38 PM
Caster question for stock supension and stock size tires... FrontRange4Runner 5th gen T4Rs 5 03-27-2014 02:53 PM
F/S CA Stock Catback 2001 Sport V6 4Runner & Stock Rear Springs & straightpipecatless GoHideTheAsian Classifieds - buy & sell (no commercial ads please) 4 02-06-2011 01:04 AM
Very nice Headrest Monitors, 06 JBL 6 disk, stock speakers, stock sub whoosh Classifieds - buy & sell (no commercial ads please) 2 07-30-2009 12:39 PM
