Old 05-04-2021, 01:45 PM #1
MaddoxPics's Avatar
MaddoxPics MaddoxPics is offline
MaddoxPics is a jewel in the rough MaddoxPics is a jewel in the rough MaddoxPics is a jewel in the rough
MaddoxPics's Avatar
Adding Oil To AC System
Anyone have experience adding PAG46 to the AC system? I rubbed a hole through my AC line and needed to replace it. That's been done, but I noticed I lost some oil. I read that the condenser line has 1oz of PAG46 in it, but I'm not sure if I read incorrectly or not.
Trying to figure out how that would be added.
Does anyone have any info or diagrams on this? As well as recharging the system?
Thanks
MaddoxPics is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 01:52 PM #2
DAW89446's Avatar
DAW89446 DAW89446 is offline
Real Name: Dave
DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light
DAW89446's Avatar
Real Name: Dave
You can buy oil or freon with oil at pretty much any automotive chain parts store. Possibly Walmart.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
DAW89446 is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 01:53 PM #3
MaddoxPics's Avatar
MaddoxPics's Avatar
So the oil that was lost wasn't a separate oil? I took it was that was oil for the system without the freon? Maybe I understood that incorrectly. This is my first time dealing with anything AC related.
Old 05-04-2021, 02:06 PM #4
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
The oil is in with the Freon, but is normally added separately. It circulates throughout the system to lubricate the A/C compressor.
Likely, you did not loose that much oil. It is added through the ports used to recharge the A/C system, but requires special equipment to do so.
First, you must evacuated the system to get ALL air and ALL moisture out of the system (and old Freon). You need an A/C vacuum to do that. The law requires you to not let any Freon escape into the air, thus the old Freon that is removed must be recycled.
Then you need a set of gauges and hoses, with the appropriate fittings to attach to the A/C ports, to measure the pressure in the system so you get the right amount of Freon into it.
Because of the specialized equipment needed, and the requirement to recycle the Freon, a vacuum, gauges, hoses, etc., it is best to leave the recharge to a mechanic shop.
fkheath is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 03:06 PM #5
vipergrhd's Avatar
vipergrhd vipergrhd is offline
vipergrhd is on a distinguished road
vipergrhd's Avatar
Refrigerant
Which refrigerant are you using? R134A or the new R1234yf? Is there a label under hood that says PAG46? Don't mix up the oil.
vipergrhd is offline   Reply With QuoteReply With Quote
Old 05-04-2021, 03:09 PM #6
MaddoxPics's Avatar
MaddoxPics's Avatar
A friend of mine has all the correct hoses and things to do it, just wanted to make sure I had the correct stuff before doing so.
Old 05-04-2021, 03:09 PM #7
MaddoxPics's Avatar
MaddoxPics's Avatar
Mine uses the R134A and the PAG46 oil is what goes with that, but it sounds like if I get the oil mixed with the freon I'll be fine.
Old 05-05-2021, 11:47 PM #8
Jeremy556's Avatar
Jeremy556's Avatar
You most likely don't need oil. A little will get blown out with the refrigerant, but not enough to matter. Just pull vacuum and recharge with specified amount of refrigerant.
adding , line , oil , read , system
Adding a USB outlet...which system to tap? jcampo788 4th Gen T4Rs 18 02-14-2021 02:44 PM
Doing away with my stock system & adding new system. Anonymous4Runner Engines / Suspension / Wheels / Tires / Audio / Accessories 10 12-07-2011 12:50 AM
Adding a A/C system rlpjw1959 Classic T4Rs 1 11-23-2011 08:35 AM
Adding Aftermarket Nav System ?'s BAMABUCKHUNTER 4th Gen T4Rs 1 01-23-2009 01:55 PM
Adding Sirius/XM to OEM Nav system crozhawk Engines / Suspension / Wheels / Tires / Audio / Accessories 13 01-08-2007 12:13 AM
