Old 05-05-2021, 10:51 AM #1
amir_gh's Avatar
amir_gh amir_gh is offline
amir_gh will become famous soon enough
amir_gh's Avatar
Is my shock leaking
Hello everyone,
Is my shock leaking? Just noticed this today
Is the shock absorber or hydraulic cylinder?
amir_gh is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 11:22 AM #2
MStudt's Avatar
MStudt MStudt is online now
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
I would say yes based on the single picture you posted.
You
MStudt is online now   Reply With QuoteReply With Quote
Old 05-05-2021, 11:24 AM #3
amir_gh's Avatar
amir_gh's Avatar
Is my shock leaking
You
Is it the the shock absorber or the hydraulic cylinder? Shock absorber is $300, but hydraulic cylinder is like $1400
Old 05-05-2021, 11:44 AM #4
toomanytacos's Avatar
toomanytacos toomanytacos is offline
toomanytacos is on a distinguished road
Looks like that strut is toast from what you show. Might be a KDSS leak but i'm betting on the strut.
2016 T4R Trail
Mobtown Offroad Steel Skids
+ all the mainstream Overland junk
toomanytacos is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 11:55 AM #5
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
It's your front strut. Looks like the fluid was running down from under the cover, and collect dirt on the lower rap at the perch. I don't see anything below the perch, and that would indicate that it came from above.
Mike
Old 05-05-2021, 12:25 PM #6
amir_gh's Avatar
amir_gh's Avatar
Is my shock leaking
Mike
Thanks Mike, what should I do at this point? Replace the driver side shock absorber? Is that all? Anything else that I need to be aware of? I
The part number is 48510-80499 for my car.
Old 05-05-2021, 12:45 PM #7
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
@amir_gh your profile picture shows a 4Runner Limited model.
If the picture of your leak is from a Limited 4Runner, then you likely have the X-REAS suspension system.
Toyota 4-Runner X-REAS Shocks - Shockwarehouse.com
5th gen and XREAS system
X-reas
Xreas failure at 30k miles
5th Gen Limited X-REAS Leak - Options?
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 01:43 PM #8
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
I don't know anything about XREAS, but I do know KDSS would not show a leak like that on the coilover.
$300? for a shock? I replaced my fronts and they were $30.00 something each for OEM and i did it myself using methods found on here. Mine wasn't red though, so maybe the new runners have red shocks that cost more?
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 03:52 PM #9
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Don’t know what he has.
Doesn’t look OEM, at least my 21 TRDOPR came with the same black Tokico shocks/coilovers as my previous 14 SR5P.
Best Regards,
Saker
Old 05-05-2021, 04:09 PM #10
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
XRES are more expensive, and a bit different than what you have.
Your's isn't a Limited so it won't be the same. Definitely OEM too.
Old 05-05-2021, 04:23 PM #11
Saker's Avatar
Saker's Avatar
Well, thank you........
that explains that!
Best Regards,
Saker
Old 05-05-2021, 06:26 PM #12
amir_gh's Avatar
amir_gh's Avatar
So can I just replace the leaking shock with a new one?
Old 05-05-2021, 06:29 PM #13
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
I think you first need to confirm that's the problem. If so, then yes, replace it.
Mike
Old 05-05-2021, 06:45 PM #14
DannyLlama's Avatar
DannyLlama DannyLlama is offline
Real Name: Danny
DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough DannyLlama is a jewel in the rough
DannyLlama's Avatar
Real Name: Danny
First - before you buy anything. Check if there are leaks anywhere else in your truck that are spilling to your shocks.
Second - Toyota assigns a 1through 5 leak-stage rating system. If its 3 or below they wont replace it. There has to be some logic to this. Therefore, have them assess and tell you what stage it is.
Third - If you do need to change it, you have two options. Replace with like-for-like XREAS system. OR Rip it out and lift it with kings and you will be at same cost, more clearance and longer lasting shocks. I know this because I had the dealer replace 2 XREAS systems. Its garbage for longevity.
Fourth - if I have my old XREAS for sale :P if you want to make an offer
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
DannyLlama is offline   Reply With QuoteReply With Quote
Old 05-05-2021, 06:49 PM #15
DannyLlama's Avatar
Real Name: Danny
DannyLlama's Avatar
Real Name: Danny
Mike
You can't replace just one. They are all (all 4) hydraulically connected.
Dual Battery Thread
iphone , leaking , noticed , shock , today
leaking rear shock 4.yota Engines / Suspension / Wheels / Tires / Audio / Accessories 0 11-08-2020 09:39 PM
Leaking shock LTDanTRDPRO 5th gen T4Rs 3 07-29-2017 06:23 PM
Leaking (new) Icon Shock Question/Help OregonTrailRunner General Discussions 6 06-14-2016 03:36 PM
Is my shock leaking? JohannS 4th Gen T4Rs 5 03-21-2013 10:33 AM
Leaking Read Shock WhiteLightning 4th Gen T4Rs 2 12-17-2012 09:00 PM
