Old 05-06-2021, 01:25 PM #1
usdmej usdmej is offline
usdmej will become famous soon enough
sound issues after speaker upgrade
Just installed new components in front and coaxials in the rear doors using tacotunes speaker adapter plates (removed and bypassed the cargo hatch speakers to keep the rear speakers in series).
unfortunately my driver side speakers now play significantly lower in volume than the passenger side speakers, probably at 20% of what the passenger side is outputting
passenger side speakers sound fantastic but i'm getting an audible buzzing sound from the front component speakers when the vehicle is on
anyone else run into these issues?
usdmej is offline   Reply With QuoteReply With Quote
Old 05-06-2021, 11:37 PM #2
rhadam's Avatar
rhadam rhadam is offline
rhadam has a spectacular aura about rhadam has a spectacular aura about
rhadam's Avatar
I installed TacoTunes speakers, ran them for a couple months before upgrading to a Kenwood 10.1" headunit and speakers all around. Never had an issue with the TT speakers. Buzzing would typically indicate a grounding issue... right?
2017 T4R OR Super White
RRW RR4-V bronze wheels, Diode Dynamics SS3 Fog + Ditch, C4 Fab Lo Pro Winch Bumper + Smittybilt 10k synthetic, UpTop Overland Bravo Roof Rack
Dobinson's full suspension 2.5" front 1.5" rear - Dobinson's UCA - DirtKing LCA
Kenwood eXcelon 10.1 headunit + Kenwood speakers
rhadam is offline   Reply With QuoteReply With Quote
Old 05-06-2021, 11:44 PM #3
Skidmarcx's Avatar
Skidmarcx Skidmarcx is offline
Skidmarcx will become famous soon enough
Skidmarcx's Avatar
More info on how the components are connected needed.
What do you mean you bypassed the rear lift gate speaker? I guess I don’t know how Toyota connects all the rear speakers
97 Limited 4x2 ---> 4x4 (SOLD)
SS 1.3 | ToyTec | RadFlo | Aussie | SOR | AOR | CBI | DC Power | Rigid | Alpine | Audison | JL Audio | Second Skin
2020 TRD Off Road Premium
King | BFG | Rago | AudioControl | AudioFrog | JL Audio | Dynamat
Skidmarcx is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 08:26 AM #4
MedicLt MedicLt is offline
MedicLt is on a distinguished road
I did a double layer of dynamatting in all my doors and hatch. That alone improved the road noise issue.
I did Hertz component speakers all around a 10” JL sub w/custom enclosure (should have gone 12”) JL amp and Cleansweep.
Can you swap that buzzy b**ch of a speaker out?
That sucks dude. Hope you sort it out.
2015 TRD Pro.
MedicLt is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 08:51 AM #5
21TOR 21TOR is offline
21TOR is on a distinguished road
You should be able to adjust the balance to compensate, probably set up that way originally.
Guessing after you changed the speakers you are noticing the set up by the factory signal.
No idea on the buzzing.
21TOR is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 09:01 AM #6
Tieyota Tieyota is offline
Tieyota is on a distinguished road
Buzzing does typically indicate a grounding issue. I’d recheck your wiring and make sure none of it was pinched by anything once you installed it in the door
Tieyota is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 11:26 AM #7
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
Did you match the Impedance to the factory speakers? Did the factory speakers have any kind of foil backing to prevent interference?
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 12:45 PM #8
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Buzzing is usually cause by the following: Bad or loose connection, blown speaker (yes even new speakers sometimes) Bad or loose ground, Impedance mismatch. Sometimes you don't get what you ordered; I'd check to insure all speakers are correct and match your head unit. Swap the buzzing speaker to another spot and see.
Old 05-21-2021, 05:08 PM #9
thanks for the help guys.
i was able to figure out the buzzing, my right front crossover was too close to some wires. once i relocated them the buzzing stopped.
Originally Posted by Dude View Post
Did the same setup. Check your jumpers...I used a Metra speaker harness and just wired the leads together and snapped them in.
Also, how did you tap the lead for your front component crossover? I pulled mine using a Tacotunes tweeter adapter running the full range signal to the crossover and then new speaker wiring to the tweeter and mid. I noticed that on of the pins in that harness was not properly seated...check it.
Also double check any adapters used at the speaker itself and connections....any connection point is a possible failure.
Otherwise it might help if you post up details on how you wired it all up.
if you've suggested that in other threads then i might have copied you since im running the same wiring as you.
however, for the front component crossover, the TT harness had 4 wires coming out (2 went to the crossover input, 2 went to the crossover woofer output). i only had to run 2 wires from the tweeter out to the tweeter.
Old 05-21-2021, 05:16 PM #10
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
Did you figure out why the driver’s side volume was so low?
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 05-24-2021, 03:06 PM #11
unfortunately no, with more listening i'm noticing the right and left side have a different sound signature too (right/loud side is more clear with better highs) which leads me to believe there is a connection issue and not just a system imbalance.
are you having a similar issue?
Old 05-24-2021, 03:23 PM #12
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
The buzzing is a ground loop and something is not grounded properly, the volume issue sounds to me like a wiring configuration issue or something with the bypassing of the rear speakers
Old 05-24-2021, 04:04 PM #13
as i said earlier, the buzzing sound was the crossover being too close to some other wires.
the only thing swapped were the speakers, there was no grounding involved anywhere. can you explain why you think it's related to grounding as others have also suggested?
Old 05-24-2021, 04:47 PM #14
ads2539's Avatar
ads2539's Avatar
No, I’m not. No part of my system is JBL or Toyota, not even the speaker wires. I was just interested in this thread.
Old 05-25-2021, 01:34 AM #15
2Biglabs 2Biglabs is offline
2Biglabs is on a distinguished road
Phase?
Are the speakers in phase on both sides? That might come across as low volume. Crossovers, depending on the style, change the phase in different ways. Depends on what dB/octave they are.
If one speaker is "out of phase" with all the other seakers "in phase" the odd man out will be lower.
When i say in phase, it meant all speakers are + at the same time or - at teh same time. Autosound2000 (if there still around) has a CD (sorry, im old) that has a track to determine proper phasing.
Good luck.
2Biglabs is offline   Reply With QuoteReply With Quote
front , passenger , side , sound , speakers
Speaker upgrade/sound system opinions? CDNsurf 3rd gen T4Rs 23 02-11-2015 06:58 PM
No sound after speaker upgrade parawing742 4th Gen T4Rs 9 03-10-2014 11:14 AM
Having sound/speaker issues - stock radio jscorsone 5th gen T4Rs 3 11-15-2012 08:47 PM
Sound Quality of 8 speaker Entune system vs. 15 Speaker Nav/JBL system Crit Rat 5th gen T4Rs 5 01-17-2012 06:39 PM
JBL 10 Speaker Sound marnok Engines / Suspension / Wheels / Tires / Audio / Accessories 0 06-20-2006 10:05 AM
