05-06-2021, 01:25 PM
sound issues after speaker upgrade
Just installed new components in front and coaxials in the rear doors using tacotunes speaker adapter plates (removed and bypassed the cargo hatch speakers to keep the rear speakers in series).
unfortunately my driver side speakers now play significantly lower in volume than the passenger side speakers, probably at 20% of what the passenger side is outputting
passenger side speakers sound fantastic but i'm getting an audible buzzing sound from the front component speakers when the vehicle is on
anyone else run into these issues?
05-06-2021, 11:37 PM
I installed TacoTunes speakers, ran them for a couple months before upgrading to a Kenwood 10.1" headunit and speakers all around. Never had an issue with the TT speakers. Buzzing would typically indicate a grounding issue... right?
2017 T4R OR Super White
RRW RR4-V bronze wheels, Diode Dynamics SS3 Fog + Ditch, C4 Fab Lo Pro Winch Bumper + Smittybilt 10k synthetic, UpTop Overland Bravo Roof Rack
Dobinson's full suspension 2.5" front 1.5" rear - Dobinson's UCA - DirtKing LCA
Kenwood eXcelon 10.1 headunit + Kenwood speakers
05-06-2021, 11:44 PM
More info on how the components are connected needed.
What do you mean you bypassed the rear lift gate speaker? I guess I don’t know how Toyota connects all the rear speakers
97 Limited 4x2 ---> 4x4 (SOLD)
SS 1.3 | ToyTec | RadFlo | Aussie | SOR | AOR | CBI | DC Power | Rigid | Alpine | Audison | JL Audio | Second Skin
2020 TRD Off Road Premium
King | BFG | Rago | AudioControl | AudioFrog | JL Audio | Dynamat
05-07-2021, 08:26 AM
I did a double layer of dynamatting in all my doors and hatch. That alone improved the road noise issue.
I did Hertz component speakers all around a 10” JL sub w/custom enclosure (should have gone 12”) JL amp and Cleansweep.
Can you swap that buzzy b**ch of a speaker out?
That sucks dude. Hope you sort it out.
2015 TRD Pro.
05-07-2021, 08:51 AM
You should be able to adjust the balance to compensate, probably set up that way originally.
Guessing after you changed the speakers you are noticing the set up by the factory signal.
No idea on the buzzing.
05-07-2021, 09:01 AM
Buzzing does typically indicate a grounding issue. I’d recheck your wiring and make sure none of it was pinched by anything once you installed it in the door
05-07-2021, 11:26 AM
Did you match the Impedance to the factory speakers? Did the factory speakers have any kind of foil backing to prevent interference?
05-07-2021, 12:45 PM
Buzzing is usually cause by the following: Bad or loose connection, blown speaker (yes even new speakers sometimes) Bad or loose ground, Impedance mismatch. Sometimes you don't get what you ordered; I'd check to insure all speakers are correct and match your head unit. Swap the buzzing speaker to another spot and see.
05-21-2021, 05:08 PM
thanks for the help guys.
i was able to figure out the buzzing, my right front crossover was too close to some wires. once i relocated them the buzzing stopped.
Originally Posted by Dude
Did the same setup. Check your jumpers...I used a Metra speaker harness and just wired the leads together and snapped them in.
Also, how did you tap the lead for your front component crossover? I pulled mine using a Tacotunes tweeter adapter running the full range signal to the crossover and then new speaker wiring to the tweeter and mid. I noticed that on of the pins in that harness was not properly seated...check it.
Also double check any adapters used at the speaker itself and connections....any connection point is a possible failure.
Otherwise it might help if you post up details on how you wired it all up.
if you've suggested that in other threads then i might have copied you since im running the same wiring as you.
however, for the front component crossover, the TT harness had 4 wires coming out (2 went to the crossover input, 2 went to the crossover woofer output). i only had to run 2 wires from the tweeter out to the tweeter.
05-21-2021, 05:16 PM
Real Name: Howard J. Turkstra
Did you figure out why the driver’s side volume was so low?
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
05-24-2021, 03:06 PM
unfortunately no, with more listening i'm noticing the right and left side have a different sound signature too (right/loud side is more clear with better highs) which leads me to believe there is a connection issue and not just a system imbalance.
are you having a similar issue?
05-24-2021, 03:23 PM
Real Name: Chris
Real Name: Chris
The buzzing is a ground loop and something is not grounded properly, the volume issue sounds to me like a wiring configuration issue or something with the bypassing of the rear speakers
05-24-2021, 04:04 PM
as i said earlier, the buzzing sound was the crossover being too close to some other wires.
the only thing swapped were the speakers, there was no grounding involved anywhere. can you explain why you think it's related to grounding as others have also suggested?
05-24-2021, 04:47 PM
No, I’m not. No part of my system is JBL or Toyota, not even the speaker wires. I was just interested in this thread.
05-25-2021, 01:34 AM
Phase?
Are the speakers in phase on both sides? That might come across as low volume. Crossovers, depending on the style, change the phase in different ways. Depends on what dB/octave they are.
If one speaker is "out of phase" with all the other seakers "in phase" the odd man out will be lower.
When i say in phase, it meant all speakers are + at the same time or - at teh same time. Autosound2000 (if there still around) has a CD (sorry, im old) that has a track to determine proper phasing.
Good luck.
