Old 05-07-2021, 04:57 PM #16
Hans Moleman Hans Moleman is offline
Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about
My 2nd gen Tacoma parking brake has much more holding power. My 4Runner is so weak. The Tacoma does have a huge drum and regular brake shoes so that's probably why. The 4Runner has tiny parking shoes inside the rotor.
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
Hans Moleman is offline   Reply With QuoteReply With Quote
Old 05-08-2021, 06:26 AM #17
TRDrew's Avatar
TRDrew TRDrew is offline
TRDrew is on a distinguished road
TRDrew's Avatar
Update - had to basically argue with the dealer, but he sent it back to a technician who did find it needed to be adjusted. Now it seems to hold better, but still a little roll. The pedal used to go all the way to the floor with barely any effort. Now it goes 3/4 of that distance but I have to push hard. I guess it will have to do. Thanks much for the comments and feedback.
TRDrew is offline   Reply With QuoteReply With Quote
Old 05-08-2021, 12:41 PM #18
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a glorious beacon of light BobsTrail is a glorious beacon of light BobsTrail is a glorious beacon of light BobsTrail is a glorious beacon of light BobsTrail is a glorious beacon of light
BobsTrail's Avatar
Real Name: BobH
Originally Posted by Unretired View Post
I always put the truck in neutral, set the parking brake, feel it hold, then put it in park so the stress isn't on the parking pawl. Months after the adjustments, my parking brake will still hold on 6-7 clicks nose uphill and 4-5 clicks nose downhill.
I have been doing it this way for 8 years and it works fine. Have not needed to adjust in 67K miles.
The difficulty was getting my wife to do it this way.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 05-08-2021, 01:39 PM #19
jmf_tracy jmf_tracy is offline
jmf_tracy is on a distinguished road
you need to adjust it properly.
Mine was never adjusted properly from the dealer (lazy mechanics) and I finally broke down and adjusted it correct and it works great now.
BLACK 2015 TRD PRO - SAFARI SNORKEL - GOBI STEALTH - TREK BOXX
ICON STAGE 7 (700 LB SPRINGS) - 285/75 R17 NITTO TRAIL GRAPPLER
MAGNUSON SUPERCHARGER - URD FUEL & TUNE UPGRADE
DUAL BATTERY - 250 AMP ALTERNATOR - COMEUP 9500 RSI
SCHROCKWORKS BUMPERS, SLIDERS & SKIDS - 4.56 GEARS
jmf_tracy is offline   Reply With QuoteReply With Quote
Old 05-08-2021, 11:05 PM #20
TRDrew's Avatar
TRDrew's Avatar
Nope. They got it. I posted an update - all good. I just didn’t care for having to argue over it. Customer expresses concern. Just look into it. Don’t tell them some BS that non-functioning is how it’s supposed to be.
Old 05-08-2021, 11:46 PM #21
Arthur4R's Avatar
Arthur4R Arthur4R is offline
Arthur4R is on a distinguished road
Arthur4R's Avatar
2021 4Runner limited parking brake is terrible barely holds at full clicks on a small incline in the driveway.
2021 4Runner Limited
2018 4Runner Trd Off Road kdss SOLD!
Arthur4R is offline   Reply With QuoteReply With Quote
Old 05-09-2021, 08:55 AM #22
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
How do you gain access to the star nut? In previous cars I have seen a rubber plug but on my 2016 I see a metal plug which appears to be permanent.
Do I have to remove the wheel, remove the rotor, make an adjustment and see if the rotor will still slide back over the drum pads?
Or do I somehow remove the metal plug? But it seemed pretty permanent when I poked at it.
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
Old 05-09-2021, 12:03 PM #23
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a glorious beacon of light Jivewalker is a glorious beacon of light Jivewalker is a glorious beacon of light Jivewalker is a glorious beacon of light Jivewalker is a glorious beacon of light
Jivewalker's Avatar
There should be a hole in the rotor that lines up with the hole in your hub. If its not lined up, pull it off and line it up. You should then be able to adjust old school way with a flathead. What gets me that they should auto adjust on reverse. the only time I ever had to touch mine was when I replaced the rear rotors. I had to back the ebrake adjuster off to be able to pull the rotor.
2012 TE KDSS | Black| 265/70R17 C KO2's @ 44psi | 225,000 miles |Link To Inside Fishing Rod Holder Mod
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 05-09-2021, 10:25 PM #24
the_economist's Avatar
the_economist the_economist is offline
the_economist is on a distinguished road
Yes, once you remove your wheel you should have the e-break off and be able to spin the hub. You’ll see a hole in the hub, and just keep spinning it around until it lines up with the hole behind it in the rotor. Inside that hole you’ll be able to access the star nut with a flathead screwdriver. I can’t remember whether clockwise is tightening or loosening on this, but you’ll figure it out pretty quick. Just keep turning the star nut until the e-brake grabs the wheel and you can’t spin it any longer, then back it off a couple turns.
2016 4Runner SR5 4x4. BFG A/T K02s (275/70/17 E Rated). 2-inch Icon rear springs. Bilstein 6112s front (1.2" setting), 5160s rear. RCI skid plates package + gas tank (3/8 in. steel), RCI rock sliders. Warn semi-hidden winch mount + Warn Zeon 10-S Platinum winch. Raingler cargo nets (roof and rear). TRD wheels. LFD rooftop crossbars.
the_economist is offline   Reply With QuoteReply With Quote
Old 05-10-2021, 07:34 AM #25
Jivewalker's Avatar
Jivewalker's Avatar
Here is the hub/ebrake behind it. You should have holes like the two on mine. The holes in your rotor should line up. My rotor has a hole between each stud. If not, I'm confused.
-rrotor-jpg
I am fragile.
Not like a flower.
But like a bomb.
Old 05-10-2021, 07:39 AM #26
Jivewalker's Avatar
Jivewalker's Avatar
Not sure why pics wont post, lets try again.
-rotor3-jpg  -rrotor-jpg
I am fragile.
Not like a flower.
But like a bomb.
Old 05-10-2021, 10:01 AM #27
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
This video shows it pretty decently. 5th gen Toyota 4Runner rear parking brake adjustment - YouTube
Here's the full procedure from the factory shop manual I assume. http://www.toyota-4runner.org/attach...7LYwKEteS1gy2g
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
asked , brake , emergency , i’ve , rolls
Parking Brake / Emergency Brake Question Woz1976-MT 5th gen T4Rs 5 04-21-2018 05:52 PM
Emergency brake HELP 1998 Runner 3rd gen T4Rs 2 03-01-2015 02:43 PM
Emergency brake JohnnyT 4th Gen T4Rs 4 12-10-2012 06:50 AM
Emergency Brake Tonedog 4th Gen T4Rs 6 09-25-2008 12:44 AM
emergency brake gonzo 4th Gen T4Rs 5 10-10-2004 07:36 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
