Old 05-07-2021, 07:57 AM #1
TRDrew's Avatar
TRDrew TRDrew is offline
TRDrew is on a distinguished road
TRDrew's Avatar
Emergency brake - “they all do that”
2020 4Runner ORP with 7,700 miles on the clock. I set my emergency brake frequently when parking because I live in very hilly terrain (West Virginia). Truck always rolls on to transmission anyway. And I’ve driven off with emergency brake still set and only realized because the truck beeped to warn me. I asked dealer to look at it and tighten up. They told me, “they all do that. 4Runners, Tacomas… They all roll a little after setting the brake.” Hmmm. I’ve owned 30 cars in my life - including several large, heavy SUVs and I’ve NEVER had a car that rolls after setting the brake. I asked them to look at it anyway, even though they almost, basicallly refused my request. So…. Is this what the 4Runner community experiences? A emergency brake that is one step above worthless???
TRDrew is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 08:34 AM #2
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Mine doesn't roll. Once I engage it stays. Just thinking mechanically, I don't think it should roll. The e brake pads should expand against the inside of the rotor and hold tight. Sounds like it needs adjusted or something isn't correct. I would tell them to fix it or escalate the issue to the manager or even Toyota. On previous cars, rolling backwards and stopping would auto adjust the e brake, but it could be something not installed correctly. That's my $.02.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 08:59 AM #3
Tieyota Tieyota is offline
Tieyota is on a distinguished road
I can tell you my Tacoma had an amazing parking brake and did not roll! But it was also operated by a handle and not a pedal. The one on my 2021 tends to do the same as you’re describing and I’ve been less than impressed, but the dealerships around here are garbage so I’ve just grown used to it. Parking brakes on newer vehicles are USUALLY self adjusting. I say usually because Toyota slacks so bad in some areas that I honestly wouldn’t be surprised if I took the rear apart to see it’s manually adjusted still
Tieyota is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 09:06 AM #4
Baystate4Runner's Avatar
Baystate4Runner Baystate4Runner is offline
Baystate4Runner will become famous soon enough Baystate4Runner will become famous soon enough
My 4Runner does not roll after setting the e-brake.
2024 Lexus GX550 Overtrail+ - pre ordered
2021 TRD Pro - Lunar Rock
2017 TRD Pro - Super White, RCI Rock Sliders, Falken Wildpeak A/T3W - SOLD
2012 Porsche Cayman S
Baystate4Runner is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 09:16 AM #5
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
It might settle but it should not roll. It shouldn't put a lot of pressure on the parking pawl either.
If you leave it in N and set the brake and then truck rolls, or, you leave in park, set the brake and the pawl is hard to disengage, then the aux brake needs to be serviced.
I use mine a lot, too (Colorado) and it doesn't roll. Even on steel inclines when out wheeling.
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 09:27 AM #6
Unretired Unretired is offline
Real Name: Terry
Unretired will become famous soon enough Unretired will become famous soon enough
Real Name: Terry
Parking Pawl
They all do that because so many are adjusted wrong and just rolling onto the parking pawl and not really using the parking brake. I'm unimpressed with the parking brake, but after fiddling with it several times I have gotten it to work. It seems to hold MUCH better nose down hill.
I adjusted the brake with the shoe adjusters at the rear wheels and that helped, but didn't seem to last. The third adjustment I also took up slack under the center console and tightened up the lock nut real well and that has made a difference... maybe it was slipping?
I always put the truck in neutral, set the parking brake, feel it hold, then put it in park so the stress isn't on the parking pawl. Months after the adjustments, my parking brake will still hold on 6-7 clicks nose uphill and 4-5 clicks nose downhill.
2016 SR5 - Wildpeak A/T3W 265/70R17SL or BFG K02 C Load 285/70R17; RSG Sliders; LFD Crossbars, Skid Plates & Hybrid Bumper; RCI Skids on Rear Diff, Lower Links & Shock Mounts; Engo SR10S Winch; Dobinson 700/701 IMS with 314/327 Coils +2.25" front +2.5" rear; Goat Armor; Redarc Brake Controller; Camping Hatch Mod; DIY Drawers & Sleeping Platform; Cheap 10" Light Bars in Grill; Front/Rear Camera Mod with Nav Input; Simple Nav/Comms - Garmin inReach Mini, iPad & Motorola FRS.
Unretired is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 10:14 AM #7
jhguth jhguth is offline
jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold jhguth is a splendid one to behold
i've also noticed that mine holds the vehicle pretty well when facing nose down, but not very well when facing nose up. i've needed to adjust mine for the past year, but i'm just lazy
jhguth is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 10:17 AM #8
the_economist's Avatar
the_economist the_economist is offline
the_economist will become famous soon enough
About six months after I bought my 2016 SR5 brand new, I decided it was time to adjust my parking break for the same reason.
It will take you about an hour to do so. Try searching around for some threads here for instructions.
As a first step, you should be adjusting the parking brake from the rear wheels with the tires off. With the car off the ground and parking brake off, you use a screwdriver to tighten the star wheel through the small hole in the brake drum. Keep tightening until the wheel just can’t spin by hand. Then you back off and loosen a couple turns to make sure the brake isn’t dragging.
I did that adjustment once about three years ago, and have not had to adjust it since. My truck doesn’t roll anymore with a brake on.
2016 4Runner SR5 4x4. BFG A/T K02s (275/70/17 E Rated). 2-inch Icon rear springs. Bilstein 6112s front (1.2" setting), 5160s rear. RCI skid plates package + gas tank (3/8 in. steel), RCI rock sliders. Warn semi-hidden winch mount + Warn Zeon 10-S Platinum winch. Raingler cargo nets (roof and rear). TRD wheels. LFD rooftop crossbars.
the_economist is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 10:28 AM #9
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
with my ebrakes on, my 4runner isnt moving lol...
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 01:30 PM #10
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
My 2020 also has a pretty soft parking brake and it doesn’t hold my truck on steep hills either.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 01:33 PM #11
justanothereric justanothereric is offline
justanothereric is on a distinguished road
I noticed this from day 1 of owning the 4Runner and it bothers me EVERY time I park and engage it. Just figured the car was too heavy and fat so the parking brake sucks. Even on flat surfaces it will still move unless I jam down on the parking brake with like 250lbs of force.
justanothereric is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 01:34 PM #12
Whippersnapper02's Avatar
Due to their design, drum brakes (yes the parking brake is basically is drum brake) work better rolling forward than backwards. I guess I don't park on hills all that much and when I do I point the wheels into the curb but I don't recall my Runner moving or barely moving when I set the parking brake.
Old 05-07-2021, 01:40 PM #13
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
I must have got a good one. Pull uphill steep driveway and it holds pressed even halfway down. No rollback.
I hope what they meant by “they all do that” is that they are all inconsistent?
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 03:35 PM #14
Pilotmatt's Avatar
Pilotmatt Pilotmatt is offline
Pilotmatt is on a distinguished road
Pilotmatt's Avatar
My ebrake isnt great but when I push the clutch in between gears it definitely slows down.
For those of you under 25 let me explain a clutch…
2017 SR5 4WD Premium
2003 SR5 4WD V8 (2010-2017)
Pilotmatt is offline   Reply With QuoteReply With Quote
Old 05-07-2021, 04:40 PM #15
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Really put your foot into it. It should hold on even steep hills. If not, get it adjusted.
1000MPH is offline   Reply With QuoteReply With Quote
asked , brake , emergency , i’ve , rolls
Parking Brake / Emergency Brake Question Woz1976-MT 5th gen T4Rs 5 04-21-2018 05:52 PM
Emergency brake HELP 1998 Runner 3rd gen T4Rs 2 03-01-2015 02:43 PM
Emergency brake JohnnyT 4th Gen T4Rs 4 12-10-2012 06:50 AM
Emergency Brake Tonedog 4th Gen T4Rs 6 09-25-2008 12:44 AM
emergency brake gonzo 4th Gen T4Rs 5 10-10-2004 07:36 AM
